    Default calendar
    10 Posts 2 Posters 2.4k Views 2 Watching
      aquaman
      I have used fb2cal (https://github.com/mobeigi/fb2cal) to create a local ics (facebook birthdays) for my default calendar module. But my calendar wont show this at all. I have managed to show other ics files from local destination, so that part works. My fb2cal ics is successful imported into google calendar, so I guess the ICS is more or less OK. The ICS file is temporary uploaded to http://elitek.no/elicraft/birthdays.ics (no sensitive information, just a lot of birthdays for those who are interrested to congratulate any of them ;-) )
      I am running MM v2.9.0…
        sdetweil @aquaman
        @aquaman the calendar data looks fine…
        where on your local system did you place that file? it MUST be under the modules/default/calendar folder
        also, open the developers window, ctrl-shift-i, select the tab labeled ‘console’ and scroll up to see if there are any errors reported, usually red text
          aquaman
          Thank you for your reply.
          I have the ICS file under /MagicMirror/modules. I have also downloaded another ics-file named basic.ics (from google calendar) in same folder. basic.ics works just fine, but birthdays.ics is not. I have now also tried both files in /default/calendar with same result (basic.ics works, birthdays.ics not…)
          I cannot find any reported errors i developers window (console) about calendar at all…
            sdetweil @aquaman
            @aquaman after debugging, the problem is the file created by fb2ics has linux line ends (\n), but the code is looking for windows line ends (\r\n)
            once I edited and saved with windows line ends it works
            you could use unix2dos on it to convert the line ends
            I have opened an issue and submitted a pull request to the ical parser github project for this
            https://github.com/peterbraden/ical.js/issues/105
              aquaman
              Ahh.
              Thank you!
              I have tried unix2dos with newline option, but no luck yet. Seems that there are no changes in the file after running the command. Propably need some more help from google ;-)
              But thank you for your help so far :-)
                sdetweil @aquaman
                @aquaman you shouldn’t need to specify any options…
                just
                unix2dos filename
                it will convert in place
                or -ascii convert only line breaks (default)
                unix2dos -ascii filename
                  aquaman
                  Yes…
                  Done that…
                  Filesize is exactly same, however file date/time has been changed…
                    sdetweil @aquaman
                    @aquaman worked for me in both directions, no parm specified…
                    odroid@odroid:~/MagicMirror/modules/default/calendar$ unix2dos birthdays.ics
                    unix2dos: converting file birthdays.ics to DOS format...
                    and
                    odroid@odroid:~/MagicMirror/modules/default/calendar$ dos2unix birthdays.ics
                    dos2unix: converting file birthdays.ics to Unix format...
                    i then used Notepad++ to search for \r\n (windows) or \n (unix) linebreaks
                    found as expected
                      aquaman
                      Hmm… Starting to get embarrased ;-)
                      Can i provide you a ip an password on pm to log on?
                        sdetweil @aquaman
                        @aquaman sure, come over to discord chat, i am sam #5710, if can’t do discord, then email … same userid as here but on gmail
                        yeh, or direct chat here… sorry, missed that
