Default calendar
10 Posts 2 Posters 1.8k Views 2 Watching
    aquaman
    I have used fb2cal (https://github.com/mobeigi/fb2cal) to create a local ics (facebook birthdays) for my default calendar module. But my calendar wont show this at all. I have managed to show other ics files from local destination, so that part works. My fb2cal ics is successful imported into google calendar, so I guess the ICS is more or less OK. The ICS file is temporary uploaded to http://elitek.no/elicraft/birthdays.ics (no sensitive information, just a lot of birthdays for those who are interrested to congratulate any of them ;-) )
    I am running MM v2.9.0…
    S 1 Reply Last reply Oct 10, 2019, 11:12 AM Reply Quote 0
      sdetweil @aquaman
      @aquaman the calendar data looks fine…
      where on your local system did you place that file? it MUST be under the modules/default/calendar folder
      also, open the developers window, ctrl-shift-i, select the tab labeled ‘console’ and scroll up to see if there are any errors reported, usually red text
        aquaman
        Thank you for your reply.
        I have the ICS file under /MagicMirror/modules. I have also downloaded another ics-file named basic.ics (from google calendar) in same folder. basic.ics works just fine, but birthdays.ics is not. I have now also tried both files in /default/calendar with same result (basic.ics works, birthdays.ics not…)
        I cannot find any reported errors i developers window (console) about calendar at all…
        S 1 Reply Last reply Oct 10, 2019, 12:15 PM Reply Quote 0
          sdetweil @aquaman
          @aquaman after debugging, the problem is the file created by fb2ics has linux line ends (\n), but the code is looking for windows line ends (\r\n)
          once I edited and saved with windows line ends it works
          you could use unix2dos on it to convert the line ends
          I have opened an issue and submitted a pull request to the ical parser github project for this
          https://github.com/peterbraden/ical.js/issues/105
            aquaman
            Ahh.
            Thank you!
            I have tried unix2dos with newline option, but no luck yet. Seems that there are no changes in the file after running the command. Propably need some more help from google ;-)
            But thank you for your help so far :-)
            S 1 Reply Last reply Oct 10, 2019, 6:57 PM Reply Quote 0
              sdetweil @aquaman
              @aquaman you shouldn’t need to specify any options…
              just
              unix2dos filename
              it will convert in place
              or -ascii convert only line breaks (default)
              unix2dos -ascii filename
                aquaman
                Yes…
                Done that…
                Filesize is exactly same, however file date/time has been changed…
                S 1 Reply Last reply Oct 10, 2019, 7:30 PM Reply Quote 0
                  sdetweil @aquaman
                  @aquaman worked for me in both directions, no parm specified…
                  odroid@odroid:~/MagicMirror/modules/default/calendar$ unix2dos birthdays.ics
                  unix2dos: converting file birthdays.ics to DOS format...
                  and
                  odroid@odroid:~/MagicMirror/modules/default/calendar$ dos2unix birthdays.ics
                  dos2unix: converting file birthdays.ics to Unix format...
                  i then used Notepad++ to search for \r\n (windows) or \n (unix) linebreaks
                  found as expected
                    aquaman
                    Hmm… Starting to get embarrased ;-)
                    Can i provide you a ip an password on pm to log on?
                    S 1 Reply Last reply Oct 10, 2019, 8:06 PM Reply Quote 0
                      sdetweil @aquaman
                      @aquaman sure, come over to discord chat, i am sam #5710, if can’t do discord, then email … same userid as here but on gmail
                      yeh, or direct chat here… sorry, missed that
