    MMM-FlightsAbove - Display all flights in the sky above you
    20 Posts 8 Posters 13.9k Views 8 Watching
      Sun
      Thank you very much. I got it working. But I couldn’t see the Flight detail in full. I would like to see the flight in full. How to? Thank you very much in advance.
        bartleph
        Hi There,
        Is there a maximum width to the table as when I add extra fields others disappear I can see a max of only 8 or 9 depending on the width?
          bartleph @bartleph
          I have found out how to allow column resizing and that works great except that when trying to expand between Alt[m] and Model, the value of Alt[m] moves with the model heading instead of remaining stationary.
            Richard238 @Albert2002
              Richard238
              I’ve set Max Entries to 10, but I get loads of entries, why? Seems OK after a PM2 stop/start!
              How do I get rid of the scroll bars?
              How do I lose the footer/key? (I tried footerLegend: false in MMM-tabulator.js)
              My config.js:
              			module: 'MMM-FlightsAbove',
              			header: 'Flights Above',
              			position: 'top_center',
              				header: "Flights Above",          // The module header text, if any. Use: "" to remove.
              				compassHeading: true,             // Use a compass direction (NSWE) for the of heading indicator ("45" vs "NE")
              				updateInterval: 180,              // [s] Radar scan/ping/update period in secodns [default 3 min]
              				maxItems: 10,                     // MAX Number of planes to display [default is 10]
              				homeIata: "LGW",
              				// The geographical (map) Boundary-Box (BB), from within planes will be shown are given by:
              				// the maximim Lat/Lon edges of: [N-lat, W-lon, S-lat, E-lon] - all in decimal degrees.
              				radarBBox: [51.34985,-0.49832,50.95459,0.13182], // "DPS" (Bali Airport) [default]
              				//radarLocation: "51.10741,-0.15029",     // [Lat,Lon] - The location of radar center in decimal degrees
              				//radarRadius: 90,                // [km] - The maximum distance of planes shown.
              				//watchList: "",                  // Alert or Highlight planes/flights/types on this watch list
              I’m not worried about the compliments module being in the way just now.
                broberg Project Sponsor @Richard238
                @Richard238 said in MMM-FlightsAbove - Display all flights in the sky above you:
                MMM-FlightsAbove
                to your custom.css add :
                .MMM-FlightsAbove.tabulator-footer {visibility: hidden;}
                .MMM-FlightsAbove {overflow: hidden;}
                  Richard238 @broberg
                  @broberg
                  This…
                  .MMM-FlightsAbove .tabulator-footer {
                  	visibility: hidden;
                  …works just fine, thank you.
                  .MMM-FlightsAbove {
                  	width: 400px;
                  	overflow: hidden;
                  Worked when I added a width figure, the horizontal scroll bar is gone.
                  The vertical scroll bar however, remains.
                  I tired some height: nnnpx; figures, but still the pesky vertical bar is showing.
                    @Richard238
                    Then try
                    #flightsabove {overflow:hidden;}
                      Richard238
                      Tried, but the vertical scroll bar is still there.
                        Richard238
                        The vertical bar is only shown on Firefox or Edge, Chrome is OK, as is Electron on the Pi itself.
