how do i update my magic mirror
cd ~\MagicMirror git pull -
@Stoffbeuteluwe THANKS but dont work :
cd ~\MagicMirror
git pullthanks dude, i have another problem, i want to install a command voice but idont know whats is the error…
i check the config
Checking file… /home/pi/MagicMirror/config/config.js
Line 117 col 10 Expected ‘}’ to match ‘{’ from line 102 and instead saw ‘]’.
Line 118 col 6 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘;’.
Line 121 col 1 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘if’.
Line 121 col 4 Bad invocation.
Line 121 col 35 Missing semicolon.AND this are the line:
{ module: "MMM-Snow", position: "fullscreen_above", config: { // See 'Configuration options' for more information. flakeCount: 100, theme: "winter", } }, { module: "MMM-Voice-Commands", config: { debug: false, //Displays end results and errors from annyang in the Log autoStart: true, //Adds annyang commands when it first starts activateCommand: "hello mirror", //Command to active all other commands deactivateCommand: "goodbye mirror", //Command to deactivate all other commands alertHeard: false, //Whether an alert should be shown when annyang hears a phrase (mostly for debug) commands: { "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME", //The payload of the socket notification will be whatever is said in the :variable "command statement *variable": function(param){ < ---- start alert("Whatever is said in the *variable space is given as the "+param); //These function's 'this' are bound to the module's 'this' so you can do stuff like: this.sendNotification("PAGE_SELECT", "2"); } } ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@bjjsoul said in how do i update my magic mirror:
> { > module: "MMM-Snow", > position: "fullscreen_above", > config: { // See 'Configuration options' for more information. > flakeCount: 100, > theme: "winter", > } > }, > { < ---- start module > module: "MMM-Voice-Commands", > config: { < ---- start config > debug: false, //Displays end results and errors from annyang in the Log > autoStart: true, //Adds annyang commands when it first starts > activateCommand: "hello mirror", //Command to active all other commands > deactivateCommand: "goodbye mirror", //Command to deactivate all other commands > alertHeard: false, //Whether an alert should be shown when annyang hears a phrase (mostly for debug) > commands: { < --- start command > "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME", > //The payload of the socket notification will be whatever is said in the :variable > "command statement *variable": function(param){ < ---- start > alert("Whatever is said in the *variable space is given as the "+param); > //These function's 'this' are bound to the module's 'this' so you can do stuff like: > this.sendNotification("PAGE_SELECT", "2"); > } < --- end command > } < ---- end config > ] ???????? > }; > > /*************** DO NOT EDIT THE LINE BELOW ***************/ > if (typeof module !== "undefined") {module.exports = config;} -
@Stoffbeuteluwe please refer people to the new update script for updating the base.
https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
ERROR???¿?¿?? :( :(
magicmirror@2.8.0 start /home/pi/MagicMirror
sh run-start.shStarting MagicMirror: v2.8.0
Loading config …
WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:111
“command statement *variable”: function(param){ < ---- start
^SyntaxError: Unexpected token <
at new Script (vm.js:74:7)
at createScript (vm.js:246:10)
at Object.runInThisContext (vm.js:298:10)
at Module._compile (internal/modules/cjs/loader.js:678:28)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
at Module.load (internal/modules/cjs/loader.js:620:32)
at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
at Function.Module._load (internal/modules/cjs/loader.js:551:3)
at Module.require (internal/modules/cjs/loader.js:658:17)
at require (internal/modules/cjs/helpers.js:20:18) -
@bjjsoul U cannot just paste the code in. I am trying to teach you how to solve the problems.
All {} and [] must be matched in order
thank bro for your time, but i am copying and paste in the last line in the config file, but i dont know whats is my error
in this moment its looks like this:{ module: "MMM-Voice-Commands", config: { debug: false, //Displays end results and errors from annyang in the Log autoStart: true, //Adds annyang commands when it first starts activateCommand: "hello mirror", //Command to active all other commands deactivateCommand: "goodbye mirror", //Command to deactivate all other commands alertHeard: false, //Whether an alert should be shown when annyang hears a phrase (mostly for debug) commands: { "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME", //The payload of the socket notification will be whatever is said in the :variable "command statement *variable": function(param){ alert("Whatever is said in the *variable space is given as the "+param); //These function's 'this' are bound to the module's 'this' so you can do stuff like: this.sendNotification("PAGE_SELECT", "2"); } } }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
now is this faaak :(
Loading config …
WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:121
if (typeof module !== “undefined”) {module.exports = config;}
^^SyntaxError: Unexpected token if
at require (internal/modules/cjs/helpers.js:20:18)i dont know how find the line 121
i am very noob in this -
@bjjsoul, can you copy/past in here your entire config.js?
also when posting the code please click on the “</>” button to put in the code block.that way the code will be in a box like this one. -
come on man… you are missing a close brace } and a close bracket ]
start at the top of the new module you are adding and find the open braces { and match then with a close brace }
and then make sure that the confg.js modules section starts with a [ and ends with a ]
