    how do i update my magic mirror
    11 Posts 4 Posters 4.1k Views 4 Watching
    • bjjsoulB Offline
      bjjsoul
      @Stoffbeuteluwe THANKS but dont work :
      cd ~\MagicMirror
      git pull
      thanks dude, i have another problem, i want to install a command voice but idont know whats is the error…
      i check the config
      Checking file… /home/pi/MagicMirror/config/config.js
      Line 117 col 10 Expected ‘}’ to match ‘{’ from line 102 and instead saw ‘]’.
      Line 118 col 6 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘;’.
      Line 121 col 1 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘if’.
      Line 121 col 4 Bad invocation.
      Line 121 col 35 Missing semicolon.
      AND this are the line:
      		module: "MMM-Snow",
      		position: "fullscreen_above",
      		config: { // See 'Configuration options' for more information.
      			flakeCount: 100,
      			theme: "winter",
              module: "MMM-Voice-Commands",
                  debug: false, //Displays end results and errors from annyang in the Log
                  autoStart: true, //Adds annyang commands when it first starts
                  activateCommand: "hello mirror", //Command to active all other commands
                  deactivateCommand: "goodbye mirror", //Command to deactivate all other commands
                  alertHeard: false, //Whether an alert should be shown when annyang hears a phrase (mostly for debug)
                  commands: {
                      "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME",
                      //The payload of the socket notification will be whatever is said in the :variable
                      "command statement *variable": function(param){   < ----  start
                          alert("Whatever is said in the *variable space is given as the "+param);
                          //These function's 'this' are bound to the module's 'this' so you can do stuff like:
                          this.sendNotification("PAGE_SELECT", "2");
      S 1 Reply Last reply Reply Quote -1
        sdetweil @bjjsoul
        @bjjsoul said in how do i update my magic mirror:
        > 		module: "MMM-Snow",
        > 			flakeCount: 100,
        > 			theme: "winter",
        >          {   < ---- start module
        >         config: {   < ---- start  config
        >             commands: {  < --- start command
        >                 } < --- end command
        >             } < ---- end config
        > /*************** DO NOT EDIT THE LINE BELOW ***************/
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe please refer people to the new update script for updating the base.
          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
          • bjjsoulB Offline
            bjjsoul
            ERROR???¿?¿?? :( :(
            magicmirror@2.8.0 start /home/pi/MagicMirror
            sh run-start.sh
            Starting MagicMirror: v2.8.0
            Loading config …
            WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:111
            “command statement *variable”: function(param){ < ---- start
            SyntaxError: Unexpected token <
            at new Script (vm.js:74:7)
            at createScript (vm.js:246:10)
            at Object.runInThisContext (vm.js:298:10)
            at Module._compile (internal/modules/cjs/loader.js:678:28)
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
            at Module.load (internal/modules/cjs/loader.js:620:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
            at Function.Module._load (internal/modules/cjs/loader.js:551:3)
            at Module.require (internal/modules/cjs/loader.js:658:17)
            at require (internal/modules/cjs/helpers.js:20:18)
              sdetweil @bjjsoul
              @bjjsoul U cannot just paste the code in. I am trying to teach you how to solve the problems.
              All {} and [] must be matched in order
              • bjjsoulB Offline
                bjjsoul
                thank bro for your time, but i am copying and paste in the last line in the config file, but i dont know whats is my error
                in this moment its looks like this:
                             commands: {
                • bjjsoulB Offline
                  bjjsoul
                  now is this faaak :(
                  Loading config …
                  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:121
                  if (typeof module !== “undefined”) {module.exports = config;}
                  SyntaxError: Unexpected token if
                  i dont know how find the line 121
                  i am very noob in this
                    dwntwn87
                    @bjjsoul, can you copy/past in here your entire config.js?
                    also when posting the code please click on the “</>” button to put in the code block.
                    that way the code will be in a box like this one.
                      sdetweil @bjjsoul
                      come on man… you are missing a close brace } and a close bracket ]
                      start at the top of the new module you are adding and find the open braces { and match then with a close brace }
                      and then make sure that the confg.js modules section starts with a [ and ends with a ]
