    how do i update my magic mirror
    11 Posts 4 Posters 4.8k Views 4 Watching
    • bjjsoulB
      bjjsoul
      how i can update this?
      on my magic mirror appears on top one new update, but i dont know how to do it.0_1570946926790_WhatsApp Image 2019-10-07 at 9.50.47 AM.jpeg
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @bjjsoul
        @bjjsoul
        cd ~\MagicMirror
        git pull
        • bjjsoulB
          bjjsoul
          @Stoffbeuteluwe THANKS but dont work :
          cd ~\MagicMirror
          git pull
          thanks dude, i have another problem, i want to install a command voice but idont know whats is the error…
          i check the config
          Checking file… /home/pi/MagicMirror/config/config.js
          Line 117 col 10 Expected ‘}’ to match ‘{’ from line 102 and instead saw ‘]’.
          Line 118 col 6 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘;’.
          Line 121 col 1 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘if’.
          Line 121 col 4 Bad invocation.
          Line 121 col 35 Missing semicolon.
          AND this are the line:
          		module: "MMM-Snow",
          		position: "fullscreen_above",
          		config: { // See 'Configuration options' for more information.
          			flakeCount: 100,
          			theme: "winter",
                  module: "MMM-Voice-Commands",
                      debug: false, //Displays end results and errors from annyang in the Log
                      autoStart: true, //Adds annyang commands when it first starts
                      activateCommand: "hello mirror", //Command to active all other commands
                      deactivateCommand: "goodbye mirror", //Command to deactivate all other commands
                      alertHeard: false, //Whether an alert should be shown when annyang hears a phrase (mostly for debug)
                      commands: {
                          "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME",
                          //The payload of the socket notification will be whatever is said in the :variable
                          "command statement *variable": function(param){   < ----  start
                              alert("Whatever is said in the *variable space is given as the "+param);
                              //These function's 'this' are bound to the module's 'this' so you can do stuff like:
                              this.sendNotification("PAGE_SELECT", "2");
          S 1 Reply Last reply Reply Quote -1
            sdetweil @bjjsoul
            @bjjsoul said in how do i update my magic mirror:
            > 		module: "MMM-Snow",
            > 			flakeCount: 100,
            > 			theme: "winter",
            >          {   < ---- start module
            >         config: {   < ---- start  config
            >             commands: {  < --- start command
            >                 } < --- end command
            >             } < ---- end config
            > /*************** DO NOT EDIT THE LINE BELOW ***************/
              sdetweil @Stoffbeuteluwe
              @Stoffbeuteluwe please refer people to the new update script for updating the base.
              https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
              • bjjsoulB
                bjjsoul
                ERROR???¿?¿?? :( :(
                magicmirror@2.8.0 start /home/pi/MagicMirror
                sh run-start.sh
                Starting MagicMirror: v2.8.0
                Loading config …
                WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:111
                “command statement *variable”: function(param){ < ---- start
                SyntaxError: Unexpected token <
                at new Script (vm.js:74:7)
                at createScript (vm.js:246:10)
                at Object.runInThisContext (vm.js:298:10)
                at Module._compile (internal/modules/cjs/loader.js:678:28)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                at Module.load (internal/modules/cjs/loader.js:620:32)
                at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                at Module.require (internal/modules/cjs/loader.js:658:17)
                at require (internal/modules/cjs/helpers.js:20:18)
                  sdetweil @bjjsoul
                  @bjjsoul U cannot just paste the code in. I am trying to teach you how to solve the problems.
                  All {} and [] must be matched in order
                  • bjjsoulB
                    bjjsoul
                    thank bro for your time, but i am copying and paste in the last line in the config file, but i dont know whats is my error
                    in this moment its looks like this:
                                 commands: {
                    • bjjsoulB
                      bjjsoul
                      now is this faaak :(
                      Loading config …
                      WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:121
                      if (typeof module !== “undefined”) {module.exports = config;}
                      SyntaxError: Unexpected token if
                      i dont know how find the line 121
                      i am very noob in this
                        dwntwn87
                        @bjjsoul, can you copy/past in here your entire config.js?
                        also when posting the code please click on the “</>” button to put in the code block.
                        that way the code will be in a box like this one.
                          sdetweil @bjjsoul
                          come on man… you are missing a close brace } and a close bracket ]
                          start at the top of the new module you are adding and find the open braces { and match then with a close brace }
                          and then make sure that the confg.js modules section starts with a [ and ends with a ]
