    how do i update my magic mirror
    11 Posts 4 Posters 4.0k Views 4 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe please refer people to the new update script for updating the base.
      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
      • bjjsoulB Offline
        bjjsoul
        ERROR???¿?¿?? :( :(
        magicmirror@2.8.0 start /home/pi/MagicMirror
        sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config …
        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:111
        “command statement *variable”: function(param){ < ---- start
        SyntaxError: Unexpected token <
        at new Script (vm.js:74:7)
        at createScript (vm.js:246:10)
        at Object.runInThisContext (vm.js:298:10)
        at Module._compile (internal/modules/cjs/loader.js:678:28)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
        at Module.load (internal/modules/cjs/loader.js:620:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
        at Function.Module._load (internal/modules/cjs/loader.js:551:3)
        at Module.require (internal/modules/cjs/loader.js:658:17)
        at require (internal/modules/cjs/helpers.js:20:18)
          sdetweil @bjjsoul
          @bjjsoul U cannot just paste the code in. I am trying to teach you how to solve the problems.
          All {} and [] must be matched in order
          • bjjsoulB Offline
            bjjsoul
            thank bro for your time, but i am copying and paste in the last line in the config file, but i dont know whats is my error
            in this moment its looks like this:
                     module: "MMM-Voice-Commands",
                         debug: false, //Displays end results and errors from annyang in the Log
                        autoStart: true, //Adds annyang commands when it first starts
                         activateCommand: "hello mirror", //Command to active all other commands
                         deactivateCommand: "goodbye mirror", //Command to deactivate all other commands
                         alertHeard: false, //Whether an alert should be shown when annyang hears a phrase (mostly for debug)
                         commands: {
                             "command statement :variable (optional statement)": "SOCKET_NOTIFICATION_NAME",
                             //The payload of the socket notification will be whatever is said in the :variable
                             "command statement *variable": function(param){
                                alert("Whatever is said in the *variable space is given as the "+param);
                                 //These function's 'this' are bound to the module's 'this' so you can do stuff like:
                                 this.sendNotification("PAGE_SELECT", "2");
            • bjjsoulB Offline
              bjjsoul
              now is this faaak :(
              Loading config …
              WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:121
              if (typeof module !== “undefined”) {module.exports = config;}
              SyntaxError: Unexpected token if
              i dont know how find the line 121
              i am very noob in this
                dwntwn87
                @bjjsoul, can you copy/past in here your entire config.js?
                also when posting the code please click on the “</>” button to put in the code block.
                that way the code will be in a box like this one.
                  sdetweil @bjjsoul
                  @bjjsoul said in how do i update my magic mirror:
                  come on man… you are missing a close brace } and a close bracket ]
                  start at the top of the new module you are adding and find the open braces { and match then with a close brace }
                  and then make sure that the confg.js modules section starts with a [ and ends with a ]
