    Update to v2.9.0 fail
    48 Posts 3 Posters 21.6k Views 3 Watching
      sdetweil @bdream
      @bdream said in Update to v2.9.0 fail:
      upgrade.log is here from …force… no it isn’t.
      I can’t copy the 2738 lines in here.
      you can email it , same userid as here on gmail
      And what does this mean?
      on the package-lock.json… it is the same as the update… thus why it didn’t stop
      could edit it an add a space someplace
      the upgrade should have stopped at the package-lock.json file, just like before…
      but it didn’t… so I looked back at the 2.9.0 package being installed, and it has a package-lock.json file…
      so, the one now on the disk is the new one… and a git status will show it hasn’t changed…
      so, we could MAKE it be different, by using a text editor (like the one you use on the config.js file)
      and add 1 space character (hit the spacebar)
      and then save it… then it will be different
        bdream
        got u mail from me? I would send you logs then.
        @sdetweil said in Update to v2.9.0 fail:
        Is this you ask me to do? and rund your script again to see if it works now?
        cheers, bdream
          sdetweil @bdream
          @bdream i got one mail and replied. have not got any more
          yes, was a way to test. if u can
            bdream
            if u can
            Got it
            Upgrade started - Mi Okt 16 20:03:22 CEST 2019
            user requested to apply changes
            doing test run = false
            saving custom.css
            not english or locale not set, set git alias
            alias egrep='egrep --color=auto'
            alias fgrep='fgrep --color=auto'
            alias git='LC_ALL=en_US.UTF-8 git'
            alias grep='grep --color=auto'
            alias ls='ls --color=auto'
            remote name = origin
            local version 2.9.0 already same as master 2.9.0
            restoring custom.css
            removing git alias
            Upgrade ended - Mi Okt 16 20:03:22 CEST 2019
            there is no statement about the package-lock.json where I added spaces and saved it.
            Seems it works fine :grinning_face_with_smiling_eyes:
            One question I have now.
            Would it make sense changing the guide for update MM using your script instead of git pull && npm install?
            Or is this only a option in case of failure?
            cheers, bdream
              sdetweil @bdream
              if you do apply, then if the versions are the same, it just exits… if you use force then it keeps going…
              try with force instead of apply
              … once we get this tested I will submit to add to the product… u are helping me test… and I thank you very much!!
              i have 3 scripts.
              1 updated installer
              2 new updater
              3 one for fixing pm2 without having to do installer
              will submit them all
                bdream
                Interesting. Now I get 2 package-lock.json listed…
                pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                saving custom.css
                upgrading from version 2.9.0 to 2.9.0
                fetching latest revisions
                there are 2 local files that are different than the master repo
                   package-lock.json
                   vendor/package-lock.json
                any *-lock.json files do not need to be saved
                do you want to save these files for later   (Y/n)?y
                git: 'git_user_name' ist kein Git-Befehl. Siehe 'git --help'.
                > magicmirror@2.9.0 install /home/pi/MagicMirror
                > cd vendor && npm install
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                audited 220 packages in 23.225s
                found 5 vulnerabilities (4 low, 1 high)
                  run `npm audit fix` to fix them, or `npm audit` for details
                > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                MagicMirror installation successful!
                > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                > cd fonts && npm install
                audited 1 package in 0.999s
                found 0 vulnerabilities
                npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                audited 3475 packages in 88.305s
                found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                processing for module MMM-Carousel please wait
                audited 859 packages in 16.958s
                found 2 high severity vulnerabilities
                processing complete for module MMM-Carousel
                processing for module MMM-PublicTransportHafas please wait
                audited 41 packages in 2.814s
                processing complete for module MMM-PublicTransportHafas
                audited 41 packages in 3.741s
                audited 41 packages in 3.333s
                we stashed a set of files that appear changed from the latest repo versions. you should review them
                Keine Stash-Einträge gefunden.
                see installers/stashed_files for the list
                you can use git checkout stash@{0} -- filename to extract one file from the stash
                or git stash pop to restore them all
                WARNING..
                WARNING.. either will overlay the file just installed by the update
                WARNING..
                and the log:
                Upgrade started - Mi Okt 16 20:15:10 CEST 2019
                user requested to force apply changes
                saving custom.css
                current branch = master
                Auf Branch master
                Ihr Branch ist auf demselben Stand wie 'origin/master'.
                Zum Commit vorgemerkte Änderungen:
                  (benutzen Sie "git reset HEAD <Datei>..." zum Entfernen aus der Staging-Area)
                	gelöscht:       css/custom.css
                Änderungen, die nicht zum Commit vorgemerkt sind:
                  (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                  (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                	geändert:       package-lock.json
                	geändert:       vendor/package-lock.json
                Unversionierte Dateien:
                	%logfile
                	core
                	css/save_custom.css
                	installers/dumpactivemodules.js
                	installers/pm2_MagicMirror_new.json
                	mm.sh
                	nohup.out
                   package-lock.json
                save/restore files selection = y
                test merge result rc='' , if empty, no conflicts
                executing merge, apply specified
                merge result rc= 0
                 Already up to date.
                processor architecture is armv7l
                removing git alias
                Upgrade ended - Mi Okt 16 20:17:37 CEST 2019
                cheers, bdream
                  sdetweil @bdream
                  @bdream cool… don’t know why we got the german there… issued same command back to back, one to log, one to script…
                  log one came out in german
                  script one came out in english
                  fixed a bug, which should have said
                  any *-lock.json files do not need to be saved"
                  that is all u had, so you would have selected n, instead of y
                    bdream
                    Sorry, is this I have to run script again and select n instead of yes?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream if you have edited the package-lock.json file
                        bdream
                        reedited and run script
                        saving custom.css
                           package-lock.json
                        do you want to save these files for later   (Y/n)?n
                        audited 220 packages in 13.98s
                        audited 1 package in 1.385s
                        updated 1 package and audited 3475 packages in 106.649s
                        audited 859 packages in 13.644s
                        audited 41 packages in 3.408s
                        audited 41 packages in 2.67s
                        audited 41 packages in 3.904s
                        upgrade.log
                        Upgrade started - Mi Okt 16 22:11:36 CEST 2019
                        saving custom.css
                        Auf Branch master
                        	%logfile
                        	core
                        	css/save_custom.css
                        	installers/upgrade.log.bak2
                        	mm.sh
                        	nohup.out
                           package-lock.json
                        save/restore files selection = n
                        restoring package-lock.json from repo
                        restoring vendor/package-lock.json from repo
                        merge result rc= 0
                         Already up to date.
                        removing git alias
                        Upgrade ended - Mi Okt 16 22:14:11 CEST 2019
                        do I need to akt in any way here or other point?
                        cheers, bdream
                          sdetweil @bdream
                          @bdream thank you for your help and patience… all looks great!!
                          no, you do not need to do anything about the last two entries.
                            bdream
                            so we are done and I set post to solved.
                            Many thanks for your great help and patience with this newbe-stuff :smiling_face_with_sunglasses:
                            cheers, bdream
                              sdetweil @bdream
                              you are welcome… and why I want to make these scripts solid
                              • F Offline
                                fiaskogaul
                                Is the Link dead? I get 404 or when I execute the script “Syntaxfehler beim unerwarteten Wort `newline’”
                                  sdetweil @fiaskogaul
                                  @fiaskogaul which link?
                                  see this topic for the current link for update
                                  https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                                  • 3 / 3
