Solved Update to v2.9.0 fail
As I get informed about new update available on my MagicMirror² I tried
git pull && npm install
and got
Aktualisiere a31546b..500147e error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch
Sorry for german error message :winking_face: which mean I have to commit my? changes on package-lock.json
I don’t know what and how and even why :face_screaming_in_fear:
I have no clue about any change I made on package-lock.json@sdetweil I saw your post link text but don’t know if this is for Raspberry alsow and if I should try this.
I’m a little afraid killing my installation.
@bdream u should use my script…
instructions here
https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
I tried u script but get further message update available even I restarted mm
pm2 start mm
the upgrade log here
Upgrade started - Mi Okt 16 14:38:38 CEST 2019 doing test run = true downloading dumpactivemodules script saving custom.css not english or locale not set, set git alias remote name = origin upgrading from version 2.8.0 to 2.9.0 fetching latest revisions current branch = master no files different from github version test merge result rc='' , if empty, no conflicts skipping merge, only test run processing dependency changes for active modules with package.json files processing for module MMM-Carousel please wait ---------------------------------- skipped processing for MMM-Carousel, doing test run processing complete for module MMM-Carousel processing for module MMM-PublicTransportHafas please wait ---------------------------------- skipped processing for MMM-PublicTransportHafas, doing test run processing complete for module MMM-PublicTransportHafas processing for module MMM-PublicTransportHafas please wait ---------------------------------- skipped processing for MMM-PublicTransportHafas, doing test run processing complete for module MMM-PublicTransportHafas processing for module MMM-PublicTransportHafas please wait ---------------------------------- skipped processing for MMM-PublicTransportHafas, doing test run processing complete for module MMM-PublicTransportHafas restoring custom.css removing git alias Upgrade ended - Mi Okt 16 14:38:45 CEST 2019 Upgrade started - Mi Okt 16 14:41:56 CEST 2019 user requested to apply changes doing test run = false saving custom.css not english or locale not set, set git alias remote name = origin upgrading from version 2.8.0 to 2.9.0 fetching latest revisions current branch = master no files different from github version test merge result rc='' , if empty, no conflicts executing merge, apply specified merge result rc= 1 error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e there were merge errors you should examine and resolve them using the command git log --oneline --decorate a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop restoring custom.css removing git alias Upgrade ended - Mi Okt 16 14:41:58 CEST 2019
@bdream fun… can u show me the results of
alias git='LANGUAGE=en_US.UTF-8 git' git status unalias git >/dev/null
thanks…
I had also changed the messaging to english… surprised at the german message…
@sdetweil seems there is a deeper problem!?!
pi@MagicMirror:~ $ git status fatal: not a git repository (or any of the parent directories): .git
what does this mean please?
@bdream u need to be in the MagicMirror folder to do those commands
i set an alias for git to use english messages
then execute a git command, with english output
then remove the alias, so back to your configured language -
@sdetweil SORRY!
pi@MagicMirror:~/MagicMirror $ git status On branch master Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded. (use "git pull" to update your local branch) Changes not staged for commit: (use "git add <file>..." to update what will be committed) (use "git checkout -- <file>..." to discard changes in working directory) modified: css/custom.css modified: package-lock.json Untracked files: (use "git add <file>..." to include in what will be committed) core installers/dumpactivemodules.js installers/pm2_MagicMirror_new.json mm.sh nohup.out no changes added to commit (use "git add" and/or "git commit -a")
@bdream weird… says code should handle it
try this
alias alias git='LANGUAGE=en_US.UTF-8 git' git status | grep modified | awk -F: '{print $2}' unalias git >/dev/null
thanks
pi@MagicMirror:~/MagicMirror $ alias alias egrep='egrep --color=auto' alias fgrep='fgrep --color=auto' alias git='LANGUAGE=en_US.UTF-8 git' alias grep='grep --color=auto' alias ls='ls --color=auto' pi@MagicMirror:~/MagicMirror $ alias git='LANGUAGE=en_US.UTF-8 git' pi@MagicMirror:~/MagicMirror $ git status | grep modified | awk -F: '{print $2}' css/custom.css package-lock.json pi@MagicMirror:~/MagicMirror $ unalias git >/dev/null
@bdream weird…
can u try the script again? i am recording the output of the git status command, manually it detects the file
