    Update to v2.9.0 fail
    48 Posts 3 Posters 18.1k Views 3 Watching
      bdream
      @sdetweil seems there is a deeper problem!?!
      pi@MagicMirror:~ $ git status
      fatal: not a git repository (or any of the parent directories): .git
      what does this mean please?
      unalias git >/dev/null
      cheers, bdream
        sdetweil @bdream
        @bdream u need to be in the MagicMirror folder to do those commands
        i set an alias for git to use english messages
        then execute a git command, with english output
        then remove the alias, so back to your configured language
          bdream
          @sdetweil SORRY!
          pi@MagicMirror:~/MagicMirror $  git status
          On branch master
          Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded.
            (use "git pull" to update your local branch)
            (use "git add <file>..." to update what will be committed)
            (use "git checkout -- <file>..." to discard changes in working directory)
                  modified:   css/custom.css
                  modified:   package-lock.json
          Untracked files:
            (use "git add <file>..." to include in what will be committed)
                  core
                  installers/dumpactivemodules.js
                  installers/pm2_MagicMirror_new.json
                  mm.sh
                  nohup.out
          no changes added to commit (use "git add" and/or "git commit -a")
          cheers, bdream
            sdetweil @bdream
            @bdream weird… says code should handle it
            try this
            alias
            alias git='LANGUAGE=en_US.UTF-8 git'
            git status | grep modified | awk -F: '{print $2}'
            thanks
              bdream
              pi@MagicMirror:~/MagicMirror $  alias
              alias egrep='egrep --color=auto'
              alias fgrep='fgrep --color=auto'
              alias grep='grep --color=auto'
              alias ls='ls --color=auto'
              pi@MagicMirror:~/MagicMirror $  alias git='LANGUAGE=en_US.UTF-8 git'
              pi@MagicMirror:~/MagicMirror $  git status | grep modified | awk -F: '{print $2}'
                 css/custom.css
                 package-lock.json
              pi@MagicMirror:~/MagicMirror $  unalias git >/dev/null
              cheers, bdream
                sdetweil @bdream
                @bdream weird…
                can u try the script again? i am recording the output of the git status command, manually it detects the file
                  bdream
                  pi@MagicMirror:~/MagicMirror $   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                  doing test run = false
                  saving custom.css
                  upgrading from version 2.8.0 to 2.9.0
                  fetching latest revisions
                  there were merge errors
                  you should examine and resolve them
                  using the command git log --oneline --decorate
                  a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
                  restoring custom.css
                  cheers, bdream
                    sdetweil @bdream
                    @bdream can u show me the log again
                      bdream
                      Upgrade started - Mi Okt 16 15:22:29 CEST 2019
                      user requested to apply changes
                      saving custom.css
                      not english or locale not set, set git alias
                      remote name = origin
                      current branch = master
                      no files different from github version
                      test merge result rc='' , if empty, no conflicts
                      executing merge, apply specified
                      merge result rc= 1
                       error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
                      removing git alias
                      Upgrade ended - Mi Okt 16 15:22:31 CEST 2019
                      cheers, bdream
                        sdetweil @bdream
                        @bdream said in Update to v2.9.0 fail:
                        there is supposed to be output from the git status command right there ???
                        I just made another tiny log reporting change… one more time please
                        • 1 / 5
