    Update to v2.9.0 fail
    48 Posts 3 Posters 18.3k Views 3 Watching
      sdetweil @bdream
      @bdream u need to be in the MagicMirror folder to do those commands
      i set an alias for git to use english messages
      then execute a git command, with english output
      then remove the alias, so back to your configured language
        bdream
        @sdetweil SORRY!
        pi@MagicMirror:~/MagicMirror $  git status
        On branch master
        Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded.
          (use "git pull" to update your local branch)
          (use "git add <file>..." to update what will be committed)
          (use "git checkout -- <file>..." to discard changes in working directory)
                modified:   css/custom.css
                modified:   package-lock.json
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
                core
                installers/dumpactivemodules.js
                installers/pm2_MagicMirror_new.json
                mm.sh
                nohup.out
        no changes added to commit (use "git add" and/or "git commit -a")
        cheers, bdream
          sdetweil @bdream
          @bdream weird… says code should handle it
          try this
          alias
          alias git='LANGUAGE=en_US.UTF-8 git'
          git status | grep modified | awk -F: '{print $2}'
          unalias git >/dev/null
          thanks
            bdream
            pi@MagicMirror:~/MagicMirror $  alias
            alias egrep='egrep --color=auto'
            alias fgrep='fgrep --color=auto'
            alias grep='grep --color=auto'
            alias ls='ls --color=auto'
            pi@MagicMirror:~/MagicMirror $  alias git='LANGUAGE=en_US.UTF-8 git'
            pi@MagicMirror:~/MagicMirror $  git status | grep modified | awk -F: '{print $2}'
               css/custom.css
               package-lock.json
            pi@MagicMirror:~/MagicMirror $  unalias git >/dev/null
            cheers, bdream
              sdetweil @bdream
              @bdream weird…
              can u try the script again? i am recording the output of the git status command, manually it detects the file
                bdream
                pi@MagicMirror:~/MagicMirror $   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                doing test run = false
                saving custom.css
                upgrading from version 2.8.0 to 2.9.0
                fetching latest revisions
                there were merge errors
                you should examine and resolve them
                using the command git log --oneline --decorate
                a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
                restoring custom.css
                cheers, bdream
                  sdetweil @bdream
                  @bdream can u show me the log again
                    bdream
                    Upgrade started - Mi Okt 16 15:22:29 CEST 2019
                    user requested to apply changes
                    saving custom.css
                    not english or locale not set, set git alias
                    remote name = origin
                    current branch = master
                    no files different from github version
                    test merge result rc='' , if empty, no conflicts
                    executing merge, apply specified
                    merge result rc= 1
                     error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
                    removing git alias
                    Upgrade ended - Mi Okt 16 15:22:31 CEST 2019
                    cheers, bdream
                      sdetweil @bdream
                      @bdream said in Update to v2.9.0 fail:
                      there is supposed to be output from the git status command right there ???
                      I just made another tiny log reporting change… one more time please
                        bdream
                        saving custom.css
                        Upgrade started - Mi Okt 16 15:31:26 CEST 2019
                        saving custom.css
                        Auf Branch master
                        Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden.
                          (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                        Änderungen, die nicht zum Commit vorgemerkt sind:
                          (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                          (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                        	geändert:       css/custom.css
                        	geändert:       package-lock.json
                        Unversionierte Dateien:
                        	core
                        	css/save_custom.css
                        	mm.sh
                        	nohup.out
                        keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
                        merge result rc= 1
                        removing git alias
                        Upgrade ended - Mi Okt 16 15:31:29 CEST 2019
                        I’m sorry for german within the log :unamused_face:
                        cheers, bdream
                          sdetweil @bdream
                          that will do it… i search for english ‘modified’, but its not there…
                          ok, one more time… another reporting change
                            bdream
                            Upgrade started - Mi Okt 16 15:38:04 CEST 2019
                            saving custom.css
                            Auf Branch master
                            	%logfile
                            	core
                            	css/save_custom.css
                            	mm.sh
                            	nohup.out
                            merge result rc= 1
                            removing git alias
                            Upgrade ended - Mi Okt 16 15:38:06 CEST 2019
                            cheers, bdream
                              sdetweil @bdream
                              @bdream cool… do this
                              shopt | grep expand
                              should see this
                              expand_aliases  on
                              I bet you see this
                              expand_aliases  off
                                bdream
                                @sdetweil said in Update to v2.9.0 fail:
                                I bet you see this
                                expand_aliases off
                                pi@MagicMirror:~/MagicMirror $   shopt | grep expand
                                assoc_expand_once       off
                                direxpand       off
                                expand_aliases  on
                                cheers, bdream
                                  sdetweil @bdream
                                  expand_aliases on
                                  yeh, but it didn’t!!
                                  try script again
                                    bdream
                                    try script again
                                    saving custom.css
                                    there are 2 local files that are different than the master repo
                                       css/custom.css
                                       package-lock.json
                                    any *-lock.json files do not need to be saved
                                    do you want to save these files for later   (Y/n)?Y
                                    *** Bitte geben Sie an, wer Sie sind.
                                    Führen Sie
                                      git config --global user.email "you@example.com"
                                      git config --global user.name "Your Name"
                                    aus, um das als Ihre standardmäßige Identität zu setzen.
                                    Lassen Sie die Option "--global" weg, um die Identität nur
                                    für dieses Repository zu setzen.
                                    fatal: Konnte die E-Mail-Adresse nicht automatisch erkennen ('pi@MagicMirror.(none)' erhalten)
                                    Kann den aktuellen Zustand des Index nicht speichern
                                    error: Your local changes to the following files would be overwritten by merge:         package-lock.json Please commit your changes or stash them before you merge. Aborting Updating a31546b..500147e
                                    we stashed a set of files that appear changed from the latest repo versions. you should review them
                                    Keine Stash-Einträge gefunden.
                                    see installers/stashed_files for the list
                                    you can use git checkout stash@{0} -- filename to extract one file from the stash
                                    or git stash pop to restore them all
                                    WARNING..
                                    WARNING.. either will overlay the file just installed by the update
                                    WARNING..
                                    custom.css is realy touched by me but should not be affected by updates I thougt.
                                    Führen Sie
                                    that says about the git configuration is not correct. But I never configured git on the Pi. Do I need to do?
                                    The fatal is about the e-mail was not to get detected automaticly. For sure there was never a e-mail configured for nothing at the Pi.
                                    Index can not be saved.
                                    Says 'no Stash-entries were found. whatever that mens.
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream hang on…
                                        @sdetweil try this, note just adding another parm
                                        bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                                        also show results of, notice dot in front of filename
                                        cat ~/.bashrc
                                          sdetweil @bdream
                                          prior to this release, custom.css was considered a core file, and was overlayed on updates.
                                          this release puts in a fix for that… but I save/restore it anyhow
                                          stash is a place where you can hold modified files, but continue on with your work.
                                          it requires some setup, but my script is supposed to go that for you
                                            bdream
                                            pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                                            saving custom.css
                                            upgrade.log
                                            Upgrade started - Mi Okt 16 17:12:12 CEST 2019
                                            saving custom.css
                                            Auf Branch master
                                            	%logfile
                                            	core
                                            	css/save_custom.css
                                            	mm.sh
                                            	nohup.out
                                            merge result rc= 1
                                            removing git alias
                                            Upgrade ended - Mi Okt 16 17:12:14 CEST 2019
                                            pi@MagicMirror:~/MagicMirror $  cat ~/.bashrc
                                            # ~/.bashrc: executed by bash(1) for non-login shells.
                                            # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
                                            # for examples
                                            # If not running interactively, don't do anything
                                            case $- in
                                                *i*) ;;
                                                  *) return;;
                                            esac
                                            # don't put duplicate lines or lines starting with space in the history.
                                            # See bash(1) for more options
                                            HISTCONTROL=ignoreboth
                                            # append to the history file, don't overwrite it
                                            shopt -s histappend
                                            # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
                                            HISTSIZE=1000
                                            HISTFILESIZE=2000
                                            # check the window size after each command and, if necessary,
                                            # update the values of LINES and COLUMNS.
                                            shopt -s checkwinsize
                                            # If set, the pattern "**" used in a pathname expansion context will
                                            # match all files and zero or more directories and subdirectories.
                                            #shopt -s globstar
                                            # make less more friendly for non-text input files, see lesspipe(1)
                                            #[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
                                            # set variable identifying the chroot you work in (used in the prompt below)
                                            if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
                                                debian_chroot=$(cat /etc/debian_chroot)
                                            fi
                                            # set a fancy prompt (non-color, unless we know we "want" color)
                                            case "$TERM" in
                                                xterm-color|*-256color) color_prompt=yes;;
                                            esac
                                            # uncomment for a colored prompt, if the terminal has the capability; turned
                                            # off by default to not distract the user: the focus in a terminal window
                                            # should be on the output of commands, not on the prompt
                                            force_color_prompt=yes
                                            if [ -n "$force_color_prompt" ]; then
                                                if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
                                                    # We have color support; assume it's compliant with Ecma-48
                                                    # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
                                                    # a case would tend to support setf rather than setaf.)
                                                    color_prompt=yes
                                                else
                                                    color_prompt=
                                                fi
                                            fi
                                            if [ "$color_prompt" = yes ]; then
                                                PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w \$\[\033[00m\] '
                                            else
                                                PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
                                            fi
                                            unset color_prompt force_color_prompt
                                            # If this is an xterm set the title to user@host:dir
                                            case "$TERM" in
                                            xterm*|rxvt*)
                                                PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
                                            esac
                                            # enable color support of ls and also add handy aliases
                                            if [ -x /usr/bin/dircolors ]; then
                                                test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
                                                #alias dir='dir --color=auto'
                                                #alias vdir='vdir --color=auto'
                                            fi
                                            # colored GCC warnings and errors
                                            #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
                                            # some more ls aliases
                                            #alias ll='ls -l'
                                            #alias la='ls -A'
                                            #alias l='ls -CF'
                                            # Alias definitions.
                                            # You may want to put all your additions into a separate file like
                                            # ~/.bash_aliases, instead of adding them here directly.
                                            # See /usr/share/doc/bash-doc/examples in the bash-doc package.
                                            if [ -f ~/.bash_aliases ]; then
                                                . ~/.bash_aliases
                                            fi
                                            # enable programmable completion features (you don't need to enable
                                            # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
                                            # sources /etc/bash.bashrc).
                                            if ! shopt -oq posix; then
                                              if [ -f /usr/share/bash-completion/bash_completion ]; then
                                                . /usr/share/bash-completion/bash_completion
                                              elif [ -f /etc/bash_completion ]; then
                                                . /etc/bash_completion
                                              fi
                                            fi
                                            cheers, bdream
