    Update to v2.9.0 fail
    48 Posts 3 Posters 22.3k Views 3 Watching
      bdream
      I tried u script but get further message update available even I restarted mm
      pm2 start mm
      the upgrade log here
      Upgrade started - Mi Okt 16 14:38:38 CEST 2019
      doing test run = true
      downloading dumpactivemodules script
      saving custom.css
      not english or locale not set, set git alias
      remote name = origin
      upgrading from version 2.8.0 to 2.9.0
      fetching latest revisions
      current branch = master
      no files different from github version
      test merge result rc='' , if empty, no conflicts
      skipping merge, only test run
      processing for module MMM-Carousel please wait
      skipped processing for MMM-Carousel, doing test run
      processing complete for module MMM-Carousel
      processing for module MMM-PublicTransportHafas please wait
      skipped processing for MMM-PublicTransportHafas, doing test run
      processing complete for module MMM-PublicTransportHafas
      restoring custom.css
      removing git alias
      Upgrade ended - Mi Okt 16 14:38:45 CEST 2019
      Upgrade started - Mi Okt 16 14:41:56 CEST 2019
      user requested to apply changes
      doing test run = false
      saving custom.css
      executing merge, apply specified
      merge result rc= 1
       error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
      there were merge errors
      you should examine and resolve them
      using the command git log --oneline --decorate
      a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
      removing git alias
      Upgrade ended - Mi Okt 16 14:41:58 CEST 2019
      cheers, bdream
        sdetweil @bdream
        @bdream fun… can u show me the results of
        alias git='LANGUAGE=en_US.UTF-8 git'
        git status
        unalias git >/dev/null
        thanks…
        I had also changed the messaging to english… surprised at the german message…
          bdream
          @sdetweil seems there is a deeper problem!?!
          pi@MagicMirror:~ $ git status
          fatal: not a git repository (or any of the parent directories): .git
          what does this mean please?
          cheers, bdream
            sdetweil @bdream
            @bdream u need to be in the MagicMirror folder to do those commands
            i set an alias for git to use english messages
            then execute a git command, with english output
            then remove the alias, so back to your configured language
              bdream
              @sdetweil SORRY!
              pi@MagicMirror:~/MagicMirror $  git status
              On branch master
              Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded.
                (use "git pull" to update your local branch)
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
                      modified:   css/custom.css
                      modified:   package-lock.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
                      core
                      installers/dumpactivemodules.js
                      installers/pm2_MagicMirror_new.json
                      mm.sh
                      nohup.out
              no changes added to commit (use "git add" and/or "git commit -a")
              cheers, bdream
                sdetweil @bdream
                @bdream weird… says code should handle it
                try this
                alias
                git status | grep modified | awk -F: '{print $2}'
                thanks
                  bdream
                  pi@MagicMirror:~/MagicMirror $  alias
                  alias egrep='egrep --color=auto'
                  alias fgrep='fgrep --color=auto'
                  alias grep='grep --color=auto'
                  alias ls='ls --color=auto'
                  pi@MagicMirror:~/MagicMirror $  alias git='LANGUAGE=en_US.UTF-8 git'
                  pi@MagicMirror:~/MagicMirror $  git status | grep modified | awk -F: '{print $2}'
                     css/custom.css
                     package-lock.json
                  pi@MagicMirror:~/MagicMirror $  unalias git >/dev/null
                  cheers, bdream
                    sdetweil @bdream
                    @bdream weird…
                    can u try the script again? i am recording the output of the git status command, manually it detects the file
                      bdream
                      pi@MagicMirror:~/MagicMirror $   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                      saving custom.css
                      cheers, bdream
                        sdetweil @bdream
                        @bdream can u show me the log again
                          bdream
                          Upgrade started - Mi Okt 16 15:22:29 CEST 2019
                          saving custom.css
                          merge result rc= 1
                          removing git alias
                          Upgrade ended - Mi Okt 16 15:22:31 CEST 2019
                          cheers, bdream
                            sdetweil @bdream
                            @bdream said in Update to v2.9.0 fail:
                            there is supposed to be output from the git status command right there ???
                            I just made another tiny log reporting change… one more time please
                              bdream
                              saving custom.css
                              Upgrade started - Mi Okt 16 15:31:26 CEST 2019
                              saving custom.css
                              Auf Branch master
                              Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden.
                                (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                              Änderungen, die nicht zum Commit vorgemerkt sind:
                                (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                                (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                              	geändert:       css/custom.css
                              	geändert:       package-lock.json
                              Unversionierte Dateien:
                              	core
                              	css/save_custom.css
                              	mm.sh
                              	nohup.out
                              keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
                              merge result rc= 1
                              removing git alias
                              Upgrade ended - Mi Okt 16 15:31:29 CEST 2019
                              I’m sorry for german within the log :unamused_face:
                              cheers, bdream
                                sdetweil @bdream
                                that will do it… i search for english ‘modified’, but its not there…
                                ok, one more time… another reporting change
                                  bdream
                                  Upgrade started - Mi Okt 16 15:38:04 CEST 2019
                                  saving custom.css
                                  Auf Branch master
                                  	%logfile
                                  	core
                                  	css/save_custom.css
                                  	mm.sh
                                  	nohup.out
                                  merge result rc= 1
                                  removing git alias
                                  Upgrade ended - Mi Okt 16 15:38:06 CEST 2019
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream cool… do this
                                    shopt | grep expand
                                    should see this
                                    expand_aliases  on
                                    I bet you see this
                                    expand_aliases  off
                                      bdream
                                      @sdetweil said in Update to v2.9.0 fail:
                                      I bet you see this
                                      expand_aliases off
                                      pi@MagicMirror:~/MagicMirror $   shopt | grep expand
                                      assoc_expand_once       off
                                      direxpand       off
                                      expand_aliases  on
                                      cheers, bdream
                                        sdetweil @bdream
                                        expand_aliases on
                                        yeh, but it didn’t!!
                                        try script again
                                          bdream
                                          try script again
                                          saving custom.css
                                          there are 2 local files that are different than the master repo
                                             css/custom.css
                                             package-lock.json
                                          any *-lock.json files do not need to be saved
                                          do you want to save these files for later   (Y/n)?Y
                                          *** Bitte geben Sie an, wer Sie sind.
                                          Führen Sie
                                            git config --global user.email "you@example.com"
                                            git config --global user.name "Your Name"
                                          aus, um das als Ihre standardmäßige Identität zu setzen.
                                          Lassen Sie die Option "--global" weg, um die Identität nur
                                          für dieses Repository zu setzen.
                                          fatal: Konnte die E-Mail-Adresse nicht automatisch erkennen ('pi@MagicMirror.(none)' erhalten)
                                          Kann den aktuellen Zustand des Index nicht speichern
                                          error: Your local changes to the following files would be overwritten by merge:         package-lock.json Please commit your changes or stash them before you merge. Aborting Updating a31546b..500147e
                                          we stashed a set of files that appear changed from the latest repo versions. you should review them
                                          Keine Stash-Einträge gefunden.
                                          see installers/stashed_files for the list
                                          you can use git checkout stash@{0} -- filename to extract one file from the stash
                                          or git stash pop to restore them all
                                          WARNING..
                                          WARNING.. either will overlay the file just installed by the update
                                          WARNING..
                                          custom.css is realy touched by me but should not be affected by updates I thougt.
                                          Führen Sie
                                          that says about the git configuration is not correct. But I never configured git on the Pi. Do I need to do?
                                          The fatal is about the e-mail was not to get detected automaticly. For sure there was never a e-mail configured for nothing at the Pi.
                                          Index can not be saved.
                                          Says 'no Stash-entries were found. whatever that mens.
                                          cheers, bdream
                                          S 2 Replies Last reply
                                            sdetweil @bdream
                                            @bdream hang on…
