    Update to v2.9.0 fail
    48 Posts 3 Posters 22.3k Views 3 Watching
      sdetweil @bdream
      @bdream u should use my script…
      instructions here
      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
        bdream
        I tried u script but get further message update available even I restarted mm
        pm2 start mm
        the upgrade log here
        Upgrade started - Mi Okt 16 14:38:38 CEST 2019
        doing test run = true
        downloading dumpactivemodules script
        saving custom.css
        not english or locale not set, set git alias
        remote name = origin
        upgrading from version 2.8.0 to 2.9.0
        fetching latest revisions
        current branch = master
        no files different from github version
        test merge result rc='' , if empty, no conflicts
        skipping merge, only test run
        processing for module MMM-Carousel please wait
        skipped processing for MMM-Carousel, doing test run
        processing complete for module MMM-Carousel
        processing for module MMM-PublicTransportHafas please wait
        skipped processing for MMM-PublicTransportHafas, doing test run
        processing complete for module MMM-PublicTransportHafas
        restoring custom.css
        removing git alias
        Upgrade ended - Mi Okt 16 14:38:45 CEST 2019
        Upgrade started - Mi Okt 16 14:41:56 CEST 2019
        user requested to apply changes
        doing test run = false
        saving custom.css
        executing merge, apply specified
        merge result rc= 1
         error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
        there were merge errors
        you should examine and resolve them
        using the command git log --oneline --decorate
        a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
        removing git alias
        Upgrade ended - Mi Okt 16 14:41:58 CEST 2019
        cheers, bdream
          sdetweil @bdream
          @bdream fun… can u show me the results of
          alias git='LANGUAGE=en_US.UTF-8 git'
          git status
          unalias git >/dev/null
          thanks…
          I had also changed the messaging to english… surprised at the german message…
            bdream
            @sdetweil seems there is a deeper problem!?!
            pi@MagicMirror:~ $ git status
            fatal: not a git repository (or any of the parent directories): .git
            what does this mean please?
            cheers, bdream
              sdetweil @bdream
              @bdream u need to be in the MagicMirror folder to do those commands
              i set an alias for git to use english messages
              then execute a git command, with english output
              then remove the alias, so back to your configured language
                bdream
                @sdetweil SORRY!
                pi@MagicMirror:~/MagicMirror $  git status
                On branch master
                Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded.
                  (use "git pull" to update your local branch)
                  (use "git add <file>..." to update what will be committed)
                  (use "git checkout -- <file>..." to discard changes in working directory)
                        modified:   css/custom.css
                        modified:   package-lock.json
                Untracked files:
                  (use "git add <file>..." to include in what will be committed)
                        core
                        installers/dumpactivemodules.js
                        installers/pm2_MagicMirror_new.json
                        mm.sh
                        nohup.out
                no changes added to commit (use "git add" and/or "git commit -a")
                cheers, bdream
                  sdetweil @bdream
                  @bdream weird… says code should handle it
                  try this
                  alias
                  git status | grep modified | awk -F: '{print $2}'
                  thanks
                    bdream
                    pi@MagicMirror:~/MagicMirror $  alias
                    alias egrep='egrep --color=auto'
                    alias fgrep='fgrep --color=auto'
                    alias grep='grep --color=auto'
                    alias ls='ls --color=auto'
                    pi@MagicMirror:~/MagicMirror $  alias git='LANGUAGE=en_US.UTF-8 git'
                    pi@MagicMirror:~/MagicMirror $  git status | grep modified | awk -F: '{print $2}'
                       css/custom.css
                       package-lock.json
                    pi@MagicMirror:~/MagicMirror $  unalias git >/dev/null
                    cheers, bdream
                      sdetweil @bdream
                      @bdream weird…
                      can u try the script again? i am recording the output of the git status command, manually it detects the file
                        bdream
                        pi@MagicMirror:~/MagicMirror $   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                        saving custom.css
                        cheers, bdream
                          sdetweil @bdream
                          @bdream can u show me the log again
                            bdream
                            Upgrade started - Mi Okt 16 15:22:29 CEST 2019
                            saving custom.css
                            merge result rc= 1
                            removing git alias
                            Upgrade ended - Mi Okt 16 15:22:31 CEST 2019
                            cheers, bdream
                              sdetweil @bdream
                              @bdream said in Update to v2.9.0 fail:
                              there is supposed to be output from the git status command right there ???
                              I just made another tiny log reporting change… one more time please
                                bdream
                                saving custom.css
                                Upgrade started - Mi Okt 16 15:31:26 CEST 2019
                                saving custom.css
                                Auf Branch master
                                Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden.
                                  (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                                Änderungen, die nicht zum Commit vorgemerkt sind:
                                  (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                                  (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                                	geändert:       css/custom.css
                                	geändert:       package-lock.json
                                Unversionierte Dateien:
                                	core
                                	css/save_custom.css
                                	mm.sh
                                	nohup.out
                                keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
                                merge result rc= 1
                                removing git alias
                                Upgrade ended - Mi Okt 16 15:31:29 CEST 2019
                                I’m sorry for german within the log :unamused_face:
                                cheers, bdream
                                  sdetweil @bdream
                                  that will do it… i search for english ‘modified’, but its not there…
                                  ok, one more time… another reporting change
                                    bdream
                                    Upgrade started - Mi Okt 16 15:38:04 CEST 2019
                                    saving custom.css
                                    Auf Branch master
                                    	%logfile
                                    	core
                                    	css/save_custom.css
                                    	mm.sh
                                    	nohup.out
                                    merge result rc= 1
                                    removing git alias
                                    Upgrade ended - Mi Okt 16 15:38:06 CEST 2019
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream cool… do this
                                      shopt | grep expand
                                      should see this
                                      expand_aliases  on
                                      I bet you see this
                                      expand_aliases  off
                                        bdream
                                        @sdetweil said in Update to v2.9.0 fail:
                                        I bet you see this
                                        expand_aliases off
                                        pi@MagicMirror:~/MagicMirror $   shopt | grep expand
                                        assoc_expand_once       off
                                        direxpand       off
                                        expand_aliases  on
                                        cheers, bdream
                                          sdetweil @bdream
                                          expand_aliases on
                                          yeh, but it didn’t!!
                                          try script again
                                            bdream
                                            try script again
                                            saving custom.css
                                            there are 2 local files that are different than the master repo
                                               css/custom.css
                                               package-lock.json
                                            any *-lock.json files do not need to be saved
                                            do you want to save these files for later   (Y/n)?Y
                                            *** Bitte geben Sie an, wer Sie sind.
                                            Führen Sie
                                              git config --global user.email "you@example.com"
                                              git config --global user.name "Your Name"
                                            aus, um das als Ihre standardmäßige Identität zu setzen.
                                            Lassen Sie die Option "--global" weg, um die Identität nur
                                            für dieses Repository zu setzen.
                                            fatal: Konnte die E-Mail-Adresse nicht automatisch erkennen ('pi@MagicMirror.(none)' erhalten)
                                            Kann den aktuellen Zustand des Index nicht speichern
                                            error: Your local changes to the following files would be overwritten by merge:         package-lock.json Please commit your changes or stash them before you merge. Aborting Updating a31546b..500147e
                                            we stashed a set of files that appear changed from the latest repo versions. you should review them
                                            Keine Stash-Einträge gefunden.
                                            see installers/stashed_files for the list
                                            you can use git checkout stash@{0} -- filename to extract one file from the stash
                                            or git stash pop to restore them all
                                            WARNING..
                                            WARNING.. either will overlay the file just installed by the update
                                            WARNING..
                                            custom.css is realy touched by me but should not be affected by updates I thougt.
                                            Führen Sie
                                            that says about the git configuration is not correct. But I never configured git on the Pi. Do I need to do?
                                            The fatal is about the e-mail was not to get detected automaticly. For sure there was never a e-mail configured for nothing at the Pi.
                                            Index can not be saved.
                                            Says 'no Stash-entries were found. whatever that mens.
                                            cheers, bdream
                                            S 2 Replies Last reply
