    Update to v2.9.0 fail
    48 Posts 3 Posters 22.3k Views 3 Watching
      bdream
      @sdetweil SORRY!
      pi@MagicMirror:~/MagicMirror $  git status
      On branch master
      Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded.
        (use "git pull" to update your local branch)
        (use "git add <file>..." to update what will be committed)
        (use "git checkout -- <file>..." to discard changes in working directory)
              modified:   css/custom.css
              modified:   package-lock.json
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
              core
              installers/dumpactivemodules.js
              installers/pm2_MagicMirror_new.json
              mm.sh
              nohup.out
      no changes added to commit (use "git add" and/or "git commit -a")
      cheers, bdream
        sdetweil @bdream
        @bdream weird… says code should handle it
        try this
        alias
        alias git='LANGUAGE=en_US.UTF-8 git'
        git status | grep modified | awk -F: '{print $2}'
        unalias git >/dev/null
        thanks
          bdream
          pi@MagicMirror:~/MagicMirror $  alias
          alias egrep='egrep --color=auto'
          alias fgrep='fgrep --color=auto'
          alias grep='grep --color=auto'
          alias ls='ls --color=auto'
          pi@MagicMirror:~/MagicMirror $  alias git='LANGUAGE=en_US.UTF-8 git'
          pi@MagicMirror:~/MagicMirror $  git status | grep modified | awk -F: '{print $2}'
             css/custom.css
             package-lock.json
          pi@MagicMirror:~/MagicMirror $  unalias git >/dev/null
          cheers, bdream
            sdetweil @bdream
            @bdream weird…
            can u try the script again? i am recording the output of the git status command, manually it detects the file
              bdream
              pi@MagicMirror:~/MagicMirror $   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
              doing test run = false
              saving custom.css
              upgrading from version 2.8.0 to 2.9.0
              fetching latest revisions
              there were merge errors
              you should examine and resolve them
              using the command git log --oneline --decorate
              a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
              restoring custom.css
              cheers, bdream
                sdetweil @bdream
                @bdream can u show me the log again
                  bdream
                  Upgrade started - Mi Okt 16 15:22:29 CEST 2019
                  user requested to apply changes
                  saving custom.css
                  not english or locale not set, set git alias
                  remote name = origin
                  current branch = master
                  no files different from github version
                  test merge result rc='' , if empty, no conflicts
                  executing merge, apply specified
                  merge result rc= 1
                   error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
                  removing git alias
                  Upgrade ended - Mi Okt 16 15:22:31 CEST 2019
                  cheers, bdream
                    sdetweil @bdream
                    @bdream said in Update to v2.9.0 fail:
                    there is supposed to be output from the git status command right there ???
                    I just made another tiny log reporting change… one more time please
                      bdream
                      saving custom.css
                      Upgrade started - Mi Okt 16 15:31:26 CEST 2019
                      saving custom.css
                      Auf Branch master
                      Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden.
                        (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                      Änderungen, die nicht zum Commit vorgemerkt sind:
                        (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                        (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                      	geändert:       css/custom.css
                      	geändert:       package-lock.json
                      Unversionierte Dateien:
                      	core
                      	css/save_custom.css
                      	mm.sh
                      	nohup.out
                      keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
                      merge result rc= 1
                      removing git alias
                      Upgrade ended - Mi Okt 16 15:31:29 CEST 2019
                      I’m sorry for german within the log :unamused_face:
                      cheers, bdream
                        sdetweil @bdream
                        that will do it… i search for english ‘modified’, but its not there…
                        ok, one more time… another reporting change
                          bdream
                          Upgrade started - Mi Okt 16 15:38:04 CEST 2019
                          saving custom.css
                          Auf Branch master
                          	%logfile
                          	core
                          	css/save_custom.css
                          	mm.sh
                          	nohup.out
                          merge result rc= 1
                          removing git alias
                          Upgrade ended - Mi Okt 16 15:38:06 CEST 2019
                          cheers, bdream
                            sdetweil @bdream
                            @bdream cool… do this
                            shopt | grep expand
                            should see this
                            expand_aliases  on
                            I bet you see this
                            expand_aliases  off
                              bdream
                              @sdetweil said in Update to v2.9.0 fail:
                              I bet you see this
                              expand_aliases off
                              pi@MagicMirror:~/MagicMirror $   shopt | grep expand
                              assoc_expand_once       off
                              direxpand       off
                              expand_aliases  on
                              cheers, bdream
                                sdetweil @bdream
                                expand_aliases on
                                yeh, but it didn’t!!
                                try script again
                                  bdream
                                  try script again
                                  saving custom.css
                                  there are 2 local files that are different than the master repo
                                     css/custom.css
                                     package-lock.json
                                  any *-lock.json files do not need to be saved
                                  do you want to save these files for later   (Y/n)?Y
                                  *** Bitte geben Sie an, wer Sie sind.
                                  Führen Sie
                                    git config --global user.email "you@example.com"
                                    git config --global user.name "Your Name"
                                  aus, um das als Ihre standardmäßige Identität zu setzen.
                                  Lassen Sie die Option "--global" weg, um die Identität nur
                                  für dieses Repository zu setzen.
                                  fatal: Konnte die E-Mail-Adresse nicht automatisch erkennen ('pi@MagicMirror.(none)' erhalten)
                                  Kann den aktuellen Zustand des Index nicht speichern
                                  error: Your local changes to the following files would be overwritten by merge:         package-lock.json Please commit your changes or stash them before you merge. Aborting Updating a31546b..500147e
                                  we stashed a set of files that appear changed from the latest repo versions. you should review them
                                  Keine Stash-Einträge gefunden.
                                  see installers/stashed_files for the list
                                  you can use git checkout stash@{0} -- filename to extract one file from the stash
                                  or git stash pop to restore them all
                                  WARNING..
                                  WARNING.. either will overlay the file just installed by the update
                                  WARNING..
                                  custom.css is realy touched by me but should not be affected by updates I thougt.
                                  Führen Sie
                                  that says about the git configuration is not correct. But I never configured git on the Pi. Do I need to do?
                                  The fatal is about the e-mail was not to get detected automaticly. For sure there was never a e-mail configured for nothing at the Pi.
                                  Index can not be saved.
                                  Says 'no Stash-entries were found. whatever that mens.
                                  cheers, bdream
                                  S 2 Replies Last reply
                                    sdetweil @bdream
                                    @bdream hang on…
                                      @sdetweil try this, note just adding another parm
                                      bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                                      also show results of, notice dot in front of filename
                                      cat ~/.bashrc
                                        sdetweil @bdream
                                        prior to this release, custom.css was considered a core file, and was overlayed on updates.
                                        this release puts in a fix for that… but I save/restore it anyhow
                                        stash is a place where you can hold modified files, but continue on with your work.
                                        it requires some setup, but my script is supposed to go that for you
                                          bdream
                                          pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                                          saving custom.css
                                          upgrade.log
                                          Upgrade started - Mi Okt 16 17:12:12 CEST 2019
                                          saving custom.css
                                          Auf Branch master
                                          	%logfile
                                          	core
                                          	css/save_custom.css
                                          	mm.sh
                                          	nohup.out
                                          merge result rc= 1
                                          removing git alias
                                          Upgrade ended - Mi Okt 16 17:12:14 CEST 2019
                                          pi@MagicMirror:~/MagicMirror $  cat ~/.bashrc
                                          # ~/.bashrc: executed by bash(1) for non-login shells.
                                          # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
                                          # for examples
                                          # If not running interactively, don't do anything
                                          case $- in
                                              *i*) ;;
                                                *) return;;
                                          esac
                                          # don't put duplicate lines or lines starting with space in the history.
                                          # See bash(1) for more options
                                          HISTCONTROL=ignoreboth
                                          # append to the history file, don't overwrite it
                                          shopt -s histappend
                                          # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
                                          HISTSIZE=1000
                                          HISTFILESIZE=2000
                                          # check the window size after each command and, if necessary,
                                          # update the values of LINES and COLUMNS.
                                          shopt -s checkwinsize
                                          # If set, the pattern "**" used in a pathname expansion context will
                                          # match all files and zero or more directories and subdirectories.
                                          #shopt -s globstar
                                          # make less more friendly for non-text input files, see lesspipe(1)
                                          #[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
                                          # set variable identifying the chroot you work in (used in the prompt below)
                                          if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
                                              debian_chroot=$(cat /etc/debian_chroot)
                                          fi
                                          # set a fancy prompt (non-color, unless we know we "want" color)
                                          case "$TERM" in
                                              xterm-color|*-256color) color_prompt=yes;;
                                          esac
                                          # uncomment for a colored prompt, if the terminal has the capability; turned
                                          # off by default to not distract the user: the focus in a terminal window
                                          # should be on the output of commands, not on the prompt
                                          force_color_prompt=yes
                                          if [ -n "$force_color_prompt" ]; then
                                              if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
                                                  # We have color support; assume it's compliant with Ecma-48
                                                  # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
                                                  # a case would tend to support setf rather than setaf.)
                                                  color_prompt=yes
                                              else
                                                  color_prompt=
                                              fi
                                          fi
                                          if [ "$color_prompt" = yes ]; then
                                              PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w \$\[\033[00m\] '
                                          else
                                              PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
                                          fi
                                          unset color_prompt force_color_prompt
                                          # If this is an xterm set the title to user@host:dir
                                          case "$TERM" in
                                          xterm*|rxvt*)
                                              PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
                                          esac
                                          # enable color support of ls and also add handy aliases
                                          if [ -x /usr/bin/dircolors ]; then
                                              test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
                                              #alias dir='dir --color=auto'
                                              #alias vdir='vdir --color=auto'
                                          fi
                                          # colored GCC warnings and errors
                                          #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
                                          # some more ls aliases
                                          #alias ll='ls -l'
                                          #alias la='ls -A'
                                          #alias l='ls -CF'
                                          # Alias definitions.
                                          # You may want to put all your additions into a separate file like
                                          # ~/.bash_aliases, instead of adding them here directly.
                                          # See /usr/share/doc/bash-doc/examples in the bash-doc package.
                                          if [ -f ~/.bash_aliases ]; then
                                              . ~/.bash_aliases
                                          fi
                                          # enable programmable completion features (you don't need to enable
                                          # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
                                          # sources /etc/bash.bashrc).
                                          if ! shopt -oq posix; then
                                            if [ -f /usr/share/bash-completion/bash_completion ]; then
                                              . /usr/share/bash-completion/bash_completion
                                            elif [ -f /etc/bash_completion ]; then
                                              . /etc/bash_completion
                                            fi
                                          fi
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream what a battle!
                                            in the short term, erase package-lock.json
                                            also show me output of
                                            echo $LC_ALL
