    MMM-Face-Reco-DNN
    8 Posts 2 Posters 2.4k Views 2 Watching
      Blauenfeldt
      When i use classes like below
      classes: 'name'
      i get an error for the next line in the config.js
      If I write it with a comma like this:
      Classes: 'name',
      Then it and the whole module: "MMM-Face-Reco-DNN"will get ignored, and all my modules will be shown, even if nobody is in front of the camera.
      Here is a log:
      0|MagicMirror  | Loading config ...
      0|MagicMirror  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:65
      0|MagicMirror  | 			classes: 'name'
      0|MagicMirror  | 			^^^^^^^
      0|MagicMirror  | SyntaxError: Unexpected identifier
      0|MagicMirror  |     at new Script (vm.js:74:7)
      0|MagicMirror  |     at createScript (vm.js:246:10)
      0|MagicMirror  |     at Object.runInThisContext (vm.js:298:10)
      0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:678:28)
      0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
      0|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:620:32)
      0|MagicMirror  |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
      0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
      0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:658:17)
      0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:20:18)
      0|MagicMirror  | Loading module helpers ...
      Here is line 65 in my config file:
      			module: "currentweather",
      				locationID: "hidden",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "hidden"
      			classes: 'name'
      If I move classes up below position like this:
      			classes: 'name'
      				appid: "hidden"
      Then the result will be like this:
      0|MagicMirror  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:60
      0|MagicMirror  | 			config: {
        sdetweil @Blauenfeldt
        @Blauenfeldt said in MMM-Face-Reco-DNN:
        classes ‘name’,
        yes, it should be
        classes: ‘name’,
        u missed the colon (:) between name and value
          Blauenfeldt
          My bad. That is what i have done. I will edit my problem so it is more detailed.
            @Blauenfeldt can u show your whole module definition
            is there a comma on the end of the line before classes:
            B 1 Reply Last reply
              Blauenfeldt @sdetweil
              I’ve updated it. yes, the line before classes ends with a comma.
                @Blauenfeldt thanks
                in this case
                				appid: "hidden"
                			}    // < ------  comma needed here
                			classes: 'name'
                in this case
                			classes: 'name'   // < --- comma needed here
                				appid: "hidden"
                so, if u see an error like
                general rule, look at the line BEFORE the line referenced and add a trailing comma
                in this case, line 59 (add a comma)
                also, do
                npm run config:check
                fix errors from top down
                repeat til no errors
                  @sdetweil Thank you. I will try that.
                    Blauenfeldt
                    It works like a charm now. Thank you very much.
