    MYMIRROR - From Modena
    28 Posts 6 Posters 24.4k Views 7 Watching
      s.monti.74
        s.monti.74
          s.monti.74
          I have done in this way.
          I Have installed Arduino IDE on RPI and to run on Arduino the program to send via serial communication ten information of the RFID it’s reading
          This in the programo uploaded on Arduino
          I use two RFID tags (TAG1 and TAG2)
          richland007R 1 Reply Last reply
            s.monti.74
              s.monti.74
              #include <SPI.h>
              #include <RFID.h>
              #define SDA_DIO 10  // 53 per Mega
              #define RESET_DIO 9
              #define delayRead 1000 // Time of delay
              #define delayLed 2000
              #define ledVerde 3
              #define ledRosso 4
              RFID RC522(SDA_DIO, RESET_DIO);
              String TAG1= "975318736";
              String TAG2= "976A15D37";
              void setup()
                Serial.begin(9600);
                /* Abilita SPI*/
                SPI.begin();
                /* Viene inizilizzato RFID reader */
                RC522.init();
                /*Serial.println("Setup");*/
                pinMode(ledVerde,OUTPUT);
                pinMode(ledRosso,OUTPUT);
              void loop()
                /* Temporary loop counter */
                byte i;
                // Se viene letta una tessera
                if (RC522.isCard())
                  RC522.readCardSerial();
                  String codiceLetto ="";
                  for(i = 0; i <= 4; i++)
                    codiceLetto+= String (RC522.serNum[i],HEX);
                    codiceLetto.toUpperCase();
                   if (codiceLetto.equals(TAG1)){
                    Serial.println("S");
                    accendiLed(ledVerde);
                  if (codiceLetto.equals(TAG2)){
                    Serial.println("G");
                  delay(delayRead);
              boolean verificaCodice(String codiceLetto){
                if(codiceLetto.equals(codiceAutorizzato)){
                  return true;
                }else{
                  return false;
              void accendiLed(int ledPin){
                digitalWrite(ledPin,HIGH);
                delay(delayLed);
                digitalWrite(ledPin,LOW);
                s.monti.74
                this program sends via serial communication the value “S” if i use TAG1 and “G” if I usa TAG2
                Then you have to use, on magic mirror, the module MMM-Serial-Notifications to read the value:
                    module: 'MMM-Serial-Notifications',
                      devices: {
                        '/dev/ttyACM0': {
                          messages: {
                            'S': [
                		notification: 'CURRENT_PROFILE',
                		payload:  'S',
                          'A': [
                		payload:  'G',
                and the module MMM-ProfileSwitcher to manage all other modules:
                        		module: 'MMM-ProfileSwitcher',
                			classes: 'default',
                			header: "Profile",
                				enterMessages: {
                					"G": "Ciao, G",
                					"S": "Ciao, S"
                				leaveMessages: {
                					"G": "Ciao G, ci vediamo alla prossima",
                					"S": "Ciao S, ci vediamo alla prossima",
                				timers: {
                    				"S": {
                        			time: 10 * 1000
                    				"G": {
                        			time: 10 * 1000
                BYE
                Stefano
                • richland007R
                  richland007 @s.monti.74
                  @s-monti-74 So do you use an Arduino Uno or not??
                  Why do you download the Arduino IDE on the Rpi?? Is it just for programming the UNO (i use the IDE on my Windows machine) or to read the serial commands??
                  How do you connect the RFID board RC522 to the Rpi or to the UNO?? … the board has 7 used pins and 1 unused, assuming we are talking about the RFID-RC522 board
                  Gracie
                  Denis
                  • richland007R
                    richland007
                    @s-monti-74 Stefano One more question if you use the Arduino Uno how do you connected it to the Rpi??
                      s.monti.74
                      I have bought this on Amazon:
                      AZDelivery ⭐⭐⭐⭐⭐ Kit RFID RC522 13,56MHz con Reader, Chip e Scheda per Arduino e Raspberry Pi con eBook Gratuito!
                      7€
                      I have connected Arduino with PI via USb cable
                      with this connection I upload sketch to Aruino (this is why I use Arduino IDE on PI) and with the same connection datas (RFID tags) are tranfered from Arduino to PI (and the module of magic Mirror does the rest of the job)
                      • richland007R
                        @s-monti-74
                        Is the Arduino code you copied on the above post the complete one?? It makes no sense to me …also what wiring scheme are you using for the RFID board to the Uno??
                        Always thank you for the response
                        Another thing can you please check for errors the MMM-Serial-Notifications module entry code on the config… that you posted on the above post… it mentions an S and A instead of G and no TAG1 or TAG2
                        As always
                        Thank you again
                        Denis
                          sdetweil @richland007
                          @richland007 the uno is connected to the pi serial port from the uno serial port.
                          So the uno code writes to it’s port, and the data causes an serial event on the pi with the data.
                          • richland007R
                            richland007 @sdetweil
                            @sdetweil Yes Sam but is the UNO to Rpi connection using Dupont wires and the TX RX pinouts or through the usb connection which is also used to upload the sketch to the UNO… i thought it was through the usb??
                              @richland007 i believe he uses both… usb for sketch and serial for data
                                s.monti.74 @richland007
                                @richland007 I have modified the code before update it, to make it simpler and probably something is wrong.
                                I use 2 tags, the first to recognize me (S) and the second to recognize my wife (G)
                                for serial communication, later I send you a photo
                                  s.monti.74
                                  • richland007R
                                    @s-monti-74 Great i got the schematics now :)
                                    Can you please post again the complete Arduino code
                                    Thank you very very much
                                    Denis
                                      @richland007 I can’t upload in the editor the full code because the editor blocks it (probably it converts the “;” char as the end of the code) I also can’t upload a txt file witch the code, i can upload only images
                                      richland007R Cr4z33C 2 Replies Last reply
                                      • richland007R
                                        @s-monti-74 Can you e-mail the Arduino sketch as txt file to me please at grabocka (@) sbcglobal.net
                                        oh the config.js entries also please so i can change my names into it :)
                                        Grazie mille
                                        Denis
                                        • Cr4z33C
                                          Cr4z33 @s.monti.74
                                          @s-monti-74 said in MYMIRROR - From Modena:
                                          You can easily copy&paste everything to pastebin.com then share here the link for others. ;)
                                            s.monti.74 @Cr4z33
                                            @Cr4z33
                                            this is my “paste”…
                                            https://pastebin.com/wY8yVtpv
