    Anyone successfully using MMM-Tesla module?
    10 Posts 5 Posters 4.2k Views 6 Watching
      jpiatt
      I have coded the following but only get message “Loading …” in the assigned area. Any tips or tricks to getting this to work?
                          module: "MMM-Tesla",
                          position: "bottom_left",
                                  email: "REDACTED",
                                  password: "REDACTED",
                                  client_id: "81527cff06843c8634fdc09e8ac0abefb46...",
                                  clent_secret: "c7257eb71a564034f9419ee651c7d0e5...",
                                  vehicle_id: "REDACTED",
                                  google_api_key: "REDACTED",
                                  refreshInterval: 1000 * 60 * 10
      • K Offline
        kellogg76
        I’m in the same boat, with the same “Loading…” message. Did you ever get it working?
          sdetweil @jpiatt
          @jpiatt open the developers window with
          Ctrl-shift-i
          Or start mm in dev mode
          npm start dev
          Select the console tab, and scroll up to find any errors, red rext
            CDT
            @jpiatt
            I did, finally. Maybe this will help:
            I used the teslams command line program to get my vehicle_ID. There are two IDs that it presents: one is vehicle ID and was 10 characters. The one you want is just called “ID” and is 17 characters. Worked instantly after I changed that.
            See if that gets you there.
              jpiatt @CDT
              @CDT It’s obviously been a long time since I checked this post. This tip was very helpful. I was using the wrong vehicle_ID and have changed it. I’m still getting the “Loading…” message. Based on your experience though, I feel like I must have a problem in my config and I’m going to play with it some more today and see if I can straighten it out.
              The first error message I see in the console log (actually it’s written to stdout) is an UnhandledPromiseRejectionWarning with a Response Error: 404 Not Found. I’m considering just reinstalling the module in case I’ve edited something trying to troubleshoot and left out a comma or introduced bad line-ending with a funky editor or something.
              I will post here if I resolve the issue.
                sdetweil @jpiatt
                @jpiatt said in Anyone successfully using MMM-Tesla module?:
                That means the url of the API didn’t work. So something is missing in the setup, or the API has changed
                  jpiatt @sdetweil
                  @sdetweil Thanks, sam. That’s what I figured. I’ll post here when I figure out what I screwed up.
                    CDT
                    One more tip. Your car’s ID seems to change monthly. So you have to run teslams to get it working.
                    I am working on my own version which is a bit more feature rich (not a lot more, because I have no training as a programmer). I think I have all the bugs worked out but want to see if I can address this ID update in an automated fashion.
                      CDT @CDT
                      @CDT
                        antagon
                        I have started work on a fork from MMM-Tesla, since I could not get this working either.
                        It is located at https://github.com/martinburheimtingstad/MMM-Tesla2/
