    pm2 dosn`t start mm.sh after reboot
    29 Posts 3 Posters 14.6k Views 3 Watching
      Skorpionbird
      thx for the fast reason.
        sdetweil @Skorpionbird
        @Skorpionbird did it fix it?
          Skorpionbird
          no dosn`t work with your reason
            @Skorpionbird can u show me
            ~/MagicMirror/installers/pm2_setup.log
              Skorpionbird
              pm2 setup starting - Di Nov 5 15:55:05 CET 2019
              node version v10.17.0
              force installing latest npm version via npm
              npm version 6.11.3
              pm2 installed
              pm2 installed, but does not work, uninstalling
              pm2 not installed, installing
              get the pm2 platform specific startup command
              command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup sys$
              [PM2] Init System found: systemd
              Platform systemd
              Template
              [Unit]
              Description=PM2 process manager
              Documentation=https://pm2.keymetrics.io/
              After=network.target
              [Service]
              Type=forking
              User=pi
              LimitNOFILE=infinity
              LimitNPROC=infinity
              LimitCORE=infinity
              Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$
              Environment=PM2_HOME=/home/pi/.pm2
              PIDFile=/home/pi/.pm2/pm2.pid
              Restart=on-failure
              ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
              ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
              ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
              [Install]
              WantedBy=multi-user.target
              Target path
              /etc/systemd/system/pm2-pi.service
              Command list
              [ ‘systemctl enable pm2-pi’ ]
              [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
              [PM2] Making script booting at startup…
              Executing: systemctl enable pm2-pi…
              [PM2] [v] Command successfully executed.
              [PM2] Freeze a process list on reboot via:
              $ pm2 save
              [PM2] Remove init script via:
              $ pm2 unstartup systemd
              pm2 startup done
              configure the pm2 config file for MagicMirror
              start MagicMirror via pm2 now
              save MagicMirror pm2 config now
              pm2 setup completed - Di Nov 5 15:56:55 CET 2019
                @Skorpionbird what is the output of pm2 logs?
                S 2 Replies Last reply
                  Skorpionbird @sdetweil
                  @sdetweil already postet
                    @sdetweil when i copy paste ~/MagicMirror/installers/pm2_setup.log
                    Then i recive
                    Connecting to 192.168.1.174 port 22, please wait…
                    login as:
                    pi@192.168.1.174’s password:
                    Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Sun Nov  3 20:42:57 2019 from 192.168.1.9
                    pi@raspberrypi:~ $ ~/MagicMirror/installers/pm2_setup.log
                    -bash: /home/pi/MagicMirror/installers/pm2_setup.log: Keine Berechtigung access denied
                    pi@raspberrypi:~ $
                      @Skorpionbird I want to see the output of the command
                      pm2 logs
                        @sdetweil oh sry here is it
                        pm2 logs
                        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                        [PM2] PM2 Successfully daemonized
                        [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
                        /home/pi/.pm2/pm2.log last 15 lines:
                        PM2        | 2019-11-05T19:12:24: PM2 log: ===============================================================================
                        PM2        | 2019-11-05T19:12:24: PM2 log: — New PM2 Daemon started ----------------------------------------------------
                        PM2        | 2019-11-05T19:12:24: PM2 log: Time                 : Tue Nov 05 2019 19:12:24 GMT+0100 (GMT+01:00)
                        PM2        | 2019-11-05T19:12:24: PM2 log: PM2 version          : 4.1.2
                        PM2        | 2019-11-05T19:12:24: PM2 log: Node.js version      : 10.17.0
                        PM2        | 2019-11-05T19:12:24: PM2 log: Current arch         : arm
                        PM2        | 2019-11-05T19:12:24: PM2 log: PM2 home             : /home/pi/.pm2
                        PM2        | 2019-11-05T19:12:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                        PM2        | 2019-11-05T19:12:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                        PM2        | 2019-11-05T19:12:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                        PM2        | 2019-11-05T19:12:24: PM2 log: Application log path : /home/pi/.pm2/logs
                        PM2        | 2019-11-05T19:12:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                        PM2        | 2019-11-05T19:12:24: PM2 log: Concurrent actions   : 2
                        PM2        | 2019-11-05T19:12:24: PM2 log: SIGTERM timeout      : 1600
                          Skorpionbird
                          any news?
                            @Skorpionbird what system is this? hardware/os?
                            i have seen a similar problem recently on macOs Catalina…
                            S T 2 Replies Last reply
                              @sdetweil its a Rpi 2 with Noobs Rasbian GNU Linux 10
                                @Skorpionbird in the pm2_setup.log, could you show me the rest of this line
                                and try this
                                sudo env PATH=$PATH:/usr/local/bin pm2 startup systemd -u pi --hp /home/pi
                                then , make sure MagicMirror is not running
                                pm2 start installers/pm2_MagicMirror.json
                                pm2 save
                                then reboot
                                  Skorpionbird
                                  @sdetweil said in pm2 dosn`t start mm.sh after reboot:
                                  thx with this it works fine
                                  • T
                                    trividar @sdetweil
                                    @sdetweil Have you a solution for mac osx catalina? THX
                                      sdetweil @trividar
                                      @trividar sure, just use the updated install script, which will be in the next release
                                      see
                                      https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                      T 1 Reply Last reply
                                      • T
                                        trividar @sdetweil
                                        @sdetweil how can I execute this script?
                                          sdetweil @trividar
                                          @trividar read the instructions at the link I gave,
                                          in a terminal window , use finder to find ‘terminal’
                                          • T
                                            trividar @sdetweil
                                            @sdetweil OK I found the link…
                                            bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                            just a question, I have set up the magicmirror with all my settings etc. can I just execute this without loosing my stuff??
