    pm2 dosn`t start mm.sh after reboot
    29 Posts 3 Posters 14.6k Views 3 Watching
      sdetweil @Skorpionbird
      @Skorpionbird can u show me
      ~/MagicMirror/installers/pm2_setup.log
        Skorpionbird
        pm2 setup starting - Di Nov 5 15:55:05 CET 2019
        node version v10.17.0
        force installing latest npm version via npm
        npm version 6.11.3
        pm2 installed
        pm2 installed, but does not work, uninstalling
        pm2 not installed, installing
        get the pm2 platform specific startup command
        command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup sys$
        [PM2] Init System found: systemd
        Platform systemd
        Template
        [Unit]
        Description=PM2 process manager
        Documentation=https://pm2.keymetrics.io/
        After=network.target
        [Service]
        Type=forking
        User=pi
        LimitNOFILE=infinity
        LimitNPROC=infinity
        LimitCORE=infinity
        Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$
        Environment=PM2_HOME=/home/pi/.pm2
        PIDFile=/home/pi/.pm2/pm2.pid
        Restart=on-failure
        ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
        ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
        ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
        [Install]
        WantedBy=multi-user.target
        Target path
        /etc/systemd/system/pm2-pi.service
        Command list
        [ ‘systemctl enable pm2-pi’ ]
        [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
        [PM2] Making script booting at startup…
        Executing: systemctl enable pm2-pi…
        [PM2] [v] Command successfully executed.
        [PM2] Freeze a process list on reboot via:
        $ pm2 save
        [PM2] Remove init script via:
        $ pm2 unstartup systemd
        pm2 startup done
        configure the pm2 config file for MagicMirror
        start MagicMirror via pm2 now
        save MagicMirror pm2 config now
        pm2 setup completed - Di Nov 5 15:56:55 CET 2019
          @Skorpionbird what is the output of pm2 logs?
          S 2 Replies Last reply
            Skorpionbird @sdetweil
            @sdetweil already postet
              @sdetweil when i copy paste ~/MagicMirror/installers/pm2_setup.log
              Then i recive
              Connecting to 192.168.1.174 port 22, please wait…
              login as:
              pi@192.168.1.174’s password:
              Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
              The programs included with the Debian GNU/Linux system are free software;
              the exact distribution terms for each program are described in the
              individual files in /usr/share/doc/*/copyright.
              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
              permitted by applicable law.
              Last login: Sun Nov  3 20:42:57 2019 from 192.168.1.9
              pi@raspberrypi:~ $ ~/MagicMirror/installers/pm2_setup.log
              -bash: /home/pi/MagicMirror/installers/pm2_setup.log: Keine Berechtigung access denied
              pi@raspberrypi:~ $
                @Skorpionbird I want to see the output of the command
                pm2 logs
                  @sdetweil oh sry here is it
                  pm2 logs
                  [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                  [PM2] PM2 Successfully daemonized
                  [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
                  /home/pi/.pm2/pm2.log last 15 lines:
                  PM2        | 2019-11-05T19:12:24: PM2 log: ===============================================================================
                  PM2        | 2019-11-05T19:12:24: PM2 log: — New PM2 Daemon started ----------------------------------------------------
                  PM2        | 2019-11-05T19:12:24: PM2 log: Time                 : Tue Nov 05 2019 19:12:24 GMT+0100 (GMT+01:00)
                  PM2        | 2019-11-05T19:12:24: PM2 log: PM2 version          : 4.1.2
                  PM2        | 2019-11-05T19:12:24: PM2 log: Node.js version      : 10.17.0
                  PM2        | 2019-11-05T19:12:24: PM2 log: Current arch         : arm
                  PM2        | 2019-11-05T19:12:24: PM2 log: PM2 home             : /home/pi/.pm2
                  PM2        | 2019-11-05T19:12:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                  PM2        | 2019-11-05T19:12:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                  PM2        | 2019-11-05T19:12:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                  PM2        | 2019-11-05T19:12:24: PM2 log: Application log path : /home/pi/.pm2/logs
                  PM2        | 2019-11-05T19:12:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                  PM2        | 2019-11-05T19:12:24: PM2 log: Concurrent actions   : 2
                  PM2        | 2019-11-05T19:12:24: PM2 log: SIGTERM timeout      : 1600
                    Skorpionbird
                    any news?
                      @Skorpionbird what system is this? hardware/os?
                      i have seen a similar problem recently on macOs Catalina…
                      S T 2 Replies Last reply
                        @sdetweil its a Rpi 2 with Noobs Rasbian GNU Linux 10
                          @Skorpionbird in the pm2_setup.log, could you show me the rest of this line
                          and try this
                          sudo env PATH=$PATH:/usr/local/bin pm2 startup systemd -u pi --hp /home/pi
                          then , make sure MagicMirror is not running
                          pm2 start installers/pm2_MagicMirror.json
                          pm2 save
                          then reboot
                            Skorpionbird
                            @sdetweil said in pm2 dosn`t start mm.sh after reboot:
                            thx with this it works fine
                            • T
                              trividar @sdetweil
                              @sdetweil Have you a solution for mac osx catalina? THX
                                sdetweil @trividar
                                @trividar sure, just use the updated install script, which will be in the next release
                                see
                                https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                T 1 Reply Last reply
                                • T
                                  trividar @sdetweil
                                  @sdetweil how can I execute this script?
                                    sdetweil @trividar
                                    @trividar read the instructions at the link I gave,
                                    in a terminal window , use finder to find ‘terminal’
                                    • T
                                      trividar @sdetweil
                                      @sdetweil OK I found the link…
                                      bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                      just a question, I have set up the magicmirror with all my settings etc. can I just execute this without loosing my stuff??
                                        sdetweil @trividar
                                        @trividar no… if u have it running, why do you need to install again?
                                        if you don’t have it running, then u need to install…
                                        you can copy the config.js to the new system, but you will have to install the modules and make sure to handle the dependencies they require
                                        • T
                                          trividar @sdetweil
                                          @sdetweil because I can’t get pm2 to work on my mac mini catalina
                                            sdetweil @trividar
                                            @trividar oh, pm2… then use the new script for that
                                            see here
                                            https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                                            sometimes it doesn’t restart on boot like I think it should (on catalina, worked great on sierra an high sierra). haven’t found the problem yet
