    pm2 dosn`t start mm.sh after reboot
    29 Posts 3 Posters 12.9k Views 3 Watching
      Skorpionbird
      Hello
      i have the problem that pm2 dosn`t start mm.sh after reboot. it was working with the MM2 Version 2.8.0 but after the update to 2.9.0 its no longer working.
      Any Idea?
        sdetweil @Skorpionbird
        @Skorpionbird
        see here for my script to update/fix pm2
        https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
          Skorpionbird
          thx for the fast reason.
            @Skorpionbird did it fix it?
              Skorpionbird
              no dosn`t work with your reason
                @Skorpionbird can u show me
                ~/MagicMirror/installers/pm2_setup.log
                  Skorpionbird
                  pm2 setup starting - Di Nov 5 15:55:05 CET 2019
                  node version v10.17.0
                  force installing latest npm version via npm
                  npm version 6.11.3
                  pm2 installed
                  pm2 installed, but does not work, uninstalling
                  pm2 not installed, installing
                  get the pm2 platform specific startup command
                  command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup sys$
                  [PM2] Init System found: systemd
                  Platform systemd
                  Template
                  [Unit]
                  Description=PM2 process manager
                  Documentation=https://pm2.keymetrics.io/
                  After=network.target
                  [Service]
                  Type=forking
                  User=pi
                  LimitNOFILE=infinity
                  LimitNPROC=infinity
                  LimitCORE=infinity
                  Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$
                  Environment=PM2_HOME=/home/pi/.pm2
                  PIDFile=/home/pi/.pm2/pm2.pid
                  Restart=on-failure
                  ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                  ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                  ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                  [Install]
                  WantedBy=multi-user.target
                  Target path
                  /etc/systemd/system/pm2-pi.service
                  Command list
                  [ ‘systemctl enable pm2-pi’ ]
                  [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                  [PM2] Making script booting at startup…
                  Executing: systemctl enable pm2-pi…
                  [PM2] [v] Command successfully executed.
                  [PM2] Freeze a process list on reboot via:
                  $ pm2 save
                  [PM2] Remove init script via:
                  $ pm2 unstartup systemd
                  pm2 startup done
                  configure the pm2 config file for MagicMirror
                  start MagicMirror via pm2 now
                  save MagicMirror pm2 config now
                  pm2 setup completed - Di Nov 5 15:56:55 CET 2019
                    @Skorpionbird what is the output of pm2 logs?
                      Skorpionbird @sdetweil
                      @sdetweil already postet
                        @sdetweil when i copy paste ~/MagicMirror/installers/pm2_setup.log
                        Then i recive
                        Connecting to 192.168.1.174 port 22, please wait…
                        login as:
                        pi@192.168.1.174’s password:
                        Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                        The programs included with the Debian GNU/Linux system are free software;
                        the exact distribution terms for each program are described in the
                        individual files in /usr/share/doc/*/copyright.
                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                        permitted by applicable law.
                        Last login: Sun Nov  3 20:42:57 2019 from 192.168.1.9
                        pi@raspberrypi:~ $ ~/MagicMirror/installers/pm2_setup.log
                        -bash: /home/pi/MagicMirror/installers/pm2_setup.log: Keine Berechtigung access denied
                        pi@raspberrypi:~ $
                          @Skorpionbird I want to see the output of the command
                          pm2 logs
                            @sdetweil oh sry here is it
                            pm2 logs
                            [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                            [PM2] PM2 Successfully daemonized
                            [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
                            /home/pi/.pm2/pm2.log last 15 lines:
                            PM2        | 2019-11-05T19:12:24: PM2 log: ===============================================================================
                            PM2        | 2019-11-05T19:12:24: PM2 log: — New PM2 Daemon started ----------------------------------------------------
                            PM2        | 2019-11-05T19:12:24: PM2 log: Time                 : Tue Nov 05 2019 19:12:24 GMT+0100 (GMT+01:00)
                            PM2        | 2019-11-05T19:12:24: PM2 log: PM2 version          : 4.1.2
                            PM2        | 2019-11-05T19:12:24: PM2 log: Node.js version      : 10.17.0
                            PM2        | 2019-11-05T19:12:24: PM2 log: Current arch         : arm
                            PM2        | 2019-11-05T19:12:24: PM2 log: PM2 home             : /home/pi/.pm2
                            PM2        | 2019-11-05T19:12:24: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                            PM2        | 2019-11-05T19:12:24: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                            PM2        | 2019-11-05T19:12:24: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                            PM2        | 2019-11-05T19:12:24: PM2 log: Application log path : /home/pi/.pm2/logs
                            PM2        | 2019-11-05T19:12:24: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                            PM2        | 2019-11-05T19:12:24: PM2 log: Concurrent actions   : 2
                            PM2        | 2019-11-05T19:12:24: PM2 log: SIGTERM timeout      : 1600
                              Skorpionbird
                              any news?
                                @Skorpionbird what system is this? hardware/os?
                                i have seen a similar problem recently on macOs Catalina…
                                S T 2 Replies Last reply Reply Quote 0
                                  @sdetweil its a Rpi 2 with Noobs Rasbian GNU Linux 10
                                    @Skorpionbird in the pm2_setup.log, could you show me the rest of this line
                                    and try this
                                    sudo env PATH=$PATH:/usr/local/bin pm2 startup systemd -u pi --hp /home/pi
                                    then , make sure MagicMirror is not running
                                    pm2 start installers/pm2_MagicMirror.json
                                    pm2 save
                                    then reboot
                                      Skorpionbird
                                      @sdetweil said in pm2 dosn`t start mm.sh after reboot:
                                      thx with this it works fine
                                      • T Offline
                                        trividar @sdetweil
                                        @sdetweil Have you a solution for mac osx catalina? THX
                                          sdetweil @trividar
                                          @trividar sure, just use the updated install script, which will be in the next release
                                          see
                                          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                          • T Offline
                                            trividar @sdetweil
                                            @sdetweil how can I execute this script?
