    Google calender no events shown
    calendargoogle calendarmodules
    37 Posts 3 Posters 24.8k Views 3 Watching
      sdetweil @mercuryskies
      @mercuryskies right, cause the 1st one ends with ,} which closes the lists of calendars, and then next one has a } too…
      the 1st one url doesn’t work for some reason, (in browser)
      so the test is to take each url, and put it into a browser on the pi, it should download the ics file… if not, you have to fix THAT…
      the pi does not logon as you… so it might work on windows
        mercuryskies
        so both of the google calendar links do not work in my pi browser, it just says site not available.
        if i paste the last default webcal address it just takes me to a google search result.
          @mercuryskies i typed over the word calendar in the https://calendar.google.com and it gets urls not found, not address not found…
          try that… seems some goofy character
            mercuryskies
            the standard google calendar url works fine. it takes me to my calendar and i can see everything in my browser.
            but when i try my private and public urs in the browser i get the site can not be reached.
            i am so confused
              @mercuryskies i was confused as well, then started overtyping the url to find the problem… something in the word ‘calendar’ not right… type it over from the keyboard, not just cut/paste
                mercuryskies @sdetweil
                @sdetweil I’m sorry to sound dumb but can you elaborate . Over typing ? Where are you putting the corrected url .
                  @mercuryskies paste the url of a calendar entry into the browser, then using the keyboard, type over each character (overtype) one by one, and test hitting enter til the thing works.
                  that is what I had to do… then, when it works, copy/paste THAT url back into the calendar entry in config.js
                    @sdetweil ooooooooh exciting. I’ll try that now
                      mercuryskies @mercuryskies
                      @mercuryskies as Instructed I’ve over typed each character and keep getting " the site cannot be reached
                      Calnder.google.com s server ip adress can not be found . Try checking connection and proxy firewall and Dns… "
                      Nothing downloads basically. The url ends in ics correct?
                        @mercuryskies ok, open another tab, and tpe the url https://calendar.google.com
                        hit enter… that should work
                        then copy paste everything AFTER the google.com from the failing to the good after the google.com (deleting any extra stuff on the good url)…
                        then try THAT
                          mercuryskies
                          i get error 404…
                            @mercuryskies
                            but it is no longer unable to find address… now, url not found.
                            u need to go back to the google site and get the url again…
                              @sdetweil as in regenerate a new one ?
                                @mercuryskies well, it will be the same one the url is fixed… just special
                                i am on a new machine today, i saw your trouble… I went to my google calendar site, and copied the private url link and put into just install MM and it works correctly…
                                  @sdetweil the thing is I never copied it because the pi browser doesn’t display the entire calender website. I coudltn seem to get to the settings of the url on pi it seems to run a basic version of the website so I copied the private url from a windows internet browser where i could
                                  M S 2 Replies Last reply Reply Quote 0
                                    I tried resetting my ical adress and re entering a new one. Again. Problem persists. Does anyone have any more suggestions please ? Thanks. Michael
                                      @sdetweil could the problem be related to my node.js. I only ask as when I was trying to configure the google photos module there was a message that came up stating I needed to update my node.js 10.2 to a later version.
                                      Could this old version be preventing my calender from working?
                                      Thanks , Michael
                                        @mercuryskies if u put the cursor in the address/url field and hit ctrl-a (select all), ctrl-c (copy), then u will get the full url.
                                        Those operations are the same as on Windows.
                                          Seregeth
                                          I am also new here and wanted to connect my calendar to my Google calendar as well.
                                          I somehow already failed to get the *.ics file. If I only copy the link out of Google, which is there for pasting, the list with the appointments unfortunately remains empty.
                                          I then tried to create a *.ics file from this public link in various ways and as described in various videos, but unfortunately all to no avail.
                                          Has Google changed anything recently?
                                          Unfortunately, the thread here comes to an abrupt end. How did it come to a solution?
                                            sdetweil @Seregeth
                                            @Seregeth open calendar.google.com
                                            use your mouse to hover over your name in the calendars list in the lower left navigation panel
                                            when over your calendar, 3 dots will appear to the right, click on the 3 dots, and click on ‘Settings and sharing’
                                            the calendar settings page will be displayed,
                                            scroll down to the “Integrate calendar” section
                                            in the lower part in the ics section select the secret url
                                            Secret address in iCal format.
                                            ‘Use this address to access this calendar from other applications without making it public.’
                                            that url is the one u specify in the MM calendar config…
