    MMM-Hotword won't recognize the hotword
    7 Posts 3 Posters 1.9k Views 3 Watching
    • N Offline
      Newbie007
      I guess I successfully install mmm-assistantmk2 along with mmm-hotword. I followed this method for installation.
      I configured my config file and I can see Google logo on my MM screen as well, however no matter how much I shout “Computer” or “Smart Mirror” there is no detection.
      Is there any way I can debug and see what’s going on? Or what did I misconfigure?
      Config.js
      	module: "MMM-Hotword",
      		record: {
      			recordProgram : "arecord",
      			device        : "plughw:1"
      			autostart:true,
      			onDetected: {
      				notification: (payload) => {
      					return "ASSISTANT_ACTIVATE"
      				payload: (payload) => {
      						return {
      						  profile: payload.hotword
      	module: "MMM-AssistantMk2",
      	position: "bottom_left",
      		deviceLocation: {
      			coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
      			latitude: , // -90.0 - +90.0
      			longitude: 	, // -180.0 - +180.0
      				record: {
      					device        : "plughw:1",
      				notifications: {
      					ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
      					ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      				useWelcomeMessage: "brief today",
      				profiles: {
      					"default" : {
      						lang: "en-IN"
      Edit 1 : I ran using npm start dev and I got this error [HOTWORD] No model to load
      Edit 2 : I added cuple of models in config file, running npm start says it detected hotword but received no response.
      [HOTWORD] Detected: computer
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: true, hotword: 'computer', file: null }
        A Former User @Newbie007
        @Newbie007
        Your profile of AssistantMk2 is “computer”? You are calling “computer” as a profile, but you have defined only “default” profile.
        And remove useWelcomeMessage unless you control start modules manually.
        • N Offline
          Newbie007
          Do you mean I should change like this in config.js file?
          //useWelcomeMessage: "brief today",
          				profiles: {
          					"computer" : {
          						lang: "en-IN"
                                         profiles: {
          					"smart_mirror" : {
          						lang: "en-IN"
            @Newbie007
            First, what was wrong was that you are using the configuration for MMM-Hotword 1.X. It is updated to 2.X, so you should use https://github.com/eouia/MMM-AssistantMk2/wiki/Configuration#with-mmm-hotwordv2
            • N Offline
              Newbie007 @Guest
              @Sean yes this worked thanks!
              I didn’t even realise the first config was for v1
                chassain 0
                after some difficults this module works…but i can’t use hotword jarvis as model (snowboy and computer are ok)…what 's the difference ?
                  A Former User @chassain 0
                  @chassain-0
                  Some of the voice models of snowboy sometimes looks weird. Jarvis is one example.
                  They put the 2 voice patterns in one model(“jarvis.umdl”), so you should use like this;
                  https://github.com/eouia/MMM-Hotword/blob/master/documents/models.md
                  Or you can assign a different identifier to each pattern like this;
                    hotwords: ["jarvis_1", "jarvis_2"],
                    file: "jarvis.umdl",
                    sensitivity: "0.8,0.8",
