    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 70.5k Views 28 Watching
    • makepluscodeM Offline
      makepluscode
      This guide is about how to install google assistant and magic mirror on latest raspbian.
      I had some errors, so I made a video to share it, https://youtu.be/UBgH5hejYtM
      And Here is github for this, https://github.com/makepluscode/rpi-tutorial-advanced/blob/master/006-raspbian-magicmirror-google-assistant-latest/
      Dependency Versions
      1. OS : 2018-11-13-raspbian-stretch-full.img
      2. MagicMirror2 : 2.5.0
      3. MMM-Hotword : 1.1.0
      4. MMM-AssistantMk2 : 2.1.2
      Install
      STEP1. Rasbian installation
      1. Download the latest image from the RazBian website. (2018-11-13-raspbian)
      2. Download Rufus to write images to SD card.
      3. Run Rufus and select the downloaded image to burn the SD card.
      STEP2. Insert SD card + LCD + Power connection
      1. Insert SD card and keyboardㆍmouse dongle into raspberry pi.
      2. Connect LCD to raspberry pi on HDMI.
      STEP3. First Boot
      1. Connect the USB power cable to the raspberry pi
      2. After boot is done, connect to the Internet with WIFI
      3. Update packages
      sudo apt-get update
      STEP4. Installing a Magic Mirror
      1. Install the Magic Mirror using a script on the Internet
      sudo apt-get install npm
      sudo npm install -g npm@latest
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      STEP5. Installing Magic Mirror Modules
      1. Go to modules directory and install the MMM-Hotword
      cd ~/MagicMirror/modules/
      sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
      git clone https://github.com/eouia/MMM-Hotword.git
      cd MMM-Hotword
      npm install
      cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
      npm install --save-dev electron-rebuild
      npm install nan
      ./node_modules/.bin/electron-rebuild
      1. Install MMM-AssistantMk2
      sudo apt-get install mpg321 libasound2-dev
      git clone https://github.com/eouia/MMM-AssistantMk2
      cd MMM-AssistantMk2
      npm install
      cd scripts
      chmod +x *.sh
      cd ~/MagicMirror/modules/MMM-AssistantMk2
      STEP6. Configure Google Assistant Module
      1. Open the Google Action Console and create a new project
      https://console.actions.google.com
      1. Open the Google Cloud Platform Console and select the generated project
      https://console.cloud.google.com
      1. Search for the Google Assistant API and click Enable.
      2. Click CONFIGURE … of Credentials and put the name and e-mail.
      3. Generate Other credentials with the OAuth Client ID in Create Credentials
      4. Download generated OAuth client ID in json format
      5. Move the downloaded OAuth client ID to modules/MMM-AssistantMk2/credentials.json
      mv ~/Download/cre.... credentials.json
      1. Run auth_and_test.js to verify the generated client ID
      node auth_and_test.js
      1. Accept the client verification process and copy and enter your Google account key
      2. Move the generated token.json
      mv token.json ./profiles/default.json
      STEP7. Edit Google assistant module config
      1. Open the Magic Mirror configuration file with TextEditor and modify it with the contents of github
      Install USB Mic. and Speaker
      https://github.com/makepluscode/rpi-tips/tree/master/001-bringup-audio-and-mic
      vi ~/.asoundrc
      pcm.!default{
        type asym
        playback.pcm{
          type hw
          card 0
        capture.pcm{
          type plug
          slave.pcm "hw:1, 0"
      ctl.!default{
        type hw
        card 0
      And, change audio output from hdmi to analog.
      Test
      Go to the location where the Magic Mirror is and start the application
      cd ~/MagicMirror
      npm start
      Video Tutorial
      F O M 3 Replies Last reply Reply Quote 2
      • N Offline
        numb3rs
        Wow this is a great tutorial, and video. I am going to add this to my mirror. Can I ask where you got your USB mic and speaker combo from?
        I especially liked how you showed the troubleshooting, and corrections in your video. So many people edit out the hurdles. Kudos to you my friend! A++
        • L Offline
          leej00
          Thank you for the elaborate instructions, everything for me went well until I’ve noticed that the default modules (calendar, complements, news feed) seem to disappear after some time. Did you run into similar issues?
          B N 2 Replies Last reply Reply Quote 0
            bachoo786 @leej00
            @leej00 hello mate
            how did you configure the last part i.e.
            STEP7. EDIT GOOGLE ASSISTANT MODULE CONFIG
            there is soo much information on github that needs to be added on to the config.js, which part of it did you add to your config.js? can you please share it?
            I get the google icon on my mm but when I say “Ok Google” nothing happens"
            Thanks.
            • N Offline
              numb3rs
              A few things you can do:
              Add your location inside the config.js under the module call. You can find this info inside the CONFIGURATION.md
              i.e.
              // — ESSENTIALS / modifying for your environment might be needed.
              Use: https://www.mapdevelopers.com/geocode_tool.php
              deviceLocation: {
                coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                  latitude: 00.0, // -90.0 - +90.0
                  longitude: -00.00, // -180.0 - +180.0
              With MMM-Hotword, using USB mic (plughw:1) you need to use the following:
              //Hotword Module
                  module: "MMM-Hotword",
                    record: {
                      recordProgram : "arecord",
                      device        : "plughw:1",
                    autostart:true,
                    onDetected: {
                      notification: function (payload) {
                        return "ASSISTANT_ACTIVATE"
                      payload: function (payload){
                        return {
                          profile: payload.hotword
              		module: "MMM-AssistantMk2",
              		position: "bottom_bar",
              		record: {
                    notifications: {
                      ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                      ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
              deviceLocation: {
                      latitude: 00.00, // -90.0 - +90.0
              It works. Thank You! I am using the PS Eye as suggested in other forms. My audio out is still set to HDMI because im staging on my TV.
              LPT: Add the following to the MK2 module config so the screens dont toggle so fast:
              screenDuration: 5000, //this is milliseconds
              • N Offline
                numb3rs @leej00
                @leej00
                Testing this now to see if I get the same results.
                @makepluscode
                Can confirm all modules disappear besides the default weather module.
                I have a YouTube playlist playing, and I can still hear the module playing through the speakers, but visually it is no longer there.
                If I give it a keyword voice command it is listening for it will draw the modules again.
                Another observation is every time I give it a voice command it starts my playlist from the top.
                • N Offline
                  numb3rs
                  @bachoo786 say “smart mirror” or “snowboy”
                  You can also read more on the .umdl and how to obtain a custom .umdl here:
                  snowboy.kitt.ai
                  More particularly:
                  http://docs.kitt.ai/snowboy/#api-v1-train
                    Jmh474
                    This post is deleted!
                    • F Offline
                      Fabian @makepluscode
                      @makepluscode
                      Hello first of all thanks for the great tutorial!
                      Unfortunately I’m stuck with the last step (installation of the microphone)
                      When I enter the command “vi ~/.asoundrc” I get the following message:
                      I ask for help
                      Greeting Fabian
                        Sahil @Fabian
                        @Fabian
                        Type sudo nano. asoundrc in command prompt
                        Then paste your code there.
                        To save that code press ctrl+X, then Y and then enter.
                        You are good to go
                        1 Reply Last reply Reply Quote -1
                          dxfan227
                          So In Your Opinion is MMM Hotword and MMM-assistankmk2 the best combo for google assistant?
                          I see a few other modules like MMM-GoogleAssistant out there too
                            siddhartha
                            pcm.!default {
                            type asym
                            capture.pcm “mic”
                            playback.pcm “speaker”
                            pcm.mic {
                            type plug
                            slave {
                            pcm “hw:1,0”
                            pcm.speaker {
                            type plug
                            slave {
                            pcm “hw:0,1”
                            This is my asoundrc conf but i want to change conf like this
                            defaults.pcm.!card
                            defaults.ctl.!card
                            screencast and google assistant both want diffrent asoundrc so any suggetions ??
                            Thank you.
                            i am noob at this so sorry in advance for dumb question…
                            Thank you for your reply 🙂
                            • O Offline
                              otto
                              • O Offline
                                otto @makepluscode
                                @makepluscode
                                https://pastebin.com/cBFMG7ak
                                i got this… what sholde i do?
                                • H Offline
                                  harrycool25
                                  An amazing guide! Thanks a lot. Got the mirror and the google assistant module up an running well, with a few issues that I will address here.
                                  So, overall, everything is VERRY LAGGY- from audio, video, animation and update rate. I was told to downgrade MM from 2.9.0 down to 2.1.0, but have no idea how. Any help please. And the google assistant, when asked about some specific things like direction or information on the web, it just shows the URL for like a split second, then stop. Anyway I can display this on my phone, like idk connect the module to my phone in any way?
                                  Please help. I’ve been struggling with this for 4 weeks already and it’s starting to br a major annoyance :(
                                    Ayos53
                                    Excuse me but i have a problem in your tutoriel : step 5 point 1.
                                    when you ask to go :
                                    I havent folder node module. When i “npm install” in MMM-hotword i have :
                                    npm notice created a lockfile as package-lock.json. You should commit this file.
                                    npm WARN MMM-Hotword@2.0.1 No repository field.
                                      sdetweil @Ayos53
                                      @Ayos53 said in The latest Install Guide (MM w/ Google Assistant):
                                      its node_modules (note the trailing s)…
                                      it will be there if you ran npm install in the MMM-Hotword folder as required by the install instructions (the install.sh script does this)
                                        Ayos53
                                        Sorry it’s me again.
                                        I have a problem when i launch magicmiror, he crashed.
                                        The log file :
                                        1 warn npm npm does not support Node.js v10.15.2
                                        2 warn npm You should probably upgrade to a newer version of node as we
                                        3 warn npm can't make any promises that npm will work with this version.
                                        4 warn npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                                        5 warn npm You can find the latest version at https://nodejs.org/
                                        6 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                        7 info using npm@5.8.0
                                        8 info using node@v10.15.2
                                        9 verbose run-script [ 'prestart', 'start', 'poststart' ]
                                        10 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
                                        11 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
                                        12 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
                                        13 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                        14 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
                                        15 silly lifecycle magicmirror@2.9.0~start: Args: [ '-c', 'sh run-start.sh' ]
                                        16 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                                        17 verbose stack Error: magicmirror@2.9.0 start: `sh run-start.sh`
                                        17 verbose stack spawn ENOENT
                                        17 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                                        17 verbose stack     at ChildProcess.emit (events.js:189:13)
                                        17 verbose stack     at maybeClose (internal/child_process.js:970:16)
                                        17 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                        18 verbose pkgid magicmirror@2.9.0
                                        19 verbose cwd /home/pi/MagicMirror
                                        20 verbose Linux 4.19.75-v7l+
                                        21 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                        22 verbose node v10.15.2
                                        23 verbose npm  v5.8.0
                                        24 error file sh
                                        25 error code ELIFECYCLE
                                        26 error errno ENOENT
                                        27 error syscall spawn
                                        28 error magicmirror@2.9.0 start: `sh run-start.sh`
                                        28 error spawn ENOENT
                                        29 error Failed at the magicmirror@2.9.0 start script.
                                        29 error This is probably not a problem with npm. There is likely additional logging output above.
                                        30 verbose exit [ 1, true ]
                                        If someone have an idea ?
                                          sdetweil @Ayos53
                                          seems a file is missing, please do
                                          ls /home/pi/MagicMirror/run-start.sh
                                          you should see this result
                                          pi@raspberrypi:~ $ ls /home/pi/MagicMirror/run-start.sh
                                          it is part of the git clone distribution and never changed
                                            Ayos53 @sdetweil
                                            i do
                                            and yes i have this result
                                            but always crash after 1 seconde
                                            i see this :
                                            > magicmirror@2.9.0 start /home/pi/MagicMirror
                                            > sh run-start.sh
                                            Starting MagicMirror: v2.9.0
                                            Loading config ...
                                            Loading module helpers ...
                                            Module helper loaded: MMM-NetworkConnection
                                            Module helper loaded: MMM-Hotword
                                            Module helper loaded: MMM-AssistantMk2
                                            All module helpers loaded.
                                            Server started ...
                                            Starting module: newsfeed
                                            Connecting socket for: MMM-NetworkConnection
                                            MMM-NetworkConnection helper started ...
                                            Connecting socket for: MMM-Hotword
                                            [HOTWORD] MMM-Hotword starts
                                            Connecting socket for: MMM-AssistantMk2
                                            Launching application.
                                            Create new news fetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
                                            [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                                            [AMK2] Recipe is loaded: reboot.js
                                            [AMK2] Recipe is loaded: screen_onoff.js
                                            [AMK2] Recipe is loaded: shutdown.js
                                            [HOTWORD] No model to load
                                            [AMK2] Temporal storage directory is clearing.
                                            [AMK2] assistant ready
                                            /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                                            npm ERR! file sh
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno ENOENT
                                            npm ERR! syscall spawn
                                            npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                                            npm ERR! spawn ENOENT
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.9.0 start script.
                                            npm ERR!     /home/pi/.npm/_logs/2019-12-04T14_51_36_364Z-debug.log
                                            • 1 / 4
