    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 61.4k Views 28 Watching
      dish67
      I went to test auth_and_test.js
      pi@MagicMirror:~/MagicMirror/modules/MMM-AssistantMk2 $ node auth_and_test.js
      Opening OAuth URL. Return here with your code.
      Paste your code:
      How // where can I get my code
      I close my google page and re-open my google page and can not see
      to Accept the client verification process etc…
      do you have solution
      thank you
      • K Offline
        karthik.nandam @Guest
        @Sean
        I’ve a same problem post installing the Assistant MK2 i dont see audio bar.
        I’m tring to locate the docusments to install Hotword and MK2 but couldn’t, is it possible for you to share the link to find the documents please
          dyard
          @makepluscode said in The latest Install Guide (MM w/ Google Assistant):
          mv token.json ./profiles/default.json
          Nice post, im having a few issues finding directories like this. Do I create it if I cant find it?
            sdetweil @dyard
            @dyard token.json should be in the folder where u ran the node auth_and_test.js
              MinhTran @makepluscode
              This post is deleted!
                MinhTran @MinhTran
                  dyard @sdetweil
                  @sdetweil Thanks, I ended up starting over with this module. When I go through the steps the MMM hot word module asks me for username and password I think this may have been my issue. Is there a way to down load this to get past this step?
                    sdetweil @dyard
                    @dyard sign up for a free GitHub userid
                      dyard @sdetweil
                      @sdetweil im signed up and used my login but says authentication failed.let me try again.Thanks
                      • ? Offline
                        A Former User
                        wow … this tutorial is outdated … it’s have been write in 2018 !
                        Hello … we are in 2020 … some code have moving … some code have been deleted, archive or just in private !
                        check Forum for another module because MMM-Hotword is DELETED and MMM-AssistantMk2 is Downgraded to Audio output ONLY
                        the best way is READING the developer github source and NOT any tutorial in the web.
                        Any tutorial is available for CURRENT version of the tutorial have be written and not AFTER ! (Source Code change, install method change)
                        • 6
                        • 7
                        • 5 / 7
