    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 74.1k Views 28 Watching
      sdetweil @Ayos53
      @Ayos53 said in The latest Install Guide (MM w/ Google Assistant):
      home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
      that is the error
      this is a known problem, one of the services the module depends on has a bug,
      @Sean will need to give the answer, as I don’t see a specific set of steps to resolve it
      the ‘fix’ is to downgrade the grpc module to version 1.23 (from 1.24 u are on now)
        Ayos53 @sdetweil
        ok no problem but, i don’t know how do this
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @Ayos53
          @Ayos53 me either… there are a number of steps, but I don’t know them all
          thats why we need @Sean help
          • ? Offline
            [[global:former-user]] @Ayos53
            @Ayos53
            read this
            https://github.com/eouia/MMM-AssistantMk2/tree/master#some-more-troubleshooting
            first part of “some more troubleshooting”
              Ayos53 @sdetweil
              Its ok now i follow this post :
              https://github.com/eouia/MMM-AssistantMk2/issues/231
              Now the mirror start without error.
              I have a new problem : the assistant not respond when i say “jarvis”
              but if i click on the logo, it’s ok.
              Problem with Hotword ?
                jims
                Hello ! I have a problem with this topic haha I install all in my magic mirror, but I don’t have a icon google assistant on my screen…
                Everythings is ok until step 7. I test with the command “node auth_and_test.js” and it’s okay. I don’t understand why I don’t have icon google on my screen…
                Can you help me please? how can I check ?
                Sorry for my english, I’m french :P
                			module: "MMM-Hotword",
                				record: {
                					recordProgram : "arecord",
                					device        : "plughw:1"
                				autostart:true,
                				onDetected: {
                					notification: (payload) => {
                					return "ASSISTANT_ACTIVATE"
                					payload: (payload) => {
                						return {
                						  profile: payload.hotword
                			module: "MMM-AssistantMk2",
                			position: "bottom_bar",
                				deviceLocation: {
                					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                					latitude: 45.5662672, // -90.0 - +90.0
                					longitude: 5.9203636, // -180.0 - +180.0
                				record: {
                					device        : "plughw:1",
                				notifications: {
                					ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                					ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                				useWelcomeMessage: "brief today",
                				profiles: {
                					"default" : {
                						lang: "en-US"
                • ? Offline
                  [[global:former-user]] @jims
                  @jims
                  You are using V2 configuration. It was updated recently to V3. Read the docs of MMM-Hotword and MMM-AssistantMk2.
                  J K 2 Replies Last reply Reply Quote 0
                    jims @Guest
                    @Sean said in The latest Install Guide (MM w/ Google Assistant):
                    MMM-Hotword
                    Ok thanks for your reply. So I have to install Hotword and AssistantMk2 in V3. I have to remove the older before ?
                    Thanks!
                    • ? Offline
                      @jims
                      For AMK2, backup your credentials.json and profiles. Then, remove old one, reinstall freshly. (Don’t worry, It becomes easier with new installer)
                      For Hotword, I think git pull would be enough, but if you want, reinstall freshly.
                        jims @Guest
                        @Sean Thanks! I test and I will tell you if everithings it’s okay!
                          MilkShake
                          Hi Huys, I am trying to follow this guide however I have trouble finding some of the folders after the install.
                          In Step 5: The path ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy does not exist. I found Snowboy in ~/MagicMirror/modules/MMM-Hotword/snowboy instead.
                          In Step 5 after installing the assistant, I cannot find the folder scripts in ~/MagicMirror/modules/MMM-AssistantMk2 to make them executable.
                          Does anyone have an idea why that could be? I am running the latest Rasbian Buster distribution.
                          Best Regards
                          MilkShake
                          • ? Offline
                            [[global:former-user]] @MilkShake
                            @MilkShake
                            MM and modules are changed often. So In some cases; following original instruction would be another way.
                            For MMM-Hotword and MMM-AssistantMk2, It was updated recently… (almost 1~2 months ago). Go to each repository, Read the docs, and follow the instruction to install.
                              MilkShake @Guest
                              @Sean Ok, Thank you dude. I will put more effort into it :)
                                jims
                                @Sean Hi Sean. At the moment, i have time to test google assistant haha So, I update Hotword and Assistant Mk2 in V3. But, it doesn’t work… I don’t have the icon google assistant on my screen…
                                Can you help me please ?
                                • ? Offline
                                  @jims
                                  Change your configuration. probably you are using old ones for both modules.
                                    jims @Guest
                                    @Sean
                                    I use this, but I don’t know if it’s okay
                                    				record: {
                                    					device        : "plughw:1"
                                    				autostart:true,
                                    				onDetected: {
                                    						return {
                                    			  position: "fullscreen_above",
                                    				ui: "Fullscreen",
                                    				assistantConfig: {
                                    				  latitude: 45.56667,
                                    				  longitude: 5.93333,
                                    				micConfig: { // put there configuration generated by auto-installer
                                    				  recorder: "arecord",
                                    				  device: "plughw:1",
                                    				recipes: [ "with-MMM-Hotword.js" ],
                                    				profiles: {
                                    				  "default": {
                                    					profileFile: "default.json",
                                    					lang: "en-US"
                                    				addons: false,
                                    • ? Offline
                                      @jims
                                      I said both modules. :) Reconfigure Hotword also. Follow the instructions of wiki. (There might be for V3 configuration sample somewhere)
                                      J 2 Replies Last reply Reply Quote 0
                                        jims @Guest
                                        @Sean sorry
                                        ok thanks. But I use this url :
                                        https://github.com/eouia/MMM-AssistantMk2/blob/7406bac00cfed1d1b9783ab2b11b7c54fc515cc9/documents/config_sample.md
                                        and now, google assistant it’s ok when i said “smartmirror”
                                        BUT , a google accunt window open to put the google projet and the google window give me a connexion key.
                                        But, I already do this step before, with node auth_and_test.js and I don’t understand…
                                          jims @Guest
                                          @Sean everythings it s ok! it s work! just renew the credentiel and the key :)
                                          • H Offline
                                            HaveFunToLearn
                                            This post is deleted!
                                            • 2 / 4
