    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 76.6k Views 28 Watching
    • O
      otto @makepluscode
      @makepluscode
      https://pastebin.com/cBFMG7ak
      i got this… what sholde i do?
      • H
        harrycool25
        An amazing guide! Thanks a lot. Got the mirror and the google assistant module up an running well, with a few issues that I will address here.
        So, overall, everything is VERRY LAGGY- from audio, video, animation and update rate. I was told to downgrade MM from 2.9.0 down to 2.1.0, but have no idea how. Any help please. And the google assistant, when asked about some specific things like direction or information on the web, it just shows the URL for like a split second, then stop. Anyway I can display this on my phone, like idk connect the module to my phone in any way?
        Please help. I’ve been struggling with this for 4 weeks already and it’s starting to br a major annoyance :(
        • A
          Ayos53
          Excuse me but i have a problem in your tutoriel : step 5 point 1.
          when you ask to go :
          cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          I havent folder node module. When i “npm install” in MMM-hotword i have :
          npm notice created a lockfile as package-lock.json. You should commit this file.
          npm WARN MMM-Hotword@2.0.1 No repository field.
            sdetweil @Ayos53
            @Ayos53 said in The latest Install Guide (MM w/ Google Assistant):
            its node_modules (note the trailing s)…
            it will be there if you ran npm install in the MMM-Hotword folder as required by the install instructions (the install.sh script does this)
            • A
              Ayos53
              Sorry it’s me again.
              I have a problem when i launch magicmiror, he crashed.
              The log file :
              1 warn npm npm does not support Node.js v10.15.2
              2 warn npm You should probably upgrade to a newer version of node as we
              3 warn npm can't make any promises that npm will work with this version.
              4 warn npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
              5 warn npm You can find the latest version at https://nodejs.org/
              6 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
              7 info using npm@5.8.0
              8 info using node@v10.15.2
              9 verbose run-script [ 'prestart', 'start', 'poststart' ]
              10 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
              11 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
              12 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
              13 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              14 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
              15 silly lifecycle magicmirror@2.9.0~start: Args: [ '-c', 'sh run-start.sh' ]
              16 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
              17 verbose stack Error: magicmirror@2.9.0 start: `sh run-start.sh`
              17 verbose stack spawn ENOENT
              17 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
              17 verbose stack     at ChildProcess.emit (events.js:189:13)
              17 verbose stack     at maybeClose (internal/child_process.js:970:16)
              17 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              18 verbose pkgid magicmirror@2.9.0
              19 verbose cwd /home/pi/MagicMirror
              20 verbose Linux 4.19.75-v7l+
              21 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
              22 verbose node v10.15.2
              23 verbose npm  v5.8.0
              24 error file sh
              25 error code ELIFECYCLE
              26 error errno ENOENT
              27 error syscall spawn
              28 error magicmirror@2.9.0 start: `sh run-start.sh`
              28 error spawn ENOENT
              29 error Failed at the magicmirror@2.9.0 start script.
              29 error This is probably not a problem with npm. There is likely additional logging output above.
              30 verbose exit [ 1, true ]
              If someone have an idea ?
                sdetweil @Ayos53
                seems a file is missing, please do
                ls /home/pi/MagicMirror/run-start.sh
                you should see this result
                pi@raspberrypi:~ $ ls /home/pi/MagicMirror/run-start.sh
                it is part of the git clone distribution and never changed
                A 1 Reply Last reply
                • A
                  Ayos53 @sdetweil
                  i do
                  and yes i have this result
                  but always crash after 1 seconde
                  i see this :
                  > magicmirror@2.9.0 start /home/pi/MagicMirror
                  > sh run-start.sh
                  Starting MagicMirror: v2.9.0
                  Loading config ...
                  Loading module helpers ...
                  Module helper loaded: MMM-NetworkConnection
                  Module helper loaded: MMM-Hotword
                  Module helper loaded: MMM-AssistantMk2
                  All module helpers loaded.
                  Server started ...
                  Starting module: newsfeed
                  Connecting socket for: MMM-NetworkConnection
                  MMM-NetworkConnection helper started ...
                  Connecting socket for: MMM-Hotword
                  [HOTWORD] MMM-Hotword starts
                  Connecting socket for: MMM-AssistantMk2
                  Launching application.
                  Create new news fetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
                  [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                  [AMK2] Recipe is loaded: reboot.js
                  [AMK2] Recipe is loaded: screen_onoff.js
                  [AMK2] Recipe is loaded: shutdown.js
                  [HOTWORD] No model to load
                  [AMK2] Temporal storage directory is clearing.
                  [AMK2] assistant ready
                  /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                  npm ERR! file sh
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.9.0 start script.
                  npm ERR!     /home/pi/.npm/_logs/2019-12-04T14_51_36_364Z-debug.log
                    sdetweil @Ayos53
                    that is the error
                    this is a known problem, one of the services the module depends on has a bug,
                    @Sean will need to give the answer, as I don’t see a specific set of steps to resolve it
                    the ‘fix’ is to downgrade the grpc module to version 1.23 (from 1.24 u are on now)
                    • A
                      Ayos53 @sdetweil
                      ok no problem but, i don’t know how do this
                      S ? 2 Replies Last reply
                        sdetweil @Ayos53
                        @Ayos53 me either… there are a number of steps, but I don’t know them all
                        thats why we need @Sean help
                          A Former User @Ayos53
                          @Ayos53
                          read this
                          https://github.com/eouia/MMM-AssistantMk2/tree/master#some-more-troubleshooting
                          first part of “some more troubleshooting”
                          • A
                            Ayos53 @sdetweil
                            Its ok now i follow this post :
                            https://github.com/eouia/MMM-AssistantMk2/issues/231
                            Now the mirror start without error.
                            I have a new problem : the assistant not respond when i say “jarvis”
                            but if i click on the logo, it’s ok.
                            Problem with Hotword ?
                              jims
                              Hello ! I have a problem with this topic haha I install all in my magic mirror, but I don’t have a icon google assistant on my screen…
                              Everythings is ok until step 7. I test with the command “node auth_and_test.js” and it’s okay. I don’t understand why I don’t have icon google on my screen…
                              Can you help me please? how can I check ?
                              Sorry for my english, I’m french :P
                              			module: "MMM-Hotword",
                              				record: {
                              					recordProgram : "arecord",
                              					device        : "plughw:1"
                              				autostart:true,
                              				onDetected: {
                              					notification: (payload) => {
                              					return "ASSISTANT_ACTIVATE"
                              					payload: (payload) => {
                              						return {
                              						  profile: payload.hotword
                              			module: "MMM-AssistantMk2",
                              			position: "bottom_bar",
                              				deviceLocation: {
                              					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                              					latitude: 45.5662672, // -90.0 - +90.0
                              					longitude: 5.9203636, // -180.0 - +180.0
                              				record: {
                              					device        : "plughw:1",
                              				notifications: {
                              					ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                              					ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                              				useWelcomeMessage: "brief today",
                              				profiles: {
                              					"default" : {
                              						lang: "en-US"
                              ? 1 Reply Last reply
                                A Former User @jims
                                @jims
                                You are using V2 configuration. It was updated recently to V3. Read the docs of MMM-Hotword and MMM-AssistantMk2.
                                J K 2 Replies Last reply
                                  jims @Guest
                                  @Sean said in The latest Install Guide (MM w/ Google Assistant):
                                  MMM-Hotword
                                  Ok thanks for your reply. So I have to install Hotword and AssistantMk2 in V3. I have to remove the older before ?
                                  Thanks!
                                    A Former User @jims
                                    @jims
                                    For AMK2, backup your credentials.json and profiles. Then, remove old one, reinstall freshly. (Don’t worry, It becomes easier with new installer)
                                    For Hotword, I think git pull would be enough, but if you want, reinstall freshly.
                                    J 1 Reply Last reply
                                      jims @Guest
                                      @Sean Thanks! I test and I will tell you if everithings it’s okay!
                                        MilkShake
                                        Hi Huys, I am trying to follow this guide however I have trouble finding some of the folders after the install.
                                        In Step 5: The path ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy does not exist. I found Snowboy in ~/MagicMirror/modules/MMM-Hotword/snowboy instead.
                                        In Step 5 after installing the assistant, I cannot find the folder scripts in ~/MagicMirror/modules/MMM-AssistantMk2 to make them executable.
                                        Does anyone have an idea why that could be? I am running the latest Rasbian Buster distribution.
                                        Best Regards
                                        MilkShake
                                          A Former User @MilkShake
                                          @MilkShake
                                          MM and modules are changed often. So In some cases; following original instruction would be another way.
                                          For MMM-Hotword and MMM-AssistantMk2, It was updated recently… (almost 1~2 months ago). Go to each repository, Read the docs, and follow the instruction to install.
                                          M 1 Reply Last reply
                                            MilkShake @Guest
                                            @Sean Ok, Thank you dude. I will put more effort into it :)
                                            • 2 / 4
