    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 75.7k Views 28 Watching
    • A
      Ayos53 @sdetweil
      Its ok now i follow this post :
      https://github.com/eouia/MMM-AssistantMk2/issues/231
      Now the mirror start without error.
      I have a new problem : the assistant not respond when i say “jarvis”
      but if i click on the logo, it’s ok.
      Problem with Hotword ?
        jims
        Hello ! I have a problem with this topic haha I install all in my magic mirror, but I don’t have a icon google assistant on my screen…
        Everythings is ok until step 7. I test with the command “node auth_and_test.js” and it’s okay. I don’t understand why I don’t have icon google on my screen…
        Can you help me please? how can I check ?
        Sorry for my english, I’m french :P
        			module: "MMM-Hotword",
        				record: {
        					recordProgram : "arecord",
        					device        : "plughw:1"
        				autostart:true,
        				onDetected: {
        					notification: (payload) => {
        					return "ASSISTANT_ACTIVATE"
        					payload: (payload) => {
        						return {
        						  profile: payload.hotword
        			module: "MMM-AssistantMk2",
        			position: "bottom_bar",
        				deviceLocation: {
        					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
        					latitude: 45.5662672, // -90.0 - +90.0
        					longitude: 5.9203636, // -180.0 - +180.0
        				record: {
        					device        : "plughw:1",
        				notifications: {
        					ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
        					ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
        				useWelcomeMessage: "brief today",
        				profiles: {
        					"default" : {
        						lang: "en-US"
          A Former User @jims
          @jims
          You are using V2 configuration. It was updated recently to V3. Read the docs of MMM-Hotword and MMM-AssistantMk2.
          J K 2 Replies Last reply Reply Quote 0
            jims @Guest
            @Sean said in The latest Install Guide (MM w/ Google Assistant):
            MMM-Hotword
            Ok thanks for your reply. So I have to install Hotword and AssistantMk2 in V3. I have to remove the older before ?
            Thanks!
              A Former User @jims
              @jims
              For AMK2, backup your credentials.json and profiles. Then, remove old one, reinstall freshly. (Don’t worry, It becomes easier with new installer)
              For Hotword, I think git pull would be enough, but if you want, reinstall freshly.
                jims @Guest
                @Sean Thanks! I test and I will tell you if everithings it’s okay!
                  MilkShake
                  Hi Huys, I am trying to follow this guide however I have trouble finding some of the folders after the install.
                  In Step 5: The path ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy does not exist. I found Snowboy in ~/MagicMirror/modules/MMM-Hotword/snowboy instead.
                  In Step 5 after installing the assistant, I cannot find the folder scripts in ~/MagicMirror/modules/MMM-AssistantMk2 to make them executable.
                  Does anyone have an idea why that could be? I am running the latest Rasbian Buster distribution.
                  Best Regards
                  MilkShake
                    A Former User @MilkShake
                    @MilkShake
                    MM and modules are changed often. So In some cases; following original instruction would be another way.
                    For MMM-Hotword and MMM-AssistantMk2, It was updated recently… (almost 1~2 months ago). Go to each repository, Read the docs, and follow the instruction to install.
                      MilkShake @Guest
                      @Sean Ok, Thank you dude. I will put more effort into it :)
                        jims
                        @Sean Hi Sean. At the moment, i have time to test google assistant haha So, I update Hotword and Assistant Mk2 in V3. But, it doesn’t work… I don’t have the icon google assistant on my screen…
                        Can you help me please ?
                          A Former User @jims
                          @jims
                          Change your configuration. probably you are using old ones for both modules.
                            jims @Guest
                            @Sean
                            I use this, but I don’t know if it’s okay
                            				record: {
                            					device        : "plughw:1"
                            				autostart:true,
                            				onDetected: {
                            						return {
                            			  position: "fullscreen_above",
                            				ui: "Fullscreen",
                            				assistantConfig: {
                            				  latitude: 45.56667,
                            				  longitude: 5.93333,
                            				micConfig: { // put there configuration generated by auto-installer
                            				  recorder: "arecord",
                            				  device: "plughw:1",
                            				recipes: [ "with-MMM-Hotword.js" ],
                            				profiles: {
                            				  "default": {
                            					profileFile: "default.json",
                            					lang: "en-US"
                            				addons: false,
                              A Former User @jims
                              @jims
                              I said both modules. :) Reconfigure Hotword also. Follow the instructions of wiki. (There might be for V3 configuration sample somewhere)
                                jims @Guest
                                @Sean sorry
                                ok thanks. But I use this url :
                                https://github.com/eouia/MMM-AssistantMk2/blob/7406bac00cfed1d1b9783ab2b11b7c54fc515cc9/documents/config_sample.md
                                and now, google assistant it’s ok when i said “smartmirror”
                                BUT , a google accunt window open to put the google projet and the google window give me a connexion key.
                                But, I already do this step before, with node auth_and_test.js and I don’t understand…
                                  jims @Guest
                                  @Sean everythings it s ok! it s work! just renew the credentiel and the key :)
                                  • H
                                    HaveFunToLearn
                                      dish67
                                      I went to test auth_and_test.js
                                      pi@MagicMirror:~/MagicMirror/modules/MMM-AssistantMk2 $ node auth_and_test.js
                                      Opening OAuth URL. Return here with your code.
                                      Paste your code:
                                      How // where can I get my code
                                      I close my google page and re-open my google page and can not see
                                      to Accept the client verification process etc…
                                      do you have solution
                                      thank you
                                      • K
                                        karthik.nandam @Guest
                                        @Sean
                                        I’ve a same problem post installing the Assistant MK2 i dont see audio bar.
                                        I’m tring to locate the docusments to install Hotword and MK2 but couldn’t, is it possible for you to share the link to find the documents please
                                          dyard
                                          @makepluscode said in The latest Install Guide (MM w/ Google Assistant):
                                          mv token.json ./profiles/default.json
                                          Nice post, im having a few issues finding directories like this. Do I create it if I cant find it?
                                            sdetweil @dyard
                                            @dyard token.json should be in the folder where u ran the node auth_and_test.js
                                            • 2 / 4
