    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 72.1k Views 28 Watching
      jims @Guest
      @Sean Thanks! I test and I will tell you if everithings it’s okay!
        MilkShake
        Hi Huys, I am trying to follow this guide however I have trouble finding some of the folders after the install.
        In Step 5: The path ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy does not exist. I found Snowboy in ~/MagicMirror/modules/MMM-Hotword/snowboy instead.
        In Step 5 after installing the assistant, I cannot find the folder scripts in ~/MagicMirror/modules/MMM-AssistantMk2 to make them executable.
        Does anyone have an idea why that could be? I am running the latest Rasbian Buster distribution.
        Best Regards
        MilkShake
          A Former User @MilkShake
          @MilkShake
          MM and modules are changed often. So In some cases; following original instruction would be another way.
          For MMM-Hotword and MMM-AssistantMk2, It was updated recently… (almost 1~2 months ago). Go to each repository, Read the docs, and follow the instruction to install.
            MilkShake @Guest
            @Sean Ok, Thank you dude. I will put more effort into it :)
              jims
              @Sean Hi Sean. At the moment, i have time to test google assistant haha So, I update Hotword and Assistant Mk2 in V3. But, it doesn’t work… I don’t have the icon google assistant on my screen…
              Can you help me please ?
                A Former User @jims
                @jims
                Change your configuration. probably you are using old ones for both modules.
                  jims @Guest
                  @Sean
                  I use this, but I don’t know if it’s okay
                  			module: "MMM-Hotword",
                  				record: {
                  					recordProgram : "arecord",
                  					device        : "plughw:1"
                  				autostart:true,
                  				onDetected: {
                  					notification: (payload) => {
                  					return "ASSISTANT_ACTIVATE"
                  					payload: (payload) => {
                  						return {
                  						  profile: payload.hotword
                  			  module: "MMM-AssistantMk2",
                  			  position: "fullscreen_above",
                  				ui: "Fullscreen",
                  				assistantConfig: {
                  				  latitude: 45.56667,
                  				  longitude: 5.93333,
                  				micConfig: { // put there configuration generated by auto-installer
                  				  recorder: "arecord",
                  				  device: "plughw:1",
                  				recipes: [ "with-MMM-Hotword.js" ],
                  				profiles: {
                  				  "default": {
                  					profileFile: "default.json",
                  					lang: "en-US"
                  				addons: false,
                    A Former User @jims
                    @jims
                    I said both modules. :) Reconfigure Hotword also. Follow the instructions of wiki. (There might be for V3 configuration sample somewhere)
                      jims @Guest
                      @Sean sorry
                      ok thanks. But I use this url :
                      https://github.com/eouia/MMM-AssistantMk2/blob/7406bac00cfed1d1b9783ab2b11b7c54fc515cc9/documents/config_sample.md
                      and now, google assistant it’s ok when i said “smartmirror”
                      BUT , a google accunt window open to put the google projet and the google window give me a connexion key.
                      But, I already do this step before, with node auth_and_test.js and I don’t understand…
                        jims @Guest
                        @Sean everythings it s ok! it s work! just renew the credentiel and the key :)
                        • H Offline
                          HaveFunToLearn
                            dish67
                            I went to test auth_and_test.js
                            pi@MagicMirror:~/MagicMirror/modules/MMM-AssistantMk2 $ node auth_and_test.js
                            Opening OAuth URL. Return here with your code.
                            Paste your code:
                            How // where can I get my code
                            I close my google page and re-open my google page and can not see
                            to Accept the client verification process etc…
                            do you have solution
                            thank you
                            • K Offline
                              karthik.nandam @Guest
                              @Sean
                              I’ve a same problem post installing the Assistant MK2 i dont see audio bar.
                              I’m tring to locate the docusments to install Hotword and MK2 but couldn’t, is it possible for you to share the link to find the documents please
                                dyard
                                @makepluscode said in The latest Install Guide (MM w/ Google Assistant):
                                mv token.json ./profiles/default.json
                                Nice post, im having a few issues finding directories like this. Do I create it if I cant find it?
                                  sdetweil @dyard
                                  @dyard token.json should be in the folder where u ran the node auth_and_test.js
                                    MinhTran @makepluscode
                                      MinhTran @MinhTran
                                        dyard @sdetweil
                                        @sdetweil Thanks, I ended up starting over with this module. When I go through the steps the MMM hot word module asks me for username and password I think this may have been my issue. Is there a way to down load this to get past this step?
                                          sdetweil @dyard
                                          @dyard sign up for a free GitHub userid
                                            dyard @sdetweil
                                            @sdetweil im signed up and used my login but says authentication failed.let me try again.Thanks
                                            • 2 / 4
