    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 76.6k Views 28 Watching
    • H
      HaveFunToLearn
        dish67
        I went to test auth_and_test.js
        pi@MagicMirror:~/MagicMirror/modules/MMM-AssistantMk2 $ node auth_and_test.js
        Opening OAuth URL. Return here with your code.
        Paste your code:
        How // where can I get my code
        I close my google page and re-open my google page and can not see
        to Accept the client verification process etc…
        do you have solution
        thank you
        • K
          karthik.nandam @Guest
          @Sean
          I’ve a same problem post installing the Assistant MK2 i dont see audio bar.
          I’m tring to locate the docusments to install Hotword and MK2 but couldn’t, is it possible for you to share the link to find the documents please
            dyard
            @makepluscode said in The latest Install Guide (MM w/ Google Assistant):
            mv token.json ./profiles/default.json
            Nice post, im having a few issues finding directories like this. Do I create it if I cant find it?
              sdetweil @dyard
              @dyard token.json should be in the folder where u ran the node auth_and_test.js
              D 1 Reply Last reply
                MinhTran @makepluscode
                M 1 Reply Last reply
                  MinhTran @MinhTran
                    dyard @sdetweil
                    @sdetweil Thanks, I ended up starting over with this module. When I go through the steps the MMM hot word module asks me for username and password I think this may have been my issue. Is there a way to down load this to get past this step?
                      sdetweil @dyard
                      @dyard sign up for a free GitHub userid
                      D 2 Replies Last reply
                        dyard @sdetweil
                        @sdetweil im signed up and used my login but says authentication failed.let me try again.Thanks
                          A Former User
                          wow … this tutorial is outdated … it’s have been write in 2018 !
                          Hello … we are in 2020 … some code have moving … some code have been deleted, archive or just in private !
                          check Forum for another module because MMM-Hotword is DELETED and MMM-AssistantMk2 is Downgraded to Audio output ONLY
                          the best way is READING the developer github source and NOT any tutorial in the web.
                          Any tutorial is available for CURRENT version of the tutorial have be written and not AFTER ! (Source Code change, install method change)
                            sdetweil @Guest
                            @Bugsounet sorry, i missed that completely!!
                              A Former User
                              no problem sam, it’s not for you ;)
                              hey … maybe some user use again windows 95 or windows 98 (2 years later) ?
                              In all case, windows problem is now solved ! I don’t use it ;)
                                sdetweil @Guest
                                @Bugsounet but. but… i gave incorrect help… not my style!!!
                                  A Former User
                                  LoooOOoooL :)
                                    dyard @sdetweil
                                    @sdetweil Hi sorry for the late response, so I logged in and made sure my account was able to do so. I cant seem to get passed this still.
                                    remote: Repository not found.
                                    fatal: repository ‘https://github.com/eouia/MMM-Hotword.git/’ not found
                                      sdetweil @dyard
                                      @dyard the old MMM_AssistantMk2 and MMM-Hotword have been closed down, as Sean has moved away from MM for personal reasons and @Bugsounet has taken over and produced MMM_GoogleAssistant, which replaces both
                                      • K
                                        kikosilva17
                                        hi, when i try to clone the module, it asks me to enter some github username and password, and gives me a error when i write it down… can anybody help with that??
                                          sdetweil @kikosilva17
                                          @kikosilva17 the old module no longer exists
                                          u need to get it from https://github.com/bugsounet/MMM-GoogleAssistant
                                          bugsounetB 1 Reply Last reply
                                          Reply Quote -1
                                          • bugsounetB
                                            bugsounet Banned @sdetweil
                                            @sdetweil : Grrr … no ads there thx
                                            • 3 / 4
