    The latest Install Guide (MM w/ Google Assistant)
    63 Posts 25 Posters 76.4k Views 28 Watching
      MilkShake @Guest
      @Sean Ok, Thank you dude. I will put more effort into it :)
        jims
        @Sean Hi Sean. At the moment, i have time to test google assistant haha So, I update Hotword and Assistant Mk2 in V3. But, it doesn’t work… I don’t have the icon google assistant on my screen…
        Can you help me please ?
        ? 1 Reply Last reply
          A Former User @jims
          @jims
          Change your configuration. probably you are using old ones for both modules.
          J 1 Reply Last reply
            jims @Guest
            @Sean
            I use this, but I don’t know if it’s okay
            			module: "MMM-Hotword",
            				record: {
            					recordProgram : "arecord",
            					device        : "plughw:1"
            				autostart:true,
            				onDetected: {
            					notification: (payload) => {
            					return "ASSISTANT_ACTIVATE"
            					payload: (payload) => {
            						return {
            						  profile: payload.hotword
            			  module: "MMM-AssistantMk2",
            			  position: "fullscreen_above",
            				ui: "Fullscreen",
            				assistantConfig: {
            				  latitude: 45.56667,
            				  longitude: 5.93333,
            				micConfig: { // put there configuration generated by auto-installer
            				  recorder: "arecord",
            				  device: "plughw:1",
            				recipes: [ "with-MMM-Hotword.js" ],
            				profiles: {
            				  "default": {
            					profileFile: "default.json",
            					lang: "en-US"
            				addons: false,
              A Former User @jims
              @jims
              I said both modules. :) Reconfigure Hotword also. Follow the instructions of wiki. (There might be for V3 configuration sample somewhere)
              J 2 Replies Last reply
                jims @Guest
                @Sean sorry
                ok thanks. But I use this url :
                https://github.com/eouia/MMM-AssistantMk2/blob/7406bac00cfed1d1b9783ab2b11b7c54fc515cc9/documents/config_sample.md
                and now, google assistant it’s ok when i said “smartmirror”
                BUT , a google accunt window open to put the google projet and the google window give me a connexion key.
                But, I already do this step before, with node auth_and_test.js and I don’t understand…
                  jims @Guest
                  @Sean everythings it s ok! it s work! just renew the credentiel and the key :)
                  • H
                    HaveFunToLearn
                      dish67
                      I went to test auth_and_test.js
                      pi@MagicMirror:~/MagicMirror/modules/MMM-AssistantMk2 $ node auth_and_test.js
                      Opening OAuth URL. Return here with your code.
                      Paste your code:
                      How // where can I get my code
                      I close my google page and re-open my google page and can not see
                      to Accept the client verification process etc…
                      do you have solution
                      thank you
                      • K
                        karthik.nandam @Guest
                        @Sean
                        I’ve a same problem post installing the Assistant MK2 i dont see audio bar.
                        I’m tring to locate the docusments to install Hotword and MK2 but couldn’t, is it possible for you to share the link to find the documents please
                          dyard
                          @makepluscode said in The latest Install Guide (MM w/ Google Assistant):
                          mv token.json ./profiles/default.json
                          Nice post, im having a few issues finding directories like this. Do I create it if I cant find it?
                            sdetweil @dyard
                            @dyard token.json should be in the folder where u ran the node auth_and_test.js
                            D 1 Reply Last reply
                              MinhTran @makepluscode
                              M 1 Reply Last reply
                                MinhTran @MinhTran
                                  dyard @sdetweil
                                  @sdetweil Thanks, I ended up starting over with this module. When I go through the steps the MMM hot word module asks me for username and password I think this may have been my issue. Is there a way to down load this to get past this step?
                                    sdetweil @dyard
                                    @dyard sign up for a free GitHub userid
                                    D 2 Replies Last reply
                                      dyard @sdetweil
                                      @sdetweil im signed up and used my login but says authentication failed.let me try again.Thanks
                                        A Former User
                                        wow … this tutorial is outdated … it’s have been write in 2018 !
                                        Hello … we are in 2020 … some code have moving … some code have been deleted, archive or just in private !
                                        check Forum for another module because MMM-Hotword is DELETED and MMM-AssistantMk2 is Downgraded to Audio output ONLY
                                        the best way is READING the developer github source and NOT any tutorial in the web.
                                        Any tutorial is available for CURRENT version of the tutorial have be written and not AFTER ! (Source Code change, install method change)
                                          sdetweil @Guest
                                          @Bugsounet sorry, i missed that completely!!
                                            A Former User
                                            no problem sam, it’s not for you ;)
                                            hey … maybe some user use again windows 95 or windows 98 (2 years later) ?
                                            In all case, windows problem is now solved ! I don’t use it ;)
                                            • 3 / 4
