Solved config
hi and thx again.still no joy and i have poated the latest config```
code_text* * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "GB Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "", locationID: "53.9576", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "76b503a29647f3a01dd9ba1055daea6d", } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "", locationID: "53.9576", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "76b503a29647f3a01dd9ba1055daea6d", } } { module: "newsfeed", position: "bottom_bar", config: feeds: [ { title: "BBC", url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml", } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: false, broadcastNewsUpdates: true, } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
@geo missing the /* as the 1st line
@geo here is the fixed up config
run thru npm run config:check til no errors
missing comma and open {
/* * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "GB Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "", locationID: "53.9576", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "76b503a29647f3a01dd9ba1055daea6d", } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "", locationID: "53.9576", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "76b503a29647f3a01dd9ba1055daea6d", } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "BBC", url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml", } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: false, broadcastNewsUpdates: true, } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-11-16T14_09_4 code_text ``
@geo needs to be done from inside the MagicMirror folder…
@sdetweil hi after another attempt i find the config is empty all that is available is the sample
@geo i posted the corrected config.js above, cut/paste it back into the ~/MagicMiror/config/config.js file
@geo would it be better to delete and re install
@geo no… just missing the config file…
select the text in my post above, right click mouse, select copy,
then open an editor on the file and right click mouse pastei use ssh and BitVise ssh client so I can access and edit files thru my windows machine
@sdetweil hi sorry but i am stuck config.js is empty and cant find text editor
