    Smart Mirror IR Panel
    8 Posts 3 Posters 1.9k Views 2 Watching
      rhino45
      When the IR touch screen panel is connected, loading is repeated indefinitely.
      How to fix ?
      I’m sorry I can’t speak English
      Model 3 b +
      ![alt text](image url)
        sdetweil @rhino45
        @rhino45 use one of the web converters to translate you language text to/from english. it works pretty good…
        anyhow, the constant restart is probably because of pm2…
        do
        pm2 stop 0
        then
        npm start
          rhino45 @sdetweil
          @sdetweil pm2 stop 0
          If i search = bash: pm2: command not found
            rhino45 @sdetweil
            @sdetweil It works fine, but when I connect the USB of the IR panel to the Raspberry Pi, the loading is infinite
              sdetweil @rhino45
              @rhino45 the pi loading is infinite? meaning it reboots??
              usually this is not enough power to do the pi AND the panel…
              need a bigger power supply
                rhino45 @sdetweil
                @sdetweil How much power need?
                  sdetweil @rhino45
                  @rhino45 pi is usually 2 amps… I don’t know how much ir panel takes…
                  I bought an 8 amp power supply
                  • brobergB Offline
                    broberg Project Sponsor
                    Raspberry Pi3 is minimum 2.5A to work well, the more usb stuff you use, the more power is needed.
