    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      code999 @Guest
      @Sean @mrdenmark
      Thanks for both of your help. I got it where I wanted it.
      @Sean Thanks for the module, its great! keep up the good work and awesome support.
        code999
        I do have another question on the ics file. I am using one from a region but it does not seem to work, would you know why?
        i works for google, outlook and others. Thanks
        link… https://recollect.a.ssl.fastly.net/api/places/5C168558-A4F7-11E4-B82A-04208E6A6F5F/services/224/events.en.ics?client_id=B40A0DCC-1138-11EA-87AC-FC5DCE1212EE
          jani.karna
          I really appreciate the module and it is (almost) exactly what I want. I still looking the same thing as @mrmagoo_83 that I could wrap the events in multiple lines when needed.
          Also, is there a way to make events as wide as the column? Now it is slightly narrower. Here’s a picture of what I mean.
          https://www.dropbox.com/s/9iosscweizpthrb/IMG_0603.jpg?dl=0
          Can I also shrink the gap between events vertically somehow?
          ? 1 Reply Last reply
            scuppasteve
            I really like this module and unlike the regular Calendar app is able to deal with DST.
            I have a calendar of just my kids chores to do today. All i want is to display the chores that are today, in the calendar they are all day events. So i would like the “ends in xx hours” to go away altogether ideally, but at worst i would just like it to say “Today”. Also I would like to make the slot background transparent and the slot text white. I know that is in CSS, but don’t see where to make it transparent.
            			module: 'MMM-CalendarExt2',
            				updateInterval: 1000*60*240,
            				calendars : [
            						scanInterval: 1000*60*240,
            						url: "CAL URL",
            			  	views: [
            						mode: "current",
            						hideOverflow: false,
            						slotTitle: "Kid's Chores",
            						slotMaxHeight: "75px",
            						slotCount: 10,
            						maxDays: 1,
            						locale: "en",
            						calendars: ["Chores"],
            			  	scenes: [
              A Former User @jani.karna
              @jani-karna
              1. Slightly narrow event’s width is intentional to avoid margin of error on calculation. It is hardcoded. But if you want to modify it by yourself,
                https://github.com/eouia/MMM-CalendarExt2/blob/a5d509ada997034f91e0790ad72e87512cb24c60/CALEXT2_Slot.js#L250
              eventDom.style.width = width - 15 + "px"
              Change 15 to what you want.
              Tell me more exact details? Even a picture will help.
              J 2 Replies Last reply
                A Former User @scuppasteve
                @scuppasteve
                The default method of displaying time on agenda views(current and upcoming) is defined as relative form. So, you can use just useEventTimeRelative: false, to display event time absolute format.
                But what you want is just removing time of events from specific calendars or specific views, you can control it with CSS.
                For example, when you want to hide time of all events from Chores calendar on current view, try this.
                calendars : [
                    url: "CAL URL",
                    className: "CHORES_CAL"
                Then, add this code to your css/custom.css
                .CX2 .current .CHORES_CAL .eventTime {
                  display:none;
                This means hide eventTime of CHORES_CAL of current view. Of course you can specify your target in other ways.
                And you might need some additional CSS adjustment to beautify the empty area. Try it yourself.
                • BKeyportB
                  BKeyport Module Developer @Guest
                  @Sean - This don’t seem to work. Did I break my code? (line numbers added to show result from error check) - MM won’t start with code enabled - “Please create file”
                  65: transform: (event) => {
                  66:	if (event.title.search("Recycle") > -1) {
                  67:		event.icon = "mdi:recycle",
                  68:	},
                  69:	return event
                  70: },
                  Results in:
                  Checking file...  /home/pi/MagicMirror/config/config.js
                  Line 65 col 46 'arrow function syntax (=>)' is only available in ES6 (use 'esversion: 6').
                  Line 68 col 33 Unexpected '}'.
                  Line 67 col 63 Expected an assignment or function call and instead saw an expression.
                  Line 67 col 64 Missing semicolon.
                  Line 68 col 34 Expected an identifier and instead saw ','.
                  Line 68 col 34 Expected an assignment or function call and instead saw an expression.
                  Line 68 col 35 Missing semicolon.
                  Line 69 col 45 Missing semicolon.
                  Thanks!
                    sdetweil @BKeyport
                    @BKeyport said in MMM-CalendarExt2:
                    “mdi:recycle”,
                    Remove the trailing comma
                    BKeyportB 1 Reply Last reply
                      scuppasteve @Guest
                      @Sean That worked perfectly . How would you go about making the slot event background not be a black gradient? I just want the whole thing to be transparent.
                      C 1 Reply Last reply
                        cskenney
                        @Sean Similar to the Transform method used to identify a keyword in a title and change the icon (birthday is the example) is there a way to do the same thing (identify a key word) and change the color and background-color for that specific item?
                        My example would be if the word “Softball” is found in the title of a calendar entry it would transform the icon to a softball icon (already have this figured out). I also want to change the background-color and possibly the (font) color.
                          jani.karna @Guest
                          • BKeyportB
                            @sdetweil - It gets worse.
                            68: 	},
                            69: 	return event
                            70: },
                            Line 67 col 63 Missing semicolon.
                            0|mm     | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:68
                            0|mm     |                                                              },
                            0|mm     |                                                               ^
                            0|mm     | SyntaxError: Unexpected token ,
                            0|mm     |     at new Script (vm.js:74:7)
                            0|mm     |     at createScript (vm.js:246:10)
                            0|mm     |     at Object.runInThisContext (vm.js:298:10)
                            0|mm     |     at Module._compile (internal/modules/cjs/loader.js:678:28)
                            0|mm     |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                            0|mm     |     at Module.load (internal/modules/cjs/loader.js:620:32)
                            0|mm     |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                            0|mm     |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                            0|mm     |     at Module.require (internal/modules/cjs/loader.js:658:17)
                            0|mm     |     at require (internal/modules/cjs/helpers.js:20:18)
                              sdetweil @BKeyport
                              68: }, < ------- remove THAT trailing comma
                              Line 65 col 46 ‘arrow function syntax (=>)’ is only available in ES6 (use ‘esversion: 6’).
                              need node V6, which we should be LONG past.
                              do a node -v
                                cskenney @sdetweil
                                @sdetweil @BKeyport I had the same issue with the arrow function. I did node -v and my system is v10.15.2. I was able to work around the issue by using the older notation like shown below.
                                FYI - I just revised your code so you can copy and try it.
                                65:  transform: function(event)  {
                                67:	event.icon = "mdi:recycle";
                                68: 	}
                                69: 	return event;
                                70: },
                                EDIT - line 68 revised to fix an error
                                • BKeyportB
                                  BKeyport Module Developer @cskenney
                                  @cskenney Your code almost got it. - had to remove the comma on line 68 there, but it now checks out…
                                  Just don’t seem to do anything yet. Tweaking some more.
                                  Actually, it’s doing exactly what it’s designed to do. It shows the icon for the event. I didn’t expect it to leave the title in place too. That’ll do perfect.
                                    cskenney @BKeyport
                                    I’m glad it worked for you. I edited the code above to remove the comma in case someone else tries to use it. I originally missed it when I edited your code.
                                      A Former User @cskenney
                                      @cskenney said in MMM-CalendarExt2:
                                      Sorry for the late reply. At weekends, I rarely am in front of computer.
                                      You can define class in your CSS. then assign it into your transfrom code.
                                          event.className = "CLASS_RECYCLE" // in your css/custom.css, define color and bgcolor for this class
                                        return event
                                        cskenney @Guest
                                        @Sean said in MMM-CalendarExt2:
                                          return event
                                        I figured that out about an hour ago and was coming back to the forums to revise my post. Thanks for confirming what I did works!
                                          cskenney @scuppasteve
                                          @scuppasteve said in MMM-CalendarExt2:
                                          You can adjust the background color in the CSS file.
                                          Since you already defined the eventName: “CHORES_CAL” you can use it in CSS.
                                          syntax:
                                          background-color: rgba(red, green, blue, alpha);
                                          alpha: 0~1 (0:transparent, 1:opaque)
                                          Try this in your CSS file.
                                          .CX2 .event.CHORES_CAL {
                                          	background-color:rgba(0,0,0,0);
                                          I believe that will make the background transparent for all the events in that eventName class.
                                            jani.karna
                                            @jani-karna
                                            Worked perfectly, thank you!
                                            • 10
                                            • 24
                                            • 25
                                            • 8 / 25
