    MMM-Spotify suggestion
    7 Posts 2 Posters 1.3k Views 2 Watching
    • E Offline
      ELMAGO
      Re: MMM - Spotify
      Hello
      is it possible to remove the module if no music for 5 minutes for example?
      Thank you
        A Former User @ELMAGO
        @ELMAGO
        Removing module is impossible.
        When all the player is off, It will be inactivated.(hided from screen)
        • E Offline
          ELMAGO @Guest
          @Sean
          I have difficulty expressing myself, passing it inactive in this case.
          My problem is that when I play my Spotify music on a speaker in my house, if I cut Spotifu on my phone, the speaker is still active module the rest also but paused.
          Can you help me again?
          Thanks in advance.
          • E Offline
            ELMAGO
            No answers
              @ELMAGO
              I’m not standing aside to answer all the questions.
              Anyway,
              You can put this code into your css/custom.css
              #SPOTIFY.pausing {
                display:none;
              #SPOTIFY.playing {
                display:block;
              It could make module be displayed only on playing. If you might pause, module will be hidden.
              E 2 Replies Last reply Reply Quote 0
              • E Offline
                ELMAGO @Guest
                @Sean said in MMM-Spotify suggestion:
                Anyway,
                #SPOTIFY.pausing {
                display:none;
                #SPOTIFY.playing {
                display:block;
                Hello
                thank you for cutter back, I test it tonight and I come back to you.
                Thanks for your help.
                • E Offline
                  ELMAGO @Guest
                  #SPOTIFY.pausing {
                  display:none;
                  #SPOTIFY.playing {
                  display:block;
                  It’s perfect, thank you
