    Third-Party Module - how to get help?
    64 Posts 3 Posters 40.4k Views 4 Watching
      sdetweil @ember1205
      @ember1205 hm
      my uname -a
      Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
      we have different kernels… wonder why
      just got the pi4 yesterday
      • E Offline
        ember1205 @sdetweil
        @sdetweil Possibly because you’re running on a 4 and I’m on a 3?
          are u using pm2 to manage? if so, do a pm2 logs --lines=100 >somefile
          I’d like to see the error
            sdetweil @ember1205
            @ember1205 ok, from my pi3
            Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
            • E Offline
              ember1205
              I just did an apt-get update and apt-get upgrade. I then flushed the PM2 logs and restarted. When it crashes again, I’ll post the log info as you asked.
              • E Offline
                ember1205
                At a minimum, the apt-get update / upgrade seems to have at least helped. After installing the updates and restarting, I’ve been running this module with clock, calendar, current weather, and weather forecast all enabled and it hasn’t crashed in about an hour.
                I stopped everything and reverted to the BackgroundSlideshow module to see if it would also run clean, but it died pretty quickly. I’ve flushed the logs again (although I did capture their contents from the other module’s crash) and once again changed over to ImagesPhotos to see what happens after another run.
                While I’m waiting to see if it will crash, I have some questions about the rendering configuration.
                I’ve tried both the “fullscreen” and “middle_center” settings and the photos are not constrained to the screen (in terms of the actual image, not where it’s shown). I can change the details so that I use less than full height and/or width, and there is a black border. However, the image itself is getting cropped - badly.
                How can I get this to display the entire image on the screen like I can with the other module?
                • E Offline
                  ember1205
                  PM2        | 2019-12-12T14:19:37: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2019-12-12T14:19:37: PM2 log: App [mm:0] online
                  PM2        | 2019-12-12T14:41:26: PM2 log: Stopping app:mm id:0
                  PM2        | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms
                  PM2        | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms
                  PM2        | 2019-12-12T14:41:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=process killed
                  PM2        | 2019-12-12T14:41:27: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2019-12-12T14:41:27: PM2 log: App [mm:0] online
                  PM2        | 2019-12-12T14:43:33: PM2 log: Stopping app:mm id:0
                  PM2        | 2019-12-12T14:43:33: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2019-12-12T14:43:33: PM2 log: pid=4543 msg=process killed
                  PM2        | 2019-12-12T14:43:33: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2019-12-12T14:43:33: PM2 log: App [mm:0] online
                  PM2        | 2019-12-12T14:46:33: PM2 log: Stopping app:mm id:0
                  PM2        | 2019-12-12T14:46:33: PM2 log: pid=4667 msg=failed to kill - retrying in 100ms
                  PM2        | 2019-12-12T14:46:33: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2019-12-12T14:46:33: PM2 log: pid=4667 msg=process killed
                  PM2        | 2019-12-12T14:46:33: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2019-12-12T14:46:33: PM2 log: App [mm:0] online
                  PM2        | 2019-12-12T14:47:42: PM2 log: Stopping app:mm id:0
                  PM2        | 2019-12-12T14:47:43: PM2 log: pid=4822 msg=failed to kill - retrying in 100ms
                  PM2        | 2019-12-12T14:47:43: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2019-12-12T14:47:43: PM2 log: pid=4822 msg=process killed
                  PM2        | 2019-12-12T14:47:43: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2019-12-12T14:47:43: PM2 log: App [mm:0] online
                  PM2        | 2019-12-12T15:00:40: PM2 log: Stopping app:mm id:0
                  PM2        | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms
                  PM2        | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms
                  PM2        | 2019-12-12T15:00:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=process killed
                  0|mm       | [5004:1212/145553.006275:FATAL:memory.cc(22)] Out of memory. size=96641024
                  0|mm       | No helper found for module: weatherforecast.
                  0|mm       | All module helpers loaded.
                  0|mm       | Starting server on port 8080 ...
                  0|mm       | Server started ...
                  0|mm       | Connecting socket for: MMM-ImagesPhotos
                  0|mm       | Starting node helper for: MMM-ImagesPhotos
                  0|mm       | Connecting socket for: updatenotification
                  0|mm       | Connecting socket for: calendar
                  0|mm       | Starting node helper for: calendar
                  0|mm       | Sockets connected & modules started ...
                  0|mm       | Launching application.
                  0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/EDITED%40gmail.com/EDITED/basic.ics - Interval: 900000
                  0|mm       |
                  0|mm       | > magicmirror@2.9.0 start /home/pi/MagicMirror
                  0|mm       | > sh run-start.sh
                  0|mm       |
                  0|mm       | Starting MagicMirror: v2.9.0
                  0|mm       | Loading config ...
                  0|mm       | Loading module helpers ...
                  0|mm       | Initializing new module helper ...
                  0|mm       | Module helper loaded: MMM-ImagesPhotos
                  0|mm       | No helper found for module: alert.
                  0|mm       | Module helper loaded: updatenotification
                  0|mm       | No helper found for module: clock.
                  0|mm       | Module helper loaded: calendar
                  0|mm       | No helper found for module: currentweather.
                  0|mm       |
                  0|mm       |
                  0|mm       |
                  0|mm       |
                  0|mm       | Shutting down server...
                  0|mm       | Stopping module helper: MMM-ImagesPhotos
                  0|mm       | Stopping module helper: updatenotification
                  0|mm       | Stopping module helper: calendar
                    sdetweil @ember1205
                    @ember1205 you need to use position:‘fullscreen’ for my sizing to work.
                    there is a space around the picture, its NOT ‘fullscreen’, its the fullscreen section of the mirror ui.
                    i adjust the pic to fix exactly with the same relative dimensions as actual
                    I do not fill (cover) the screen
                    and do not contain (the image)
                    alt text
                    alt text
                    alt text
                    whatever it takes to get 100% of the image, no clipping, onto the screen.
                    they will NEVER fill the screen, the measurements are different.
                    the grey is the background color in the config to use to fill the empty space around the pic
                      backgroundColor: "#808080",  // the default is #000 , ie, black
                    the pics are centered on the screen
                    S E 2 Replies Last reply Reply Quote 0
                      @ember1205 if you don’t use position:“fullscreen” then the image will be clipped or shrunk based on the area u pick, which is less that 100% of the display space.
                      I wanted a full background image without clipping or stretching
                      I checked a few thousand images to insure the right calculations.
                      • E Offline
                        ember1205 @sdetweil
                        I tried with the config you provided:
                        			module: "MMM-ImagesPhotos",
                        			position: "fullscreen",
                        				opacity: 0.9,
                        				animationSpeed: 0,
                        				updateInterval: 30000,  // how often to change pic
                        				backgroundColor: "#808080", // color around pic (if u want something other than black)
                        This results in the photos running off the edges of the screen and not being able to view the entire image. I have also tried using the config on the project page, and adding the maxHeight and maxWidth variables as well.
                        Just for the heck of it, I even tried using the “fullscreen_below” positioning area that the other module uses.
                        The photos always run off the edge of the screen. And by a lot.
                        As of right now, these are all photos that were shot on a 24MP DSLR and they are being displayed on a 1080 TV. There is definitely more pixels in the photo and the device needs to ‘resize’ them down to fit the screen (which it does not appear to be doing).
                        While you don’t ‘contain’ the images, I do recall that was an option being used in the other module that would ensure they did not overrun the screen edges. Is there a config option for yours that would enable it?
                          sdetweil @ember1205
                          @ember1205 no. Contain…etc.
                          My pics are from a Nikon D3300 24mp I don’t see anything strange.
                          U set fullscreen. I add .above
                          I just checked 50 pics, and they display exactly the same as shown in Windows Media viewer and explorer.
                          I just installed the module on two systems. Pi3 and pi4. Cut/pasted the config I posted and both systems present the same. One at 1920x1080, and one at 3840x2160. I get the screen size dynamically. Nothing is hard coded
                            sdetweil @ember1205
                            @ember1205 the pics above are without any mods… installed MM, install the module, linked to my server and started MM… they reach to the top of the window or the side (only a few), never both
                            no border around. not used space is filled with the background color.
                            if u accidentally zoomed in the browser using ctrl-+, it sadly remembers across instances
                            ctrl-minus sign will zoom out again
                            • E Offline
                              ember1205 @sdetweil
                              I’ll definitely give it a try. But… If it were a browser zoom issue, wouldn’t that prevent the other module from displaying them properly as well?
                                sdetweil @ember1205
                                @ember1205 yes…
                                  I just added a little bit of debug messaging…
                                  go to the MMM-ImagesPhotos folder, and do a git pull
                                  then edit the config and add
                                  debug:true,
                                  then restart MM
                                  using keyboard, hit ctrl-shift-i, a window will open on right side, select the tab labeled console, and type
                                  image into the field labeled filter…
                                  now u will see messages from the module as it loads images and gets the image actual size, and sets the location and dimension of the image to be displayed… like this sizes are width/height
                                  top is the top left corner (all locations are relative to the top left corner of the screen, 0,0 is the top left… so 0:72 is all the way left and 72 pixels down. (note its centered, so height+2*offset = max,.
                                  MMM-ImagesPhotos.js:237 image setting size to 3023:2015
                                  MMM-ImagesPhotos.js:238 image setting top to 0:72
                                  2015+72*2=2159 (of 2160) in this case
                                  MM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0491.JPG size=4000:6000
                                  MMM-ImagesPhotos.js:237 image setting size to 1440:2160
                                  MMM-ImagesPhotos.js:238 image setting top to 791:0
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/PICT0097.JPG size=5472:3648
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0027.JPG size=6000:4000
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0476.JPG size=6000:4000
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0042.JPG size=6000:4000
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0198.JPG size=6000:4000
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0720.JPG size=4496:3000
                                  MMM-ImagesPhotos.js:237 image setting size to 3023:2017
                                  MMM-ImagesPhotos.js:238 image setting top to 0:71
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0697.JPG size=3000:4496
                                  MMM-ImagesPhotos.js:237 image setting size to 1441:2160
                                  MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0319.JPG size=4000:6000
                                  • E Offline
                                    ember1205 @sdetweil
                                    “do a get pull”… To date, I’ve done little with repositories - can you elaborate on how I do this to make sure I do it correctly?
                                    Also… Some updates.
                                    1. CTRL - does not affect image size in any way. It DOES affect the sizing of the text for the other modules, though.
                                    2. I believe that I have determined that the desktop / browser “believes” that it is in portrait mode. The images seem to be getting constrained properly, but because the browser is configured to be as tall as it is, I’m losing all kinds of content off the bottom of the screen. If I do a CTRL-SHIFT-I and then turn on the device toolbar, I see a full vertical representation of the browser and I can see the entire image. As I increase the zoom, it becomes apparent where the image is getting clipped vertically.
                                    Thoughts?
                                      sdetweil @ember1205
                                      @ember1205
                                      do a get pull…
                                      No
                                      “do a git pull”
                                      Do
                                      cd ~/MagicMirror/modules/MMM-ImagesPhotos
                                      git pull
                                      That copies the latest from a remote repo and updates the local copy and working directory.
                                      I don’t understand how electron thinks it should be in portrait mode. Never seen that
                                        @sdetweil yeh, you should NOT zoom in
                                        I wonder if this has anything to do with the fake kms driver?
                                        • E Offline
                                          ember1205
                                          git pull says everything up to date and didn’t do anything. No image size info available.
                                          I tried reverting TO the fake driver as I was not using it (real one instead) and that hasn’t made any difference. I also tried editing the startup file to remove the rotate setting, also didn’t help.
                                            sdetweil @ember1205
                                            @ember1205 did u install.my MMM-ImagesPhotos or the original?
                                            I JUST updated mine before telling u, and I just checked the new code is there.
                                            In the MMM-ImagePhotos folder do
                                            git remote -v
                                            Should point to sdetweil
                                            • 2 / 4
