    Setup script fails
    18 Posts 6 Posters 9.7k Views 6 Watching
      sdetweil @qtin
      @qtin thanks…
      can u do a
      uname -a
      on each for me
      • Q Offline
        qtin
        @sdetweil , I’ve checked both Pi2 and Pi3 and they both return the following - exactly the same:
        pi@raspberrypi:~ $ uname -a
        Linux raspberrypi 4.19.50-v7+ #896 SMP Thu Jun 20 16:11:44 BST 2019 armv7l GNU/Linux
        • T Offline
          tcsabina
          Just some random thoughts:
          Are the update/install servers are the same for the 2 RPis?
          /etc/apt??? (not sure about the exact path…) is the location of the files that defines the update servers.
          Do they gave the same internet access? No problem accessing any website on the problematic one?
          • Q Offline
            qtin
            @tcsabina
            Thanks for the suggestion but I managed to get it to work with help from @sdetweil on my other forum post.
            Steps to follow are as follow:
            sudo npm i -g npm
            cd MagicMirror
            1. (Inside the MagicMirror directory)
            rm -rf node_modules/
            npm install
            All done :-)
            S D 2 Replies Last reply Reply Quote 0
              sdetweil @qtin
              @qtin cool! Thanks for the update!
                dpuckett @qtin
                root@raspberrypi:~/MagicMirror# npm install
                npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
                electron-chromedriver@1.8.0 install /root/MagicMirror/node_modules/electron-chromedriver
                node ./download-chromedriver.js
                internal/modules/cjs/loader.js:964
                throw err;
                Error: Cannot find module ‘/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:961:17)
                at Function.Module._load (internal/modules/cjs/loader.js:854:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                at internal/main/run_main_module.js:17:47 {
                code: ‘MODULE_NOT_FOUND’,
                requireStack: []
                npm WARN grunt-stylelint@0.12.0 requires a peer of stylelint@^11.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                npm ERR! /root/.npm/_logs/2019-12-07T00_55_07_956Z-debug.log
                  sdetweil @dpuckett
                  @dpuckett please rename the MagicMirror folder out of the way and use the install script
                  see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                  for the install command string
                    ant62130 @sdetweil
                    @sdetweil Hi,
                    I have exactly the same error as @dpuckett on my freshly installed Raspberry Pi 3B+ :
                    I runned the install script :
                    root@raspberrypi:~# bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                    $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                    $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                    $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                    $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                    $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                    $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                    \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                            \______/
                    install log being saved to /root/install.log
                    No LSB modules are available.
                    Updating packages ...
                    Installing helper tools ...
                    Lecture des listes de paquets... Fait
                    Construction de l'arbre des dépendances
                    Lecture des informations d'état... Fait
                    build-essential est déjà la version la plus récente (12.6).
                    curl est déjà la version la plus récente (7.64.0-4).
                    git est déjà la version la plus récente (1:2.20.1-2+deb10u1).
                    unzip est déjà la version la plus récente (6.0-23+deb10u1).
                    wget est déjà la version la plus récente (1.20.1-1.1).
                    Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
                      point-rpi
                    Veuillez utiliser « sudo apt autoremove » pour le supprimer.
                    0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
                    Minimum Node version: v10.1.0
                    Installed Node version: v10.15.2
                    No Node.js upgrade necessary.
                    Minimum npm version: V6.0.0
                    Installed npm version: V6.13.4
                    No npm upgrade necessary.
                    Cloning MagicMirror ...
                    Clonage dans 'MagicMirror'...
                    remote: Enumerating objects: 331, done.
                    remote: Counting objects: 100% (331/331), done.
                    remote: Compressing objects: 100% (295/295), done.
                    remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
                    Réception d'objets: 100% (331/331), 662.32 KiB | 589.00 KiB/s, fait.
                    Résolution des deltas: 100% (40/40), fait.
                    Cloning MagicMirror Done!
                    Installing dependencies ...
                    internal/modules/cjs/loader.js:583
                        throw err;
                    Error: Cannot find module '/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js'
                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                        at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                        at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
                        at startup (internal/bootstrap/node.js:283:19)
                        at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
                    npm ERR! errno 1
                    npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                    npm ERR!
                    npm ERR!     /root/.npm/_logs/2019-12-12T17_09_00_128Z-debug.log
                    Unable to install dependencies!
                    root@raspberrypi:~# uname -a
                    Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                    root@raspberrypi:~#
                    I tried to execute the command of @tcsabina which worked for him/her but no result :
                    sudo npm i -g npm
                    cd MagicMirror
                    npm install
                    All done 🙂
                      sdetweil @ant62130
                      @ant62130 please install as user pi, not root
                        ant62130 @sdetweil
                        @sdetweil Thanks for the fast reply, it works now !
                        Why is the new script not present on the homepage of the website ?
                        Antoine
                          sdetweil @ant62130
                          @ant62130 said in Setup script fails:
                          updates take time. I’m just another user like you.
                          i see new users struggling to get running, and thought I could help.
                          i have submitted it, and it has been accepted for the next update, and will replace the current version.
                          we’ve spent a few months testing to make sure its better.
                            sdetweil @ant62130
                            @ant62130 I have added a check for user being root… thanks again for the report and feedback
