    Setup script fails
    18 Posts 6 Posters 8.3k Views 6 Watching
      sdetweil @qtin
      @qtin can u tell us the difference between the two pi devices?
      Q 1 Reply Last reply Reply Quote 0
      • Q Offline
        qtin @sdetweil
        Hi Sam
        Thanks for the response. There are no differences other than hardware. I used the exact same Raspbian (NOOBS) image, installed from scratch and followed the same steps.
        Only difference is that I installed it on the Pi2 earlier last week, and on the Pi3 a few days later.
        I will get another SD Card and try it again on the Pi2 and see if it has the same issue now.
          sdetweil @qtin
          @qtin thanks…
          can u do a
          uname -a
          on each for me
          • Q Offline
            qtin
            @sdetweil , I’ve checked both Pi2 and Pi3 and they both return the following - exactly the same:
            pi@raspberrypi:~ $ uname -a
            Linux raspberrypi 4.19.50-v7+ #896 SMP Thu Jun 20 16:11:44 BST 2019 armv7l GNU/Linux
            • T Offline
              tcsabina
              Just some random thoughts:
              Are the update/install servers are the same for the 2 RPis?
              /etc/apt??? (not sure about the exact path…) is the location of the files that defines the update servers.
              Do they gave the same internet access? No problem accessing any website on the problematic one?
              • Q Offline
                qtin
                @tcsabina
                Thanks for the suggestion but I managed to get it to work with help from @sdetweil on my other forum post.
                Steps to follow are as follow:
                sudo npm i -g npm
                cd MagicMirror
                1. (Inside the MagicMirror directory)
                rm -rf node_modules/
                npm install
                All done :-)
                S D 2 Replies Last reply Reply Quote 0
                  sdetweil @qtin
                  @qtin cool! Thanks for the update!
                    dpuckett @qtin
                    root@raspberrypi:~/MagicMirror# npm install
                    npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                    npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
                    electron-chromedriver@1.8.0 install /root/MagicMirror/node_modules/electron-chromedriver
                    node ./download-chromedriver.js
                    internal/modules/cjs/loader.js:964
                    throw err;
                    Error: Cannot find module ‘/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:961:17)
                    at Function.Module._load (internal/modules/cjs/loader.js:854:27)
                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                    at internal/main/run_main_module.js:17:47 {
                    code: ‘MODULE_NOT_FOUND’,
                    requireStack: []
                    npm WARN grunt-stylelint@0.12.0 requires a peer of stylelint@^11.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                    npm ERR! /root/.npm/_logs/2019-12-07T00_55_07_956Z-debug.log
                      sdetweil @dpuckett
                      @dpuckett please rename the MagicMirror folder out of the way and use the install script
                      see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                      for the install command string
                        ant62130 @sdetweil
                        @sdetweil Hi,
                        I have exactly the same error as @dpuckett on my freshly installed Raspberry Pi 3B+ :
                        I runned the install script :
                        root@raspberrypi:~# bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                \______/
                        install log being saved to /root/install.log
                        No LSB modules are available.
                        Updating packages ...
                        Installing helper tools ...
                        Lecture des listes de paquets... Fait
                        Construction de l'arbre des dépendances
                        Lecture des informations d'état... Fait
                        build-essential est déjà la version la plus récente (12.6).
                        curl est déjà la version la plus récente (7.64.0-4).
                        git est déjà la version la plus récente (1:2.20.1-2+deb10u1).
                        unzip est déjà la version la plus récente (6.0-23+deb10u1).
                        wget est déjà la version la plus récente (1.20.1-1.1).
                        Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
                          point-rpi
                        Veuillez utiliser « sudo apt autoremove » pour le supprimer.
                        0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
                        Minimum Node version: v10.1.0
                        Installed Node version: v10.15.2
                        No Node.js upgrade necessary.
                        Minimum npm version: V6.0.0
                        Installed npm version: V6.13.4
                        No npm upgrade necessary.
                        Cloning MagicMirror ...
                        Clonage dans 'MagicMirror'...
                        remote: Enumerating objects: 331, done.
                        remote: Counting objects: 100% (331/331), done.
                        remote: Compressing objects: 100% (295/295), done.
                        remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
                        Réception d'objets: 100% (331/331), 662.32 KiB | 589.00 KiB/s, fait.
                        Résolution des deltas: 100% (40/40), fait.
                        Cloning MagicMirror Done!
                        Installing dependencies ...
                        internal/modules/cjs/loader.js:583
                            throw err;
                        Error: Cannot find module '/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js'
                            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                            at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                            at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
                            at startup (internal/bootstrap/node.js:283:19)
                            at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
                        npm ERR! errno 1
                        npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                        npm ERR!
                        npm ERR!     /root/.npm/_logs/2019-12-12T17_09_00_128Z-debug.log
                        Unable to install dependencies!
                        root@raspberrypi:~# uname -a
                        Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                        root@raspberrypi:~#
                        I tried to execute the command of @tcsabina which worked for him/her but no result :
                        sudo npm i -g npm
                        cd MagicMirror
                        npm install
                        All done 🙂
