    Setup script fails
    18 Posts 6 Posters 9.2k Views 6 Watching
      Joern
      running the default install script on PI3 with latest Raspberry OS, I only get following:
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      > electron-chromedriver@1.8.0 install /root/MagicMirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      internal/modules/cjs/loader.js:638
          throw err;
      Error: Cannot find module '/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Function.Module.runMain (internal/modules/cjs/loader.js:829:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
      npm ERR!     /root/.npm/_logs/2019-07-12T20_19_17_073Z-debug.log
      Unable to install dependencies!
        ant62130 @sdetweil
        @sdetweil Thanks for the fast reply, it works now !
        Why is the new script not present on the homepage of the website ?
        Antoine
          Joern
          after checking here for similar issue, I used bigger desktop image (2019-07-10-raspbian-buster.zip) . Still issue as below, what can I do do complete install?
          Installing dependencies ...
              throw err;
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /root/.npm/_logs/2019-07-13T16_33_01_193Z-debug.log
          pi@raspberrypi:~ $
            sdetweil @Joern
            @Joern I think npm is downlevel
            Do
            sudo npm i -g npm
            To install the latest system wide
            Then redo the npm install in the MagicMirror folder
            • Q Offline
              qtin
              I have the exact same issue and tried countless installs and re-installs without any success. I installed it on another pi a few days ago without any issues, but have been struggling to get it going on my Pi3 for the last 2 days and it is driving me nuts.
              I tried the above recommendation also without any luck.
                sdetweil @qtin
                @qtin can u tell us the difference between the two pi devices?
                Q 1 Reply Last reply Reply Quote 0
                • Q Offline
                  qtin @sdetweil
                  Hi Sam
                  Thanks for the response. There are no differences other than hardware. I used the exact same Raspbian (NOOBS) image, installed from scratch and followed the same steps.
                  Only difference is that I installed it on the Pi2 earlier last week, and on the Pi3 a few days later.
                  I will get another SD Card and try it again on the Pi2 and see if it has the same issue now.
                    sdetweil @qtin
                    @qtin thanks…
                    can u do a
                    uname -a
                    on each for me
                    • Q Offline
                      qtin
                      @sdetweil , I’ve checked both Pi2 and Pi3 and they both return the following - exactly the same:
                      pi@raspberrypi:~ $ uname -a
                      Linux raspberrypi 4.19.50-v7+ #896 SMP Thu Jun 20 16:11:44 BST 2019 armv7l GNU/Linux
                      • T Offline
                        tcsabina
                        Just some random thoughts:
                        Are the update/install servers are the same for the 2 RPis?
                        /etc/apt??? (not sure about the exact path…) is the location of the files that defines the update servers.
                        Do they gave the same internet access? No problem accessing any website on the problematic one?
                        • Q Offline
                          qtin
                          @tcsabina
                          Thanks for the suggestion but I managed to get it to work with help from @sdetweil on my other forum post.
                          Steps to follow are as follow:
                          sudo npm i -g npm
                          cd MagicMirror
                          1. (Inside the MagicMirror directory)
                          rm -rf node_modules/
                          npm install
                          All done :-)
                          S D 2 Replies Last reply Reply Quote 0
                            sdetweil @qtin
                            @qtin cool! Thanks for the update!
                              dpuckett @qtin
                              root@raspberrypi:~/MagicMirror# npm install
                              npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
                              internal/modules/cjs/loader.js:964
                              throw err;
                              Error: Cannot find module ‘/root/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js’
                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:961:17)
                              at Function.Module._load (internal/modules/cjs/loader.js:854:27)
                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                              at internal/main/run_main_module.js:17:47 {
                              code: ‘MODULE_NOT_FOUND’,
                              requireStack: []
                              npm WARN grunt-stylelint@0.12.0 requires a peer of stylelint@^11.0.0 but none is installed. You must install peer dependencies yourself.
                              npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                              npm ERR! errno 1
                              npm ERR! electron-chromedriver@1.8.0 install: node ./download-chromedriver.js
                              npm ERR!
                              npm ERR! /root/.npm/_logs/2019-12-07T00_55_07_956Z-debug.log
                                sdetweil @dpuckett
                                @dpuckett please rename the MagicMirror folder out of the way and use the install script
                                see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                for the install command string
                                  ant62130 @sdetweil
                                  @sdetweil Hi,
                                  I have exactly the same error as @dpuckett on my freshly installed Raspberry Pi 3B+ :
                                  I runned the install script :
                                  root@raspberrypi:~# bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                  $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                  $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                  $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                  $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                  $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                  $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                  \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                          \______/
                                  install log being saved to /root/install.log
                                  No LSB modules are available.
                                  Updating packages ...
                                  Installing helper tools ...
                                  Lecture des listes de paquets... Fait
                                  Construction de l'arbre des dépendances
                                  Lecture des informations d'état... Fait
                                  build-essential est déjà la version la plus récente (12.6).
                                  curl est déjà la version la plus récente (7.64.0-4).
                                  git est déjà la version la plus récente (1:2.20.1-2+deb10u1).
                                  unzip est déjà la version la plus récente (6.0-23+deb10u1).
                                  wget est déjà la version la plus récente (1.20.1-1.1).
                                  Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
                                    point-rpi
                                  Veuillez utiliser « sudo apt autoremove » pour le supprimer.
                                  0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
                                  Minimum Node version: v10.1.0
                                  Installed Node version: v10.15.2
                                  No Node.js upgrade necessary.
                                  Minimum npm version: V6.0.0
                                  Installed npm version: V6.13.4
                                  No npm upgrade necessary.
                                  Cloning MagicMirror ...
                                  Clonage dans 'MagicMirror'...
                                  remote: Enumerating objects: 331, done.
                                  remote: Counting objects: 100% (331/331), done.
                                  remote: Compressing objects: 100% (295/295), done.
                                  remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
                                  Réception d'objets: 100% (331/331), 662.32 KiB | 589.00 KiB/s, fait.
                                  Résolution des deltas: 100% (40/40), fait.
                                  Cloning MagicMirror Done!
                                  internal/modules/cjs/loader.js:583
                                      throw err;
                                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                                      at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                                      at Function.Module.runMain (internal/modules/cjs/loader.js:742:12)
                                      at bootstrapNodeJSCore (internal/bootstrap/node.js:743:3)
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR!     /root/.npm/_logs/2019-12-12T17_09_00_128Z-debug.log
                                  root@raspberrypi:~# uname -a
                                  Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                                  root@raspberrypi:~#
                                  I tried to execute the command of @tcsabina which worked for him/her but no result :
                                  sudo npm i -g npm
                                  cd MagicMirror
                                  npm install
                                  All done 🙂
                                    sdetweil @ant62130
                                    @ant62130 please install as user pi, not root
                                      ant62130 @sdetweil
                                      Antoine
                                        sdetweil @ant62130
                                        @ant62130 said in Setup script fails:
                                        updates take time. I’m just another user like you.
                                        i see new users struggling to get running, and thought I could help.
                                        i have submitted it, and it has been accepted for the next update, and will replace the current version.
                                        we’ve spent a few months testing to make sure its better.
                                          sdetweil @ant62130
                                          @ant62130 I have added a check for user being root… thanks again for the report and feedback
