    MMM-RemoteCompliments problem
    5 Posts 2 Posters 1.6k Views 3 Watching
      blackeaglece
      Hello first of all I apologize for my English, I use Google translation. I installed the MMM-RemoteCompliments mitchelltmarino module and everything went fine (I think!) But, after making all the changes following the instructions, I type pm2 start MagicMirror, the status gives it to me as working but in fact nothing happens, I only see the desktop and the MM does not start. How could I correct this problem? can anyone help me?
      Thank you very much
        sdetweil @blackeaglece
        @blackeaglece do,
        pm2 stop 0
        then
        npm start dev
        you will see messages on the console, and a second window will be open on the mirror
        called the developers window… select the tab labeled ‘console’ and scroll up to see any errors (usually red text.
          blackeaglece @sdetweil
          @sdetweil Hello, thank you very much. I executed the command, but, as you can see from the attached image errorthe only line in red is relative to the weather forecast, and when I launch the command pm2 start magi … (as you see from the second img) it still does not start.PM2
            @blackeaglece no images
              @sdetweil !ops sorry pm2 ![0_1576519448078_pm2.jpg] 0_1576519501441_pm2.jpg and arror 0_1576519469569_error.jpg
