MMM-RemoteCompliments problem
5 Posts 2 Posters 1.1k Views 3 Watching
    blackeaglece
    Hello first of all I apologize for my English, I use Google translation. I installed the MMM-RemoteCompliments mitchelltmarino module and everything went fine (I think!) But, after making all the changes following the instructions, I type pm2 start MagicMirror, the status gives it to me as working but in fact nothing happens, I only see the desktop and the MM does not start. How could I correct this problem? can anyone help me?
    Thank you very much
    S 1 Reply Last reply Dec 16, 2019, 12:47 PM Reply Quote 0
      sdetweil @blackeaglece
      @blackeaglece do,
      pm2 stop 0
      then
      npm start dev
      you will see messages on the console, and a second window will be open on the mirror
      called the developers window… select the tab labeled ‘console’ and scroll up to see any errors (usually red text.
      B 1 Reply Last reply Dec 16, 2019, 5:38 PM Reply Quote 0
        blackeaglece @sdetweil
        @sdetweil Hello, thank you very much. I executed the command, but, as you can see from the attached image errorthe only line in red is relative to the weather forecast, and when I launch the command pm2 start magi … (as you see from the second img) it still does not start.PM2
        S 1 Reply Last reply Dec 16, 2019, 5:53 PM Reply Quote 0
          @blackeaglece no images
          B 1 Reply Last reply Dec 16, 2019, 6:05 PM Reply Quote 0
            @sdetweil !ops sorry pm2 ![0_1576519448078_pm2.jpg] 0_1576519501441_pm2.jpg and arror 0_1576519469569_error.jpg
