    "Out of memory" issues - where do I begin?
    65 Posts 2 Posters 32.2k Views 2 Watching
    • E Offline
      ember1205
      I’m not sure that this is a caching error as it seems related very directly to the displaying of images but “rears up” differently based on the module. In the prior module I was using, displaying ANY graphical content lead to a quick demise of the system (within 15 minutes or so, typically). With the current module, everything was 100% fine until I cropped some of the images. The current module is one you are using with zero images, so there has to be something about the crop method I used that threw things out of whack.
      Even if it IS a straight-up caching issue, I can’t disable caching because the image display process looks poor. I’ve tried with caching disabled and it is not at all smooth, and I also haven’t tested that anywhere near enough to actually validate that it corrects anything.
      Is there a way for me to be able to at least understand the process in effect when this error gets thrown? The entry in the error log seems super generic with no real information along with it.
        sdetweil @ember1205
        @ember1205 i have been chasing these gremlins for the last 3 years without any real success.
        the addition of the call to webFrame.clearCache() has eliminated all my instability
        with the updated MMM-ImagePhotos you shouldn’t have any slow painting… as my code waits til the image is ready to show. I use it EVERY day on multiple systems and OS’s) , and don’t see any slow paint.
        • E Offline
          ember1205
          Turns out I’m wrong on two counts…
          1. I -have- been testing the caching disable extensively as it’s currently disabled. :)
          2. There is not a slow-paint issue for images with caching disabled.
          Unfortunately, I can now say that I’m pretty comfortable with the assessment of this NOT being a caching issue. With caching disabled for electron, the issue has now occurred multiple times in just the last 4-5 hours.
            sdetweil @ember1205
            @ember1205 s, I might try going thru each of the images u have adjusted with the electron browser on the pi and see what happens
            from a commandline
            export DISPLAY=:0
            pi@raspberrypi4:~/MagicMirror $ node_modules/.bin/electron file://{url to pic}
            mine looked like (from my mounted server volume)
             node_modules/.bin/electron file:///media/buildserver/media/Photos/DCIM/2018\ vacation/Page\ Arizona/DSC_0323.JPG
            then close the browser, and use a different url
            now… we are running electron 3.0.13, which is quite old…
            you could try upgrading that to something newer… next version will use 6.0.12 (if my change is accepted)
            • E Offline
              ember1205
              What would I be looking for?
                sdetweil @ember1205
                @ember1205 the browser having trouble, crashing maybe
                • E Offline
                  ember1205
                  I used an iterative command for this because there are so many photos:
                  cd ~MagicMirror
                  find < path to images >/* -exec node_modules/.bin/electron file:///{} \;
                  For each file in that directory, it would launch the electron browser and open the image. Because electron continues to run until it is terminated, this puts one image at a time on the screen. After each one loaded, I would simply click “X” to close the browser and it would move on to the next image.
                  While I -did- see one specific image file appear to load but not actually show any content (initially), I believe this may have been an issue with the fact that I walked away from the process for about ten minutes. Expanding the browser window caused it to re-render and it displayed fine. Additionally, this is an image that I have personally seen on the screen many times with no apparent link to any crashes.
                  It seems that any image-specific issues are possibly cumulative since loading each one in turn starts with a fresh memory allocation as the browser exits after each image.
                  • E Offline
                    ember1205
                    Thought I would update this…
                    Still broken.
                    I have the latest MM as a fresh install on a brand new RPi with a new power adapter, using a brand new SDCard, connected to a different monitor, using a different HDMI cable, and it’s all plugged in to an outlet at an entirely different house in a different area of the state (different sections of the grid). I have the same few, basic modules installed and have added the photos module discussed here. It crashes and hangs randomly with “out of memory” errors just like the other one.
                    The only thing the same between the two is the photo collection. I’ve not found any consistency in the past on it failing with any specific photos so troubleshooting this seems like it’s going to be impossible.
                      sdetweil @ember1205
                      @ember1205 debugging is indeed very difficult w these problems.
                      I wonder if running w chromium browser would produce different results.
                      easiest way to test
                      download the run-start.sh script from here
                      into the MagicMirror folder
                      edit the package.json and change the start command to
                      "start":"./run-start.sh",
                      edit config.js
                      and set
                       serverOnly:"local",
                      this will start mm in server mode, and use chromium to display instead of electron
                      • E Offline
                        ember1205
                        Would that be any different than running it in server mode and accessing it from a browser on my computer across the network? That would be simpler to set up and wouldn’t add more running software onto the Pi…
                        • 1 / 7
