    "Out of memory" issues - where do I begin?
    65 Posts 2 Posters 40.6k Views 2 Watching
      sdetweil @ember1205
      @ember1205 i have been chasing these gremlins for the last 3 years without any real success.
      the addition of the call to webFrame.clearCache() has eliminated all my instability
      with the updated MMM-ImagePhotos you shouldn’t have any slow painting… as my code waits til the image is ready to show. I use it EVERY day on multiple systems and OS’s) , and don’t see any slow paint.
      • E
        ember1205
        Turns out I’m wrong on two counts…
        1. I -have- been testing the caching disable extensively as it’s currently disabled. :)
        2. There is not a slow-paint issue for images with caching disabled.
        Unfortunately, I can now say that I’m pretty comfortable with the assessment of this NOT being a caching issue. With caching disabled for electron, the issue has now occurred multiple times in just the last 4-5 hours.
          sdetweil @ember1205
          @ember1205 s, I might try going thru each of the images u have adjusted with the electron browser on the pi and see what happens
          from a commandline
          export DISPLAY=:0
          pi@raspberrypi4:~/MagicMirror $ node_modules/.bin/electron file://{url to pic}
          mine looked like (from my mounted server volume)
           node_modules/.bin/electron file:///media/buildserver/media/Photos/DCIM/2018\ vacation/Page\ Arizona/DSC_0323.JPG
          then close the browser, and use a different url
          now… we are running electron 3.0.13, which is quite old…
          you could try upgrading that to something newer… next version will use 6.0.12 (if my change is accepted)
          • E
            ember1205
            What would I be looking for?
              sdetweil @ember1205
              @ember1205 the browser having trouble, crashing maybe
              • E
                ember1205
                I used an iterative command for this because there are so many photos:
                cd ~MagicMirror
                find < path to images >/* -exec node_modules/.bin/electron file:///{} \;
                For each file in that directory, it would launch the electron browser and open the image. Because electron continues to run until it is terminated, this puts one image at a time on the screen. After each one loaded, I would simply click “X” to close the browser and it would move on to the next image.
                While I -did- see one specific image file appear to load but not actually show any content (initially), I believe this may have been an issue with the fact that I walked away from the process for about ten minutes. Expanding the browser window caused it to re-render and it displayed fine. Additionally, this is an image that I have personally seen on the screen many times with no apparent link to any crashes.
                It seems that any image-specific issues are possibly cumulative since loading each one in turn starts with a fresh memory allocation as the browser exits after each image.
                • E
                  ember1205
                  Thought I would update this…
                  Still broken.
                  I have the latest MM as a fresh install on a brand new RPi with a new power adapter, using a brand new SDCard, connected to a different monitor, using a different HDMI cable, and it’s all plugged in to an outlet at an entirely different house in a different area of the state (different sections of the grid). I have the same few, basic modules installed and have added the photos module discussed here. It crashes and hangs randomly with “out of memory” errors just like the other one.
                  The only thing the same between the two is the photo collection. I’ve not found any consistency in the past on it failing with any specific photos so troubleshooting this seems like it’s going to be impossible.
                    sdetweil @ember1205
                    @ember1205 debugging is indeed very difficult w these problems.
                    I wonder if running w chromium browser would produce different results.
                    easiest way to test
                    download the run-start.sh script from here
                    into the MagicMirror folder
                    edit the package.json and change the start command to
                    "start":"./run-start.sh",
                    edit config.js
                    and set
                     serverOnly:"local",
                    this will start mm in server mode, and use chromium to display instead of electron
                    • E
                      ember1205
                      Would that be any different than running it in server mode and accessing it from a browser on my computer across the network? That would be simpler to set up and wouldn’t add more running software onto the Pi…
                        sdetweil @ember1205
                        @ember1205 same, no new software on the pi. mm install installs everything.
                        can run as
                        full ---- how it is now
                        server only
                        server only w different browser ( already installed)
                        or
                        client only
                        • E
                          ember1205
                          Understood that there isn’t new software installed, but this would mean no additional software actively running on the Pi (Electron would be stopped, and all browser software would be running from a different machine).
                            sdetweil @ember1205
                            @ember1205 right. that doesn’t mean u fixed the out of memory problem. it’s possible.
                            I was working on one change at a time.
                            u can install the run-start.sh and change config.js to serverOnly: true, then launch browser from your pc
                            • E
                              ember1205
                              Your suggestion incorporates multiple changes, though… Stopping Electron and Starting Chromium while also changing the operating mode. No?
                              I’ve changed the config.js to both
                              serverOnly: true,
                              and
                              serverOnly:"true",
                              and neither one prevents Electron from starting.
                              I’ve now also tried
                              serverOnly:true,
                                sdetweil @ember1205
                                @ember1205 u need the run-start.sh script for that parm to work
                                besides, u said u were going to run in server only mode anyway. and then u will have to change your startup process too
                                • E
                                  ember1205
                                  By adding an external browser, it crashed in only a few minutes. I’m going to let it keep running with the additional external browser to see if it causes it crash much more quickly on a more continuous basis.
                                  If I can cause it to crash quickly on a repeated basis, it gives me an opportunity to try testing specific image files. It’s possible that this is a cumulative problem that is related to a small memory loss that gets added to on the load of additional errant files.
                                  UPDATE: So much for that theory… I am currently running Electron plus an external instance of Chrome on Windows and Safari on MacOS. No “quick crashes.”
                                    sdetweil @ember1205
                                    @ember1205 i spent a year debugging an out of memory that only crashed one version of a module… another ran fine…
                                    one line of code, my code, made the difference… but the problem ‘appeared’ to be a hang , suddenly the UI was dead…
                                    randomnly displaying pics in the background.
                                    not til I added a totally new logging approach did I find the actual problem, which was out of memory, which killed the UI, which made it LOOK hung…
                                    • E
                                      ember1205
                                      In my situation, the UI goes all black and the cursor appears (no mouse or keyboard connected). There’s a generic “out of memory” error entered into the log file. Restarting MM is the only way I’ve found to get it back up and running.
                                      The photo module I’m running is your fork with the more recent changes to allow the blurring of the same image behind the full-view image. Any thoughts on anything that could/should be added to try and capture more in the logs? Is there an increased logging level I could be using in MM itself? Stack traces when it fails? Before it fails? Anything come to mind that might give me a new avenue?
                                      The issue doesn’t seem to appear if I am not using the photo module. But, that could be because the other, more basic modules don’t use resources as intensively. We’ve compared notes on RPi, kernel, build, etc. and not found anything that seems to be materially different with the one exception being the specific image files in use.
                                        sdetweil @ember1205
                                        @ember1205 i run that module every day all day and don’t see any problem, but… try this
                                        edit MMM-ImagesPhotos.js
                                        add the line shown below
                                              					img.style.top = result.targettop+"px";                    // line 271
        img=null      /// add this line
                                        					// if another image was already displayed
                                        					let c = self.fg.childElementCount;
                                        • E
                                          ember1205
                                          should it be:
                                          img=null;
                                            sdetweil @ember1205
                                            @ember1205 trailing ; is ok either way
                                            • 1 / 4
