Display turned black after I installed MMM-DigClock
7 Posts 3 Posters 1.2k Views 3 Watching
    SirVer
    I installed the MagicMirror recently and tried the MMM-BackgroundSlideshow. Everything worked perfectly. But then I wanted use the MMM-DigClock but then nothing worked. The display just turned black and I can see the mouse on the top left corner. I assume that it could not install correctly, because I got this after the installation of MMM-DigClock:
    pi@raspberrypi:~/MagicMirror/modules/MMM-DigClock $ npm install
    npm WARN deprecated undefined@0.1.0: this package has been deprecated
    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror        /modules/package.json'
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/mo        dules/package.json'
    npm WARN modules No description
    npm WARN modules No repository field.
    npm WARN modules No README data
    npm WARN modules No license field.
    removed 1 package in 1.439s
    found 0 vulnerabilities
    How can I solve this problem?
    S 1 Reply Last reply Dec 22, 2019, 12:54 PM Reply Quote 0
      sdetweil @SirVer
      @SirVer do this
      git checkout modules/node_modules/node_help/index.js
      this was because MMM-DigClock does not have a package.json file, and u should not have done npm install for it
      S 1 Reply Last reply Dec 22, 2019, 12:57 PM Reply Quote 0
        SirVer @sdetweil
        @sdetweil Thanks for the answer but I get this:
        pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_help/index.js
        error: pathspec 'modules/node_modules/node_help/index.js' did not match any file(s) known to git
        S 1 Reply Last reply Dec 22, 2019, 1:30 PM Reply Quote 0
          sdetweil @SirVer
          @SirVer sorry, typo (left off the ‘er’ on node_helper)
          git checkout modules/node_modules/node_helper/index.js
          S 1 Reply Last reply Dec 23, 2019, 11:57 AM Reply Quote 1
            SirVer @sdetweil
            @sdetweil I have a question: I thought git checkout is just changing the branch. So what is the command here git checkout … doing in index.js ?
            S 1 Reply Last reply Dec 23, 2019, 12:42 PM Reply Quote 0
              BKeyport Module Developer
              it’s much more than that.
              https://git-scm.com/docs/git-checkout
                sdetweil @SirVer
                @SirVer checkout can switch branches, it can also get a file from the local repository into your local working directory
