Docker and custom.css
11 Posts 2 Posters 5.5k Views 2 Watching
  • T Offline
    technofab
    I’ve a docker installation… where I need to put my custom.css file?
    I need to generally downsize the font size a little.
    Thanks in advance.
    S 1 Reply Last reply Dec 24, 2019, 5:24 PM Reply Quote 0
      sdetweil @technofab
      @technofab see the doc(README.md) of the docker container
      https://github.com/bastilimbach/docker-MagicMirror
      /opt/magic_mirror/css/custom.css
      Mount this file to add your own custom css into the docker container.
      Important: You need to create the file before you run the container. Otherwise Docker will create a custom.css folder.
      • T Offline
        technofab
        I did’nt find that path in the container, but I follow the gh container instructions… so? 🤔
        S 1 Reply Last reply Dec 24, 2019, 8:01 PM Reply Quote 0
          sdetweil @technofab
          @technofab correct, its not IN the container, you need to CREATE a docker mount point at that path
          • T Offline
            technofab
            S 1 Reply Last reply Dec 24, 2019, 8:15 PM Reply Quote 0
              sdetweil @technofab
              @technofab
              docker takes a --volume=source:dest or a --mount src=,dest= to map a local folder/file into the container at a particular file system location
              so, as this container wants the custom.css at /opt/magic_mirror/css/custom.css
              the parm on docker run would be
              --volume=local_path_to_custom_css:/opt/magic_mirror/css/custom.css
              notice the : between the source and dest
              in a Windows environment where : also appears in driveletter:\path
              u must use the --mount type parameter
              • T Offline
                technofab
                Thanks and merry Christmas
                • T Offline
                  technofab
                  OK I finally put my custom empty file custom.css now: i edit to limit default module calendart in witdh so:
                  body {
                   .module.calendar {
                       width:50px;
                  Stop and restart container but nothing change. What I’m missing?
                  S 1 Reply Last reply Dec 26, 2019, 12:50 PM Reply Quote 0
                    sdetweil @technofab
                    @technofab
                    well, two things
                    1. do not use ‘.module’ in front of the module name
                    2. there is no single style that will set the width…
                      there are these classes (from the calendar README)
                    | `symbolClass`         | Add a class to the cell of symbol. default 'symbol'
                    | `titleClass`          | Add a class to the title's cell.   default 'title'
                    | `timeClass`           | Add a class to the time's cell. default 'time'
                    and
                     'tableClass'      which might be usable to contain the overall width, default not specified
                    in a sample I did this in custom.css
                    .calendar .title {
                    color : blue;
                    .calendar .fribble {
                      background-color:rgba(32,32,32,0.6);
                      border-radius:8px;
                      padding:8px;
                    and in config.js for the calendar module
                      config:{
                         tableClass:'fribble'
                    S 1 Reply Last reply Dec 26, 2019, 1:42 PM Reply Quote 0
                      @technofab you can also confirm your custom.css is in the right place by doing
                      docker exec container_id (or name) cat /opt/magic_mirror/css/custom.css
                      that should match yours
                      T 1 Reply Last reply Dec 26, 2019, 6:28 PM Reply Quote 0
