    Docker and custom.css
    11 Posts 2 Posters 5.9k Views 2 Watching
      sdetweil @technofab
      @technofab
      docker takes a --volume=source:dest or a --mount src=,dest= to map a local folder/file into the container at a particular file system location
      so, as this container wants the custom.css at /opt/magic_mirror/css/custom.css
      the parm on docker run would be
      --volume=local_path_to_custom_css:/opt/magic_mirror/css/custom.css
      notice the : between the source and dest
      in a Windows environment where : also appears in driveletter:\path
      u must use the --mount type parameter
      • T Offline
        technofab
        Thanks and merry Christmas
        • T Offline
          technofab
          OK I finally put my custom empty file custom.css now: i edit to limit default module calendart in witdh so:
          body {
           .module.calendar {
               width:50px;
          Stop and restart container but nothing change. What I’m missing?
            sdetweil @technofab
            @technofab
            well, two things
            1. do not use ‘.module’ in front of the module name
            2. there is no single style that will set the width…
              there are these classes (from the calendar README)
            | `symbolClass`         | Add a class to the cell of symbol. default 'symbol'
            | `titleClass`          | Add a class to the title's cell.   default 'title'
            | `timeClass`           | Add a class to the time's cell. default 'time'
            and
             'tableClass'      which might be usable to contain the overall width, default not specified
            in a sample I did this in custom.css
            .calendar .title {
            color : blue;
            .calendar .fribble {
              background-color:rgba(32,32,32,0.6);
              border-radius:8px;
              padding:8px;
            and in config.js for the calendar module
              config:{
                 tableClass:'fribble'
              @technofab you can also confirm your custom.css is in the right place by doing
              docker exec container_id (or name) cat /opt/magic_mirror/css/custom.css
              that should match yours
              • T Offline
                technofab @sdetweil
                @sdetweil ok I was assuming is necessary add .module, now works.
                I find some example that use that keyword… 🤔
