    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 119.8k Views 39 Watching
      djsunrise19
      I want to extend the module a little bit:
      • Project Name as header
      • Project color in front of the name / the todos
      • reminder icon behind the todo (due date like the discussion above)
      I tried a few things (from @tidus5 within the fetcher). But I can’t get it to work. Any hints / ideas?
      tidus5T 1 Reply Last reply
      • tidus5T
        tidus5 @djsunrise19
        @djsunrise19 Hello
        i’m on holiday. Can send you the files when i’m back. you need to change the fetcher indeed.
        Have a nice day
        • tidus5T
          tidus5
          This is my code
          it’s based on 2 users (i badly commented the code)
          /* Magic Mirror
           * Fetcher
           * By Michael Teeuw http://michaelteeuw.nl edited for Wunderlist by Paul-Vincent Roll
           * Edited again for Todoist by Chris Brooker
           * MIT Licensed.
          var request = require("request");
          /* Fetcher
           * Responsible for requesting an update on the set interval and broadcasting the data.
           * attribute listID string - ID of the Wunderlist list.
           * attribute reloadInterval number - Reload interval in milliseconds.
           	function dateDiff(date1, date2){
              var diff = {}                           // Initialisation du retour
              var tmp = date2 - date1;
              tmp = Math.floor(tmp/1000);             // Nombre de secondes entre les 2 dates
              diff.sec = tmp % 60;                    // Extraction du nombre de secondes
              tmp = Math.floor((tmp-diff.sec)/60);    // Nombre de minutes (partie entière)
              diff.min = tmp % 60;                    // Extraction du nombre de minutes
              tmp = Math.floor((tmp-diff.min)/60);    // Nombre d'heures (entières)
              diff.hour = tmp % 24;                   // Extraction du nombre d'heures
              tmp = Math.floor((tmp-diff.hour)/24);   // Nombre de jours restants
              diff.day = tmp;
              return diff;
          var Fetcher = function(listID, reloadInterval, accessToken, clientID) {
           var self = this;
           if (reloadInterval < 1000) {
          	reloadInterval = 1000;
           var reloadTimer = null;
           var items = [];
           var fetchFailedCallback = function() {};
           var itemsReceivedCallback = function() {};
           /* private methods */
           /* fetchTodos()
          	* Request the new items.
           var fetchTodos = function() {
          	clearTimeout(reloadTimer);
          	reloadTimer = null;
          	request({
          		url: "https://todoist.com/API/v7/sync/",
          		method: "POST",
          		headers: {
          			'content-type': 'application/x-www-form-urlencoded',
          			'cache-control': 'no-cache'
          		form: {
          				token: accessToken,
          				sync_token: '*',
          				resource_types: '["items"]'
          	 function(error, response, body) {
          		if (!error && response.statusCode == 200) {
                   items = [];
          		 for (var i = 0; i < JSON.parse(body).items.length; i++) {
          			 if (JSON.parse(body).items[i].project_id == listID) {
          		donneetableau = JSON.parse(body).items[i];
          		onbalance = [];
          		icontodo = [];
          		assignedname = [];
          		datedueretour = [];
          		contentretour = [];
          		assignedtodoname = [];
          		checkedretour = [];
          		if (donneetableau.priority == '1') {icontodo ='<i></i> '}
          		else if (donneetableau.priority == '2') {icontodo ='<i></i> '}
          		else if (donneetableau.priority == '3') {icontodo ='<i></i> '}
          		else {icontodo ='<i></i> '}
          		if (donneetableau.assigned_by_uid == 'XXXXXXXX') {assignedname ='(XXXXX)'}//TEST  first XXX UID second XXXX yourname
          		else if (donneetableau.assigned_by_uid == 'XXXXXXX') {assignedname ='(XXXXXX)'}//TEST  first XXX UID second XXXX yourname
          		else {assignedname ='Inconnu'};
          		if (donneetableau.due_date_utc)
          				date1 = new Date();
          				date2 = new Date(donneetableau.due_date_utc);
          				diff = dateDiff(date1, date2);
          				if (diff.day = '1') {datedueretour += diff.day + 'd <i></i> ';}
          				else if (diff.hour >= '1') {datedueretour += diff.hour + 'h <i></i> ';}
          				else {datedueretour += diff.min + 'min <i></i> ';};
          		else {datedueretour =''};
          		contentretour = donneetableau.content;
          		if (donneetableau.responsible_uid ) {
          		if (donneetableau.responsible_uid == 'XXXXXXX') {
          		assignedtodoname ='<i></i> '
          		} ////YOUR UID USER
          		else if (donneetableau.responsible_uid == 'XXXXXXX') {assignedtodoname ='<i></i> '}
          		else {assignedtodoname ='Inconnu'};  // YOUR UID USER
          		} else { assignedtodoname ='' };
          		checkedretour = donneetableau.checked;
          		onbalance +=assignedtodoname + icontodo + datedueretour + contentretour;
          		items.push(onbalance);
          				//items.split('\n');
          				 //priority.push(JSON.parse(body).priority[i].priority);
          				 //datedue.push(JSON.parse(body).datedue[i].due_date_utc);
          		 self.broadcastItems();
          		 scheduleTimer();
           /* scheduleTimer()
          	* Schedule the timer for the next update.
           var scheduleTimer = function() {
          	//console.log('Schedule update timer.');
          	reloadTimer = setTimeout(function() {
          	 fetchTodos();
          	}, reloadInterval);
           /* public methods */
           /* setReloadInterval()
          	* Update the reload interval, but only if we need to increase the speed.
          	* attribute interval number - Interval for the update in milliseconds.
           this.setReloadInterval = function(interval) {
          	if (interval > 1000 && interval < reloadInterval) {
          	 reloadInterval = interval;
           /* startFetch()
          	* Initiate fetchTodos();
           this.startFetch = function() {
          	fetchTodos();
           /* broadcastItems()
          	* Broadcast the exsisting items.
           this.broadcastItems = function() {
          	if (items.length
            Cupola
            Dumb question, how do you exactly generate the access token? I’m a little bit confused…
            From pm2 logs, I read:
            ** Message: console message: http://localhost:8080/modules/MMM-Todoist//MMM-Todoist.js @199: SyntaxError: Unexpected token ‘>’
            I used the access token generated from here, but I’m not sure about the process, which App service URL did you use? Which OAuth redirect URL? And last which token is the right one? I can see three of them
            Thanks in advance
            pyrosmileyP 1 Reply Last reply
            • pyrosmileyP
              pyrosmiley @Cupola
              @Cupola
              Not a dumb question, don’t worry! Oauth2 can be super confusing, and everyone does it a little differently which is… frustrating at best.
              The Access Token you need is the 3rd one, what they refer to as your Test Token on the page. (The idea behind this is that with OA2, each would-be client has to use its ID and Secret to ask for specific account access for each account it wants to see. They basically did that process for you once, for testing or personal things like this that only need your account.)
              You don’t need to worry about the OAuth redirect URL or the App Service URL. I have each filled with http://127.0.0.1 but I don’t think either are required at all.
              Hopefully this gets you up and running!
                Cupola
                Thank you, now it’s working
                  mariecbilodeau
                  Is there a way to add bullets before each task?
                  • A
                    amomat
                    Hi. Is it possible to show who the task is assigned to? Trying to set up a to-do list for the kids to show their chores.
                    • eprostkoE
                      eprostko
                      Todoist is working on my MM, but the day is not right. I have a daily recurring task that says “today” on my mirror, but is “tomorrow” when I look on todoist.com directly or on my phone app.
                      Has anyone else seen and resolved this behavior?
                        Mariba
                        Hey,
                        is there functionality to see the number of days left for an event? I’d be happy if I could see that.
                        Or is it possible to show it myself by subtracting the date of the event from the current date? If yes, how do I do it?
                        Thanks. Happy New Year.
                          jani.karna
                          Hi! How can I get sorting working? No matter what I try, items are only added to the end of the list. I would like to sort them by priority and then by due date, but can’t figure of how.
                            Jas
                            For the OAuth, I can’t seem to find the “Test Token” on ToDoList site. Under the app, I only have Client ID and Client Secret. Under Settings/Integrations, there is a entry for API Token. Which of the 3 should I be using? Right now, I don’t have anything showing up from ToDoList when Mirror is running.
                              Clubjack @cbrooker
                              @cbrooker
                              Hey. I am using your Module.
                              Thank You for your work.
                              Do You think, its easy to change the Look?
                              I youse the Module “Mmm-my calendar”, and it would be great to have the same Look.
                              (two lines, one with Taskname, one with date, and a Symbol)
                              Mayve someone have an idea to realize that
                              C 1 Reply Last reply
                                Clubjack @Clubjack
                                Could one of the professionals take a look at the config of MMM-Todoist and MMM-myCalendar and see if it would be possible to easily adapt the look of mycalendar to that of todoist?
                                  Clubjack
                                  I must ask again.🙈
                                  Could somebody help me to change the Look of MMM-Todoist?
                                  It would be great, if the Look could be the same like MMM-myCalendar.
                                  Then it would make a better overall impression.
                                  At first, it would be great to know, if this is (easily) makebal.
                                  • CynicC
                                    Cynic
                                    Hello everyone! Need your help. Parameter: showProjects: false does not remove the project from the mirror. Where is the mistake?
                                    I am not a wizard. I am just learning.
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Clubjack
                                      @Clubjack said in MMM-Todoist - Your todoist tasks on your mirror:
                                      I must ask again.🙈
                                      You’d need to change the css and more then like the innerHTML’s themselves.
                                        banbutcher
                                        hi,
                                        ive just installed mmm-todoist on my mirror and after the install i can start the mirror fine but it seems that after its installed i think its affecting either mmm-keybindings of mmm-carousel because normally i can use the arrow keys to gleft and right BUT im not able to click on the page indicator to select a page, and after installing mmm-todoist im now not able to use arrow keys to select page BUT i am now able to click on the page indicator to select pages!! Curious!!
                                        i get no errors starting but in the development tools section im getting these warnings and errors:
                                        /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                                          protocols.This exposes users of this app to unnecessary security risks.
                                          Consider loading the following resources over HTTPS or FTPS.
                                         - http://0.0.0.0:8080/css/main.css
                                        - http://0.0.0.0:8080/fonts/roboto.css
                                        - http://0.0.0.0:8080/socket.io/socket.io.js
                                        - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                                        - http://0.0.0.0:8080/js/defaults.js
                                        - http://0.0.0.0:8080/config/config.js
                                        - http://0.0.0.0:8080/vendor/vendor.js
                                        - http://0.0.0.0:8080/modules/default/defaultmodules.js
                                        - http://0.0.0.0:8080/js/logger.js
                                        - http://0.0.0.0:8080/translations/translations.js
                                        - http://0.0.0.0:8080/js/translator.js
                                        - http://0.0.0.0:8080/js/class.js
                                        - http://0.0.0.0:8080/js/module.js
                                        - http://0.0.0.0:8080/js/loader.js
                                        - http://0.0.0.0:8080/js/socketclient.js
                                        - http://0.0.0.0:8080/js/main.js
                                        - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                                        - http://0.0.0.0:8080/translations/en.json
                                        - http://0.0.0.0:8080/modules/MMM-Carousel//MMM-Carousel.js
                                        - http://0.0.0.0:8080/modules/MMM-Carousel/MMM-Carousel.css
                                        - http://0.0.0.0:8080/modules/MMM-GoogleAssistant//MMM-GoogleAssistant.js
                                        - http://0.0.0.0:8080/modules/MMM-GoogleAssistant/components/response.js
                                        - http://0.0.0.0:8080/modules/MMM-GoogleAssistant/MMM-GoogleAssistant.css
                                        For more information and help, consult
                                        https://electronjs.org/docs/tutorial/security.
                                         This warning will not show up
                                        once the app is packaged.
                                        /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                                            Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                                        :8080/modules/MMM-Go…ib/highcharts.js:10 Uncaught Error: Highcharts error #16: www.highcharts.com/errors/16
                                            at Object.a.error (:8080/modules/MMM-Go…ib/highcharts.js:10)
                                            at :8080/modules/MMM-CO…lib/highcharts.js:8
                                        TypeError: Cannot read property 'items' of undefined
                                            at Class.getDom (:8080/modules/MMM-To…/MMM-Todoist.js:551)
                                            at main.js:111
                                            at new Promise (<anonymous>)
                                            at updateDom (main.js:110)
                                            at main.js:52
                                            at Array.forEach (<anonymous>)
                                            at createDomObjects (main.js:21)
                                            at Object.modulesStarted (main.js:499)
                                            at startModules (loader.js:56)
                                            at loader.js:38
                                        :8080/modules/MMM-To…/MMM-Todoist.js:551 Uncaught (in promise) TypeError: Cannot read property 'items' of undefined
                                            at main.js:111
                                            at main.js:52
                                            at loader.js:38
                                        api.openweathermap.o…ef566eab7f1c9b6c4:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
                                        :8080/modules/defaul…therforecast.js:261 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                                        and my config is:
                                        /*-------------------- MMM-Todoist Route Start-----------------*/
                                        		module: 'MMM-Todoist',
                                        		position: 'top_left',
                                        		header: 'Todoski...',
                                        			hideWhenEmpty: true,
                                        			accessToken: 'xoxoxoxox',
                                        			maximumEntries: 60,
                                        			updateInterval: 10*60*1000, // Update every 10 minutes
                                        			fade: false,
                                        			// projects and/or labels is mandatory:
                                        			projects: [ xxxxxxx, xxxxxxx ],
                                        			//labels: [] // Tasks for any projects with these labels will be shown
                                        also but not a biggie, i have 2 projects todo and magicmirror after adding a couple to each, the mirror displays them in staggered project order rather than in order as added - ie:
                                        task1 - todo
                                        task5 - MM
                                        task2 - todo
                                        task6 -MM
                                        task3 - todo
                                        task7 - MM
                                        task4 - todo
                                        id like:
                                        task1 - todo
                                        task2 - todo
                                        task3 - todo
                                        task4 - todo
                                        task5 - MM
                                        task6 -MM
                                        task7 - MM
                                        any help or ideas would be great!
                                        Many thanks,
                                        Richie
                                        • edwardssjE
                                          edwardssj @cbrooker
                                          @cbrooker Strange thing is happening here, when it refreshes the list at 10 minutes my mirror restarts, any suggestions?
                                          • 4 / 4
