    Apache Permissions: can't duplicating config.js.sample
    20 Posts 5 Posters 16.2k Views 5 Watching
      patm189
      I’m new to this and getting stuck following Apache instructions. I would appreciate any guidanace.
      Apache Permissions. I can’t update or change anything in Apache even using sudo commands in Terminal. I am trying to copy file ~/config.js.sample from MagicMirror2 folder (cp sudo nano /var/www/html/MagicMirror/config/config.js.sample so that I can rename and remove the ‘sample’, but I am getting permissions denied. I can’t simple rename the config.js.sample file either. How can I edit files in Apache server? I have no experience with Apache permissions and can’t move forward until I get this resolved.
      Pat
        patm189 @CaptainFalcon323
        @CaptainFalcon323 What happens if you right click the Magic Mirror folder > Open in Terminal > and enter command npm start? Do you still get the ‘need to config’ prompt?
          patm189
          Figured this out. I was able to give my default user “pi” permissions to write in /var/www/
          paviroP 1 Reply Last reply Reply Quote 0
          • paviroP Offline
            paviro @patm189
            @patm189 why (and how) are you using Apache vor MM v2 in the first place? It ships its own web server, you can’t use it with apache.
            – The Doctor
              patm189 @paviro
              @paviro thanks for the comment. Honestly, I have no experience with this sort of thing so I’ve been following online tutorials saying to install Apache. I might just wipe my SD Card and start over (…again).
              Let me know if I’m misunderstanding, but if I install MagicMirror2 then I do not need Apache? Install link below:
              (curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash)
              Which directory should I download this into? Once it’s installed, the other trouble I’m having is actually locating a index.php file, which is what I believe should launch with reboot once I adjust autostart file with this line (among others) @midori -e Fullscreen -a http://localhost/MagicMirror/index.php
              When I input this index.php file I get a Not Found error upon reboot and launch. THANK YOU!
              Pat
              • paviroP Offline
                paviro @patm189
                @patm189 there is no index.php anymore and no you don’t need Apache, you can’t use it actually. Download it anywhere you like, just follow the instructions in the README.
                – The Doctor
                  patm189 @paviro
                  Thanks @paviro! [grabs cup of coffee] Going to take another crack at this!
                    patm189
                    Well i’ll be damned. Following the instructions worked! Haha. Thanks for bearing with me.
                      CaptainFalcon323
                      Hello all!
                      I’m also new to this sort of thing (little/no coding experience) and I too have been following online tutorials but haven’t been getting results… So, I switched to following the README, but haven’t made it very far.
                      I’ve downloaded the necessary files from git hub using:
                      Due to my lack of coding knowledge, I’m unsure how to duplicate the config.js.sample file (so that the file becomes config.js) - referring to this line in the README:
                      Duplicate "config/config.js.sample to config/config.js.
                      I’ve tried typing this into the terminal under the magic mirror directory but nothing happens. I’ve also gone into my File Manager—> Directory Tree----> MagicMirror----> confi folder----> copied and pasted the “config.js.sample” file and renamed it to “config.js”.
                      From there I’ve gone to https:///MagicMirror/ (from another computer on the same network)to see what it all looks like. I get a message that says I need to create a config file (of that mine has an error in it and to use a JavaScript Linter).
                      Any and all help would be appreciated especially at an ELi5 level :D Thanks in advance!
                      • F Offline
                        feuerball
                        go into the config directory with a terminal and type
                        sudo cp config.js.sample config.js
                        • paviroP Offline
                          paviro @feuerball
                          @feuerball sudo should not be necessary.
                          – The Doctor
