    Cannot find module 'module-alias/register'
    10 Posts 3 Posters 7.6k Views 3 Watching
      DerRheingold
      since two days now, I keep getting this error-message when (re)starting MagicMirror:
      App threw an error during load
      Error: Cannot find module 'module-alias/register'
          at Module._resolveFilename (module.js:455:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:403:25)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:1)
          at Module._compile (module.js:556:32)
          at Object.Module._extensions..js (module.js:565:10)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      On a regular base I make a git fetch etc. to make sure MagicMirror is up to date. This morning somehow it wouldn’t start anymore. That’s the error I get when manually starting via
      DISPLAY=:0 npm start
      Any idea how to fix this? … and even more: any idea what might have caused this?
      Cheers :)
        sdetweil @DerRheingold
        @DerRheingold did u try to update to the latest release?
        if so, there were two steps
        git pull
        npm install
        did u do the second?
          DerRheingold
          @sdetweil said in Cannot find module 'module-alias/register':
          npm install
          Thanks, yes that was very helpful. Helped indeed. However I also had to fix one module by deleting and pulling it again, but now it works fine. Thanks once more :)
            amanzimdwini
            Hmm - same thing for me. Too much time on my hands, so I updated. And now I get
            Uncaught Exception:
                at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/elect        ron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                at Module.require (internal/modules/cjs/loader.js:658:17)
                at require (internal/modules/cjs/helpers.js:20:18)
                at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:283:3)
                at Module._compile (internal/modules/cjs/loader.js:711:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                at Module.load (internal/modules/cjs/loader.js:620:32)
            help?
            Thanks,
            Karl
              sdetweil @amanzimdwini
              @amanzimdwini and u also did
              npm install
              after the git pull…
              need everyone to start using the update script…
              from here
                amanzimdwini @sdetweil
                I did (read my way through all the posts)
                HOWEVER,
                https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing/2
                told me to run
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                and that made me a new installation that did work.
                Sometimes you have to sledgehammer things, I guess.
                Thanks for offering to help,
                karl
                  @amanzimdwini that post says
                  I also have a newer installer that resolves a lot of problems with MM
                  post 1
                  says
                  given that we will have a regular update quarterly, and we have such a large number of new users experiencing troubles after updates (mostly cause they have a ton to learn)… I have developed a script I would like to get included for future updates…
                  but glad u got it working… many cannot just reinstall easily
                    wait - wasnt’ that the newest?
                    Sorry - working on something else right now, but please send latest and best installer link
                    THANKS FOR THE HELP,
                    Karl
                      @amanzimdwini
                      please read the page here for the multiple scripts I provide
                      each provides the string to cut/paste to execute the specific function
                      install,
                      update
                      screen saver
                      pm2
                        @sdetweil THX! Will do.
