    no integration of google family calendar and MM
    11 Posts 3 Posters 5.2k Views 3 Watching
    • L
      Landler
      Hello everyone,
      my name is Oliver and I’m starting with the first step to the MM. I got the basic functions up and running - fine.
      Now I’m trying to integrate our family calendar from google into MM and I have some issues with it.
      In Google setting I can’t find any information about die ical-address of the calendar. I tried the combination of Google calendar ID and public URL but nothing will work.
      The standard calendar (US Holidays) works fine :-)
      Has any one an idea how to integrate this? All informations I found here are pretty old >2 years and the settings in google changed meanwhile.
      thx for your support
      Oliver
        the calendar is not shareable via ics.
        I have a family calendar like that, but I did not create it and cannot change the permissions
        Permissions settings
        Anyone can
        See nothing <----
        • L
          Landler
          so this could be the answer. If I’m using a personal calendar, I get a private ical-address but not for the family calendar.
          So I have to look for an other solution (personal calendar “Familiy”, invite other family member to look at,…)
          thx
          Oliver
            sdetweil @Landler
            @Landler get the creator of the calendar to change the permissions… that may make it ‘visible’ to outsiders
            I would like to add mine to the cal too
            • L
              Landler
              Hi Sam,
              i will try it this days. Need a litte bit more time. There’s an other “hobby” called family :-)
              Oliver
                sdetweil @Landler
                @Landler said in no integration of google family calendar and MM:
                time hobby consuming for sure!!!
                  only the creator will see the public/private urls, unless it is marked public
                  • L
                    Landler
                    Hi Sam,
                    scarry, I’m the administrator :-(
                    I will work on it
                    Oliver
                      sdetweil @Landler
                      @Landler ok, i created a new cal, and the links were in the integration section
                      is administrator same as creator?
                      • L
                        Landler
                        Yes it is,
                        I’m sitting in front of the system and doing all the creation, configuration, etc.
                        Oliver
                          randomBrainstorm
                          Try using https://github.com/randomBrainstormer/MMM-GoogleCalendar for your family calendar. I added it to the modules list just now.
