This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
Solved Black screen
@Vauxdvihl
and then restart mirror -
Mirror stays black :-( -
@Vauxdvihl if you do
cd ~/MagicMirror npm start
what do you see on the terminal window?
(alt-spacebar, n to minimize MM screen)
pi@PiMirrorNeu:~/MagicMirror $ npm start > magicmirror@2.9.0 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.9.0 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: newsfeed No helper found for module: clock. Initializing new module helper ... Module helper loaded: MMM-PublicTransportHafas No helper found for module: MMM-HTMLBox. Initializing new module helper ... Module helper loaded: MMM-DarkSkyForecast Initializing new module helper ... Module helper loaded: MMM-CalendarExt2 Initializing new module helper ... Module helper loaded: MMM-BMW-DS No helper found for module: MMM-Globe. No helper found for module: MMM-Timetable. WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del' Require stack: - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: newsfeed No helper found for module: clock. Initializing new module helper ... Module helper loaded: MMM-PublicTransportHafas No helper found for module: MMM-HTMLBox. Initializing new module helper ... Module helper loaded: MMM-DarkSkyForecast Initializing new module helper ... Module helper loaded: MMM-CalendarExt2 Initializing new module helper ... Module helper loaded: MMM-BMW-DS No helper found for module: MMM-Globe. No helper found for module: MMM-Timetable. App threw an error during load Error: Cannot find module 'del' Require stack: - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) at Function.Module._load (internal/modules/cjs/loader.js:531:27) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js:3:11) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) Whoops! There was an uncaught exception... Error: Cannot find module 'del' Require stack: - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) at Function.Module._load (internal/modules/cjs/loader.js:531:27) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js:3:11) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) { code: 'MODULE_NOT_FOUND', requireStack: [ '/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js', '/home/pi/MagicMirror/js/app.js', '/home/pi/MagicMirror/js/electron.js', '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', undefined ] } MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Launching application.
What is “del”
And why is needed now?
Strange -
@Vauxdvihl it was needed by MMM-Weatherchart module, but got deleted on the base update.
the automated script cycle was skipped due to the error
(this is the WHOLE reason I created the automated script, to cover this very problem)what is it? its some npm library the module uses
Ok
Everythings works fine now
